51psi? - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 05-02-2013, 11:05 PM   #21
Elizabeth
Elizabeth's Avatar
Fan#: 89280
What I Drive: '12 Yellow Focus SE stick, 17"rims
Points 12,559, Level 73
Points: 12,559, Level: 73 Points: 12,559, Level: 73 Points: 12,559, Level: 73
Level Up 28% Completed
Forum Activity 24%
FF Reputation: 14 Elizabeth Great Standing Member
Originally Posted by 2012silversel View Post
Exactly, psi increases 1 lb for every 10 degree rise in temp. Lets say you set your pressure today at 41 psi and the temp is 70, you drive and the tire heats up 30 degrees and now your at 43, in a week the temp is 90, the road is hotter and you tire heats up 40 degrees, now add 6 more psi and your rolling psi is at 47. Like what's already been said, the trade off for 1-2 mpg's isn't worth early tire replacement or a possible blow out. People with big brains and smart calculators have designed and determined the tire should be inflated to 35psi for safe, efficient and long life, I stick with the recommended pressure on the door sticker.
wrong.
The tire sidewall is cold pressure. So 51 PSI when "cold". So 51psi is safe when cold ,and the increase from driving is also OK. The sidewall rating takes into account the added heat/PSI increase from driving. (do you really think with lawsuit crazy lawyers, that the tire manufacturer would not take into account heat increase? the rating on the tire takes that into account
Now where I live the temps fall to well below freezing in Winter. So I actually check them at freezing in late Fall. Then in Spring I check them when it is about 70F outside. So I am good all Summer. (Even 100F no problem..)
I am happy the quoted person wants to be safe. not a problem. The issue is trying to tell others misinformation to attempt to stop them from doing this simple step to increase handling.
And "early replacement" where is that from? what sort of nonsense is that?
I have been running much higher PSI for 15 years.. And NEVER had a tire lose tread from center to cause early replacement.. In fact the tires wear far more evenly with higher PSI.
The one point I would make is if you wish to keep the tires wear even if you do not rotate,( I do not) is to have between 5 to 8 psi LESS in the rear than in front.
For a V-6 use 8psi, for a 4 banger, 5 psi higher in front.
As i mentioned.. I run 40 rear, 45 front on my Focus
(On my Contour SVT, I used to run 37 rear, 45 front, where 32 was standard)
I actualy did the tire print test on my SVT Contour. Where i checked the contact patch front and back.. finding the perfect patch with the 8psi difference..
Elizabeth is offline
Old 05-02-2013, 11:16 PM   #22
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Forum Activity 24%
Originally Posted by AZfocus2012 View Post
Here is a link to an article by someone who may have some knowledge of tires and psi's. Some good info, backing up and debunking some of what has been said here.
http://www.popularmechanics.com/cars...unked-10031440
Thanks. Agree an excellent article.
((and I agree with the comment about the Ford Crown Victoria psi.. A V-8 yeah, 10 psi difference..))
Old 05-02-2013, 11:35 PM   #23
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
What I Drive: 2012 White Platinum SEL 303A Focus
FF Reputation: 2 AZfocus2012 Good Standing Member
I just found the article on a google search. But it is concise and backs my thoughts that as long as your are between 35(door jam recommendation) and 51(or max psi cold) you will be fine. There is no real danger of catastrophic tire failure due to over-inflation until near 100psi, not 51, not 55 or even 60psi. Manufactures build in a large "safety margin" for the "Jay Walking All-stars" out there and those with faulty tire gauges. So go ahead and experiment with your pressures until you find a setting that suites your driving style and needs. If you don't have a clue, Elizabeth has some good numbers similar to what I run, or start with 38-40 front and 35 rear or 38-40 all the way around. Or just do 35 all the way around and keep a check on those pressures, because like the article says, it is better to be 3-5 over the 35 than 1 under the 35, thus backing my point that the 35 should be used as a do not go below number not necessarily the be all end all number.
AZfocus2012 is offline
Old 05-03-2013, 07:30 AM   #24
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,255, Level 64
Points: 9,255, Level: 64 Points: 9,255, Level: 64 Points: 9,255, Level: 64
Level Up 69% Completed
Forum Activity 6%
I like threads like this. Lots of well thought responses that make sense.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 05-03-2013, 08:07 AM   #25
2012silversel
2012silversel's Avatar
Fan#: 83969
What I Drive: 2014 C-Max Energi, Sterling Gray
Points 1,919, Level 26
Points: 1,919, Level: 26 Points: 1,919, Level: 26 Points: 1,919, Level: 26
Level Up 19% Completed
FF Reputation: 1 2012silversel Good Standing Member
Obviously, I'm completely wrong. In order for me to understand thermodynamics and heat expansion, I need help from the experts. If I have been driving on the freeway for several hours and I stop for fuel, I should check my tires and if the pressure is above the recommended setting on the door panel, or the pressure I chose to inflate them to, I should release air from the tires to match the desired pressure, correct? Elizabeth, if I understand correctly, I can have my tires inflated to a cold psi of 51 and under all driving conditions it will be safe and won't cause any premature or excessive wear on the tire?
