Shifting issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-01-2013, 11:39 PM   #1
Workaholic
Fan#: 114213
What I Drive: 2005, white zx3 hatch
FF Reputation: 1 Workaholic Good Standing Member
Shifting issue
Ok, so I have an 05' mk1 I just purchased. First adventure in the Focus World BTW. Definitely liking the car so far. pretty fun to drive even though its stock. Here's the problem that i'm having that is fairly new to me but i'm not sure if this is common with these cars or not.
When driving casually I can shift into 3rd gear and it shifts smooth with no issues at all.
When driving "aggressively" it will grind a small amount just at the end of the shift. I've tried depressing the clutch pedal more thinking I was short changing the clutch. Tried a different way of engaging the gear. It appears the only thing that prevents it is slowing down the shift. Could it be the shift linkage is just worn out?
Because of the car having 112k and feeling like they are worn out/too soft for my liking. The first two things I'm looking at doing to the car are suspension (still undecided since it appears H&R is no longer producing their cup kit for this car) and a SSK w/solid shift inserts. Think the SSK w/inserts will solve this issue?
Thanks,
Workaholic is offline
Old 05-02-2013, 12:14 AM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I start by making sure the trans fluid is full and in good condition. If you have any doubts i'd change it using the Ford stuff. That being said, its not a racing transmission so if you force it, too fast, it will probably grind.
jetrinka is offline
Old 05-02-2013, 12:18 AM   #3
Workaholic
Fan#: 114213
I understand its not a racing transmission. I shift 1,2,4 and 5th at the same speed and dont have this issue. I'll have to check the fluid. I think its old anyways, based on how it acts when cold. its not being forced into gear. it engages just fine I just hear it grind a small amount when going into 3rd.
Old 05-02-2013, 12:33 AM   #4
Lappracing
Fan#: 74732
What I Drive: 2009 Focus black/silver
Points 168, Level 3
Points: 168, Level: 3 Points: 168, Level: 3 Points: 168, Level: 3
Level Up 36% Completed
FF Reputation: 2 Lappracing Good Standing Member
Grinding going into 3rd is a common issue for the Focus.
Lappracing is offline
Old 05-02-2013, 07:53 AM   #5
Workaholic
Fan#: 114213
Is there a fix for it?
Old 05-02-2013, 10:21 AM   #6
streetfocus
streetfocus's Avatar
Fan#: 5768
What I Drive: 2004 Black Focus SVT
Points 2,551, Level 30
Points: 2,551, Level: 30 Points: 2,551, Level: 30 Points: 2,551, Level: 30
Level Up 68% Completed
FF Reputation: 2 streetfocus Good Standing Member
I would guess it is the linkage. I have never had this problem in my 05, and I drive aggressively more than not. The MTX75 (trans) is strong and can handle whatever you can throw at it. I don't baby mine. I think yours needs adjustment or replacement of the linkage or shift cable.
05 ZX3: Steeda intake, 67mm TB, custom 2.5 Magnaflow exhaust, Tom's Tune.
New: 04 SVT : K&N panel filter, 3 performance motor mounts, Taylor wires, orp, 67mm TB, Tom's Tune.
streetfocus is offline
Old 05-17-2013, 08:41 AM   #7
zavalax3
zavalax3's Avatar
Fan#: 89532
What I Drive: 2006 matte black zx3
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
FF Reputation: 1 zavalax3 Good Standing Member
i got the same problem with my 06 focus and it only has 32k miles....
zavalax3 is offline
Old 05-17-2013, 01:49 PM   #8
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Points 1,622, Level 23
Points: 1,622, Level: 23 Points: 1,622, Level: 23 Points: 1,622, Level: 23
Level Up 22% Completed
Forum Activity 5%
FF Reputation: 3 replica81 Good Standing Member
Both my 2003 ZX5 and current 2005 ST will make a little crunch when shifting very fast at redline into 3rd. It's just part of the Focus charm.
SR #272
Beer and Metal.
replica81 is offline
Old 05-27-2013, 04:39 PM   #9
grayzx35speed
grayzx35speed's Avatar
Fan#: 94839
What I Drive: 2006 Gray ZX3
FF Reputation: 0 grayzx35speed Newbie
Mine doesnt crunch or grind at high rpm into any gear. Then again I change my trans fluid and filter regularly. Might be bad/wrong fluid, or as street focus said bad linkage or cable.
North East Honda Killer
OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane
grayzx35speed is offline
Old 06-14-2013, 02:15 AM   #10
datzx3
datzx3's Avatar
Fan#: 109304
What I Drive: 2007,infra-red,zx3 se
FF Reputation: 1 datzx3 Good Standing Member
I test drove a 05 focus and my 07 focus dus that from time to time
datzx3 is offline
