How-To LED taillight on MK3 write up - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-01-2013, 10:52 PM   #1
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
Points 7,594, Level 58
Points: 7,594, Level: 58 Points: 7,594, Level: 58 Points: 7,594, Level: 58
Level Up 22% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 21 RAF_S197 Great Standing Member
Buy-Sell-Trade Rating: (4)
* * * I am not responsible for any damage or warranty issues from this modification. Do it at your own risk! * * *
Here is a how to write up I made for the install of LED taillights on the MK3 (however I would think the taillight wiring harness would be the same on a sedan)
Tools needed
Wire cutters
Wire crimpers
Electrical tape
Electrical wire
Shrink tube (optional)
Voltage tester (optional)
3M heave duty outdoor double sided tape (optional)
If you are unsure of which LED bulbs to buy, I bought the following off Amazon
Plasma red LED's
* * * You will need 3 pairs of these * * *
http://www.amazon.com/gp/aw/d/B00C16...A12J7DMK6HQWCS
Resisters to keep your blinkers from hyper flashing and getting a brake light bulb fault
* * * You will need 2 pairs of these * * *
http://www.amazon.com/gp/aw/d/B007G6...A12J7DMK6HQWCS
First what I did to the resisters was I extended the wires from each end longer so I have slack to mount the resisters themselves and able to keep the wires tidy within the taillight harness. I'm not sure exactly how much I lengthened them but you can judge for yourself. I would estimate about 4 inches on each end or so
* * * this is where you use the electrical wire and shrink tube (or electrical tape)* * *
Remove both taillights or one at a time like I did. If you are u sure how to do it I know there is a thread on how to remove them somewhere on this forum.
Next remember which taillight socket is which or mark them before unplugging them so you know which is which.
* * * How to wire resisters * * *
brake light
Wire one end of the resister to the beige wire which is your brake power wire and the other end of the resister to the brake ground which is the second wire over on that bulb socket.
Once this is done your middle black wire will remain untouched.
Your brake light socket is ready to put in your LED bulb.
Turn signals
Follow the same instructions as the brake light but wire the resisters to the grey wire instead of beige
* * * 3157 bulb modification for signals * * *
Since the bulb you are putting in as a signal bulb is a 3157 you will have to snip the little nipples on the bottom sides to get the bulb to fit. Once you do that the bulb will still fit in snug and work
At this point what I did was used the 3M double sided tape and put it on the underside of the resisters so I can mount them to the body instead of drilling holes (the tape is holding up just fine with the heat the resister puts out)
At this point plug your harness back in and start your car, turn on your headlights, push your brake a few times and turn your left then right turn signal.
Shut off the car and start it back up making sure you don't get any light out error messages.
If you don't have any error messages you can plug in your night time driving bulb which is a plug and play, same as reverse light.
Now you can mount your resisters, plug in your bulbs and re install your taillights.
Here is a piece of the location of the resisters I ended up with after having to move them a few times without coming too close to the taillight or hitting the taillight housing.
Stock bulbs on left, plasma LED on right
LED's
Night lights, signal and brake all on at once
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is online now
Old 05-02-2013, 12:04 AM   #2
FocusTi
FocusTi's Avatar
Fan#: 102567
What I Drive: Black 2012 Ford Focus Titanium
FF Reputation: 1 FocusTi Good Standing Member
WOW, those are a lot brighter then I thought they would be. Adding to the future mod list.
Nice job and thanks for the great write up.
Current Mods: Snorkel Delete with ITG Filter and newmission intake, Rear Sway-Bar, Magnaflow Exhaust, RMM and Hitch
Future Mods: Coilovers, End-Links, Tune, and Brakes
FocusTi is offline
Old 05-02-2013, 12:22 AM   #3
tt333
tt333's Avatar
Fan#: 102397
What I Drive: 2012 Focus SE
FF Reputation: 1 tt333 Good Standing Member
Nice write up. They don't look much different in your daytime pic but look extremely bright in your night shot. How are they in person?
tt333 is offline
Old 05-02-2013, 02:21 AM   #4
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
Points 18,979, Level 87
Points: 18,979, Level: 87 Points: 18,979, Level: 87 Points: 18,979, Level: 87
Level Up 26% Completed
Forum Activity 28%
Activity: 28% Activity: 28% Activity: 28%
FF Reputation: 43 Duffman355 Great Standing Member
shit, i was just gonna do reverse lights after realizing the crees didn't fit up front. Kudos Dude!
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 05-02-2013, 02:36 AM   #5
ShogunSamurai2005
ShogunSamurai2005's Avatar
Fan#: 91057
What I Drive: 2012 White Ford Focus 5 dr
Points 596, Level 11
Points: 596, Level: 11 Points: 596, Level: 11 Points: 596, Level: 11
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 ShogunSamurai2005 Good Standing Member
So its just brighter red light? I honestly thought it was going to be led strips like the focus electric vehicle! Gggrr!
ShogunSamurai2005 is offline
Old 05-02-2013, 03:07 AM   #6
FocusTi
FocusTi's Avatar
Fan#: 102567
Someone needs to make actual LED tail lights for our cars. Until that happens though, this is a great mod too.
FocusTi is offline
Old 05-02-2013, 03:26 AM   #7
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
Forum Activity 28%
props are still due to OP. LED lights barring heat don't ware out . . .
Randomie's Lover #8
Old 05-02-2013, 09:03 AM   #8
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,389, Level 65
Points: 9,389, Level: 65 Points: 9,389, Level: 65 Points: 9,389, Level: 65
Level Up 13% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
Good write-up RAF. Thanks,
Rep'd ya.
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 05-02-2013, 09:31 AM   #9
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 17%
They are actually really brought. I'll try to take a video soon.
I was comparing them to the OEM LED taillights on my 2012 Mustang and as far as brightness I'd say they are the same which is exactly what I was looking for.
No LED strips, sorry I couldn't help you
Rep'd ya.
Thanks for the rep!
Thanks everyone. Any questions feel free to ask
Old 05-02-2013, 12:26 PM   #10
kevinxb
kevinxb's Avatar
Fan#: 96008
What I Drive: 2012 Blue Candy Ti Hatch
Points 580, Level 11
Points: 580, Level: 11 Points: 580, Level: 11 Points: 580, Level: 11
Level Up 60% Completed
FF Reputation: 2 kevinxb Good Standing Member
Curious if anyone has used a resistor like this: http://bit.ly/18v2c46. I contacted the seller and they claim they don't get hot, but I don't see how that could be.
kevinxb is offline
