help! exhaust fix - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-01-2013, 12:26 PM   #1
kirkus8
kirkus8's Avatar
Fan#: 72303
What I Drive: 2006 silver zx3 se
FF Reputation: 1 kirkus8 Good Standing Member
help! exhaust fix
So I am aiming to remove my secondary cat like most exhaust systems do. I have a 2.5" magnaflow from the second cat back. So heres the problem, once the cat is off I need to connect the stock less than 2" pipe to my aftermarket 2.5" pipe without welding. My first thought why not use a 2-1/4" pipe and slide it over stock then clamp and seal. Then slide it into aftermarket with a pie type cut on the 2.5" to help it clamp down. Anyone have any ideas!? Thanks.
Cant have an exhaust shop do it either ive tried, they dont touch cats
2006 ford focus zx3 se
Fswerks CAI, 17" black race line wheels, Fswerks upper front stress bar, FRPP suspension, Custom 2.5" Magnaflow Exhaust, Steeda sts, Steeda shift knob
Hatch nation #54
kirkus8 is offline
Old 05-01-2013, 02:47 PM   #2
AllCarFan
Fan#: 102583
What I Drive: 2005 Saleen Sonic Blue S121
FF Reputation: 1 AllCarFan Good Standing Member
kind of hard to picture what you are doing.
Cutting off second cat....then you have a less than 2" OD pipe you want to connect to a 2.5" OD pipe? HOw much less than 2" are we talking here?
Something like this? http://www.ebay.com/itm/Walker-Exhau...ht_1422wt_1091
AllCarFan is offline
Old 05-01-2013, 05:53 PM   #3
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
I take it this is after the flex? If so measure from the flex mount= where it bolts up, to where your magna flow is at right now. Measure a couple of times, then cut right at the magna flow is now. Unbolt the flex & cut your converter out & take the pieces to a shop w/ your measured length welded in.
felixthecat is offline
Old 05-01-2013, 07:12 PM   #4
kirkus8
kirkus8's Avatar
Fan#: 72303
I need to connect stock size pipe right after flex to my 2.5" aftermarket exhaust which starts right after that second cat I want off
Hatch nation #54
kirkus8 is offline
Old 05-01-2013, 07:26 PM   #5
AllCarFan
Fan#: 102583
see ebay link
Old 05-01-2013, 07:31 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,380, Level 75
Points: 13,380, Level: 75 Points: 13,380, Level: 75 Points: 13,380, Level: 75
Level Up 33% Completed
Forum Activity 99%
If you want to be able to clamp things together,most parts stores have a selection of "reducers" that are short pieces of pipe with a different size at each end.
Something like 2 1/8 over the 2"", and 2 3/8 inside the 2.5" might work. you need to measure ID's and OD's then see what they have that'll work, then buy the clamps to fit that.
Done it before, with the multitude of adapters avail. you should find a fit that works.
Luck!
sailor is online now
Old 05-01-2013, 08:13 PM   #7
kirkus8
kirkus8's Avatar
Fan#: 72303
I cannot just simply connect the two with a reducer. Its about a 12" gap. What wrong with using no reducers just a 2-1/4" pipe. Slide it over stock siZE exhaust and slide into aftermarket. Exhaust flow would be better that way too. Clamp both ends and use exhaust paste and tape to fill any gaps.
Hatch nation #54
kirkus8 is offline
Old 05-01-2013, 08:26 PM   #8
AllCarFan
Fan#: 102583
Just buy extra pipe and a reducer. You will have leaks any other way.
Old 05-01-2013, 08:49 PM   #9
kirkus8
kirkus8's Avatar
Fan#: 72303
What size pipe and what size reducers? Do I need two?
Hatch nation #54
kirkus8 is offline
Old 05-02-2013, 09:04 AM   #10
AllCarFan
Fan#: 102583
See pic:
Most of this can be picked up at any autoparts store. Or, give the measurements and specs to an exhaust shop....have them fab it...take it home, and bolt it on yourself. I would do the latter...then, at least it would all be welded up...and the exhaust shop doesnt even ever have to touch the car.
