Repro ST3 Projector Headlights (review and write-up) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-01-2013, 11:07 AM   #1
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,304, Level 64
Points: 9,304, Level: 64 Points: 9,304, Level: 64 Points: 9,304, Level: 64
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
I recently purchased and became a guinea pig for a set of ST3 reproduction projector headlights. These lights came from China as an advertised "plug-n-play." I was not disappointed. This first post is to show the headlights as they arrived, to include packaging, material, and the lights themselves.
This box was pretty stout. There was no visible damage to the outside of the box nor to its contents.
As you can see the headlights were packed in a cardboard box, which was then 'wrapped' in wood. Literally.
There was no lack in packaging material to ensure the safety of the contents.
Each headlight came individually wrapped in not only packaging material but film in-order to further ensure protection.
*Important to note: The headlights came supplied with all of the lights needed, short of the low-beam bulb. (More on this later)
The headlights also came with all necessary plugs, covers, wiring, connectors, etc..
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is online now
Old 05-01-2013, 11:08 AM   #2
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
In this post you'll find a write up for the headlights. Not the HID. That can be found in a later post.
As I said, these headlights are advertised as a "plug-n-play" unit. They are, however, if you want the LED brow to work as a DRL than there needs to be a little work done. That is what this post is, a write-up to get the LED brow to operate as a DRL.
You'll notice that there is a stand alone yellow wire that comes out of the bottom of the headlight housing. This wire is what is used to operate the brow as a DRL. The connector itself is odd and no male end was supplied. So I cut it off...
And crimped a male-end connector to it.
I ran a wire the from the fuse box to each headlight area and crimped a female-end to it. This enabled a easy quick connect/disconnect when pulling the headlights out.
I soldered wire from the right headlight into the left and ran a single wire to the fuse box.
I tapped into the "power/heated mirror" fuse. It is a hot power source ONLY when the ignition is on.
No ignition power. No LED brow.
Ignition power, and viola, LED DRL.
<>< Gal. 6:14
April 2013 HOTM
Old 05-01-2013, 11:09 AM   #3
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
I want to make sure that I make this clear:
The inner most light came equipped with an H1 bulb. The harness, however, did not come connected to anything. Literally the green wire in the harness was cut. In other markets, NOT THE U.S., this is used as a 'cornering lamp'. That is not the case here. So. One these headlights, from this manufacturer, there is no use for the inner most light.
The LED brow IS the parking light. Without wiring it as a DRL it ONLY comes on when the parking lights are on, or the headlights have been turned on. The LED brow is the parking light. As you saw in the above post I wired them to be DRLs.
The high-beam comes equipped with an H7 bulb. I upgraded mine to the Sylvania ZXE H7 for better light output and a whiter light.
The low-beam is the projector. It REQUIRES a H7 bulb. Whether you choose to go HID (which I did, you can find that information in a later post) or halogen is your choice. You'll find pictures for both as I wanted to let those reading this see the difference. Projectors are MEANT for HID lights, but can be ran with halogen. Your H11 bulb in the stock housing WILL NOT work. The connections are different.
With halogen:
With HID (6000k):
With halogen:
With HID:
With halogen:
With HID:
<>< Gal. 6:14
April 2013 HOTM
Old 05-01-2013, 11:09 AM   #4
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
In this post you'll find a basic HID write-up. The HIDs I bought came with a wiring diagram. You will not find an extensive "how-to" in this post, merely the mounting points that I used in conjunction with the wiring diagram.
This is where I mounted and grounded the resistor for the left HID.
This is where I mounted the ballast on the left.
This is the ground point I used for the wiring harness NEEDED for the Focus in order to prevent the "low-beam bulb out" error.
Same thing on the right side for the resistor and ground point.
Same location for the ballast as the left.
The black covered wires (the one with writing on it) is the HID wiring. It is what connects the left to the right. I wired it along the front of the car and zip-tied. There is enough wire for slack at either end if routed and done properly. The red wire, you'll notice, is the positive wire for the DRLs.
This is the ground point for the right Focus specific wiring harness.
<>< Gal. 6:14
April 2013 HOTM
Old 05-01-2013, 11:41 AM   #5
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
In this post you will find pictures...and lots of them. Enjoy.
<>< Gal. 6:14
April 2013 HOTM
Old 05-01-2013, 11:51 AM   #6
kevinxb
kevinxb's Avatar
Fan#: 96008
What I Drive: 2012 Blue Candy Ti Hatch
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 2 kevinxb Good Standing Member
Buy-Sell-Trade Rating: (4)
Excellent writeup so far, looking forward to the rest. Curious if anyone who has ordered these has ordered the ones on Alibaba that come with HID already installed. Seems like it would save a few steps if you're planning to put HID in anyway, but who knows what the quality of the components they include is like.
kevinxb is offline
Old 05-01-2013, 12:27 PM   #7
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
I have tried to provide as many pictures as I could as well as providing as much explanation and detail I could.
Feel free to ask any questions you want, and I'll answer them the best I can.
This thread is NOT for debating the worth of Chinese headlights. If you want to do that. Feel free to...somewhere else.
Rep, if you want to, and enjoy.
<>< Gal. 6:14
April 2013 HOTM
Old 05-01-2013, 12:31 PM   #8
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
I should also mention that at this point I have done the following to 'test' the lights:
- 1500 + miles since installation.
- Power car wash (to test the lights seals). No leaks, no fogging, no condensation.
- Three storms, one to include hail .
- They've been in weather below freezing and in weather above 90 degrees. How is this possible you ask?! OKLAHOMA. That's how.
- I've ran them non-stop for 8 hours.
So far these headlights have held up like I would expect OEM headlights to hold up. I haven't had an issue with them yet.
<>< Gal. 6:14
April 2013 HOTM
Old 05-01-2013, 12:32 PM   #9
Tubeway Army
Fan#: 111167
What I Drive: 2013 Focus Lemon
Points 2,284, Level 28
Points: 2,284, Level: 28 Points: 2,284, Level: 28 Points: 2,284, Level: 28
Level Up 90% Completed
Forum Activity 5%
FF Reputation: 0 Tubeway Army Newbie
Good write up...not exactly "plug n play" as I originally expected but not too bad.
Sent from my SGH-T679 using FF Mobile
Tubeway Army is offline
Old 05-01-2013, 12:36 PM   #10
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 16,967, Level 83
Points: 16,967, Level: 83 Points: 16,967, Level: 83 Points: 16,967, Level: 83
Level Up 24% Completed
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
Nice upgrade!
Will aka Misfire
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