2012silversel is offline
Old 05-03-2013, 09:25 AM   #26
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 23,764, Level 94
Points: 23,764, Level: 94 Points: 23,764, Level: 94 Points: 23,764, Level: 94
Level Up 42% Completed
Forum Activity 12%
FF Reputation: 49 dyn085 Great Standing Member
If you are driving normally (not RACECAR) and your car is not overloaded (rear tires supporting a loaded trailer or something), your tires will be fine with the increase in temp. As stated above, the lawyers have taken into account the tires load rating and normal temperature increase in relation to it's max pressure listed on the sidewall.
Better yet-nitrogen
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 05-03-2013, 10:47 AM   #27
BLÜE_BÄLZ
TWISVT
BLÜE_BÄLZ's Avatar
Fan#: 65778
What I Drive: '02 Twilight Blue ZX3, '94 Ranger
Points 8,100, Level 60
Points: 8,100, Level: 60 Points: 8,100, Level: 60 Points: 8,100, Level: 60
Level Up 75% Completed
FF Reputation: 14 BLÜE_BÄLZ Great Standing Member
Buy-Sell-Trade Rating: (20)
I usually run 5%-10% under the max on the sidewall of the tire. I ran my OEM's at 45-48psi and they still had more tread in the middle than on the sides when they were gone. Ride is a little firmer, but mpg's are better and cornering is better.
Agreed I do the same
And never have/had problems
OEM+ / UNDER CONSTRUCTION /
BLÜE_BÄLZ is offline
Old 05-03-2013, 11:30 AM   #28
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Points 9,842, Level 66
Points: 9,842, Level: 66 Points: 9,842, Level: 66 Points: 9,842, Level: 66
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 99%
FF Reputation: 70 sailor Excellent Standing Member
Nice discussion!
Had to "Jump In" to respond to this one.
The one thing you DON'T want to do, is reduce tire pressure to "normal cold" readings when it has INCREASED due to heat from driving. This causes under inflation, as you'll note once they cool down and are under the recommended value.
Also, the "cold" 51 would be "safe" if that's the max printed on the tire, but it would be quite uncomfortable. Leaves no room for front to rear difference to improve handling while remaining within the recommended zone as well.
Other notes:
Max. inflation pressure was once explained to me by a Dunlop rep. as the pressure used to inflate the tire during the molding process. This corresponds to the max. load capacity pressure, and the "shape" of the tire should be normal at this value.
Increased pressure (by approx 5 psi. over "sticker" recommendation) is often suggested in owner's manuals for "extended high speed driving". This reduces increase in pressure from heat buildup, and improves handling.
"Sticker" pressure is a compromise, as prev. noted, and is related to the actual maximum recommended load (vehicle & passengers, etc.). You'll see a note as to vehicle load capacity (cargo, passengers) on that sticker.
Pressure differential, front to rear, is used to adjust handling. Higher pressures give greater cornering traction, and with the vast majority of cars being "tuned" for understeer from the factory using a bit more in the front evens things out a bit.
As to those Explorers, I've seen MANY tooling down the Hwy at 80 or more, with what looks to be about 15 psi in the rear.... Need I say more?
Cheers!
sailor is online now
Old 05-03-2013, 07:05 PM   #29
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,129, Level 27
Points: 2,129, Level: 27 Points: 2,129, Level: 27 Points: 2,129, Level: 27
Level Up 86% Completed
Forum Activity 7%
FF Reputation: 3 Juicedz Good Standing Member
Very glad I opened this topic up, tons of good information. I've decided to try 42psi front and 38 rear based on everything I've read. With the possibility of increasing that for longer trips? The car is driven daily so no racecar stuff. The tires are 215/60/16 conti's so that's probably aiding the comfort tolerance level with the psi increase.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 168whp 153wtq
Juicedz is offline
Old 05-03-2013, 09:53 PM   #30
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
FF Reputation: 4 gtferrari Good Standing Member
for every 10 degrees of temperature change your tires will change by 1 psi. so youll be safe if you go from fargo to death valley.
tires are rated for max load at max rated speed at max pressure. the worst conditions possible. there is a built in buffer zone to cover everyone's butts. your happy the companies are happy and the lawyers are happy.
i did have a f150 with a hung up caliper come in off the expressway. my dad said it was pulling and had a funny smell. 3 tires tested at 38 psi and the front left was 98 psi. max value on that tire was 50psi. i pulled the valve and stepped back. that air was wicked hot and you couldnt touch the wheel without receiving a burn
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
