51psi? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 05-02-2013, 07:24 PM   #1
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
FF Reputation: 3 Juicedz Good Standing Member
51psi?
I've got the 16" Conti's on my se. I went to check the air today and read the max inflation for the tire is 51psi. If this is correct I'll be loving my new found mileage. Rears were 30psi & fronts 35psi. The max mounting psi is 40psi on the rim?
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 168whp 153wtq
Juicedz is offline
Old 05-02-2013, 07:33 PM   #2
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
FF Reputation: 49 dyn085 Great Standing Member
Moved to Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 05-02-2013, 07:36 PM   #3
Juicedz
Juicedz's Avatar
Fan#: 108814
My bad. Thanks for the lift.
Juicedz is offline
Old 05-02-2013, 07:50 PM   #4
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (17)
NEVER EVER FILL YOUR TIRES TO THE MAX PSI RATING ON THE TIRE!
the correct setting is 35 PSI there is a sticker on your door jam stating this, it can also be found in your owners manual.
SkyPilot is offline
Old 05-02-2013, 07:52 PM   #5
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
What I Drive: 2012 White Platinum SEL 303A Focus
FF Reputation: 2 AZfocus2012 Good Standing Member
I usually run 5%-10% under the max on the sidewall of the tire. I ran my OEM's at 45-48psi and they still had more tread in the middle than on the sides when they were gone. Ride is a little firmer, but mpg's are better and cornering is better.
AZfocus2012 is offline
Old 05-02-2013, 07:52 PM   #6
Benner
Benner's Avatar
Fan#: 77653
What I Drive: 2003 Zx3
FF Reputation: 1 Benner Good Standing Member
51 PSI is the max pressure that tire is rated for. At 51 PSI you'll wear out the center tread quickly. Vehicle Manufacturers figure out what tire pressure gives the best combination of mileage and even tire wear.
You may gain a couple MPG but it's nothing compared to the cost of replacing 4 tires several thousand miles early.
By the way I'm a Mechanic at "Tire Discounters" so I see the results of over inflation every day.
Benner is offline
Old 05-02-2013, 07:55 PM   #7
AZfocus2012
Fan#: 92484
Originally Posted by SkyPilot View Post
...the correct setting is 35 PSI there is a sticker on your door jam stating this, it can also be found in your owners manual.
To me the door jam number is a bottom number not to go below, because it is so close to being under inflated anything less would be dangerous.
Old 05-02-2013, 08:26 PM   #8
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
FF Reputation: 16 ShoOff Great Standing Member
im sorry but 51 is just crazy! and the ride must be horrible for everyday driving as well. I keep mine right at 40 and i thought that was a little high
ShoOff is offline
Old 05-02-2013, 08:33 PM   #9
Juicedz
Juicedz's Avatar
Fan#: 108814
I didn't set it there but what I observed On the tire. I set it slightly over 40 psi. Temps get hot in Florida so I worried about the increase in pressure from heat. Sounds like I should take it a little lower though.
Juicedz is offline
Old 05-02-2013, 08:46 PM   #10
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 54 felixthecat Excellent Standing Member
Set your tires at the recommended pressure.
Introduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
