51psi? - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2013, 11:50 AM   #41
canadianlarry
Fan#: 102604
What I Drive: 2012 sterling grey 5spd se
Points 237, Level 4
Points: 237, Level: 4 Points: 237, Level: 4 Points: 237, Level: 4
Level Up 74% Completed
FF Reputation: 2 canadianlarry Good Standing Member
The stupid usually stay stupid. They never let information get in the way of a bad, uninformed decision.
canadianlarry is online now
Old 05-13-2013, 06:24 PM   #42
Julian@TireRack.com
Fan#: 102247
What I Drive: N/A
FF Reputation: 2 Julian@TireRack.com Good Standing Member
Here's something to keep in mind too.
The P in front of the tire size does actually mean something.
Here's a break down -
P215/55R16 Standard load max psi. - 44
psi. where max load is met - 35
psi. where max load is met - 36
P215/55R16 XL rated max psi. - 50
psi. where max load is met - 41
215/55R16 XL rated max psi. - 51
psi where max load is met - 42
Basically a P-Metric tire can't hold as much as a Euro Metric tire, and after you reach whatever psi. the max load it met at you're just giving yourself a stiffer ride or changing the handling characteristics of the tire.
This article explains a bit too - Tire Specs Explained: Maximum Inflation Pressure - the max inflation stuff is more important when you are upgrading your wheel size and going with a low profile tire, and usually only comes into importance with bigger vehicles, but I thought I would throw my name into the hat and get some info out there.
888-428-8355 ext. 4798
Julian@TireRack.com
Remember to reference Julian/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Julian@TireRack.com is offline
Old 09-16-2013, 04:34 PM   #43
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,360, Level 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
Level Up 40% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 CunFFS13 Good Standing Member
Max tire pressure 51
Then use PSI at 40-42
This is 80% of the max tire pressure
CunFFS13 is offline
