Clutch HELP - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 04-30-2013, 12:15 PM   #1
Eric1973
Fan#: 114155
What I Drive: 2002 Red Focus
Points 42, Level 1
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
Level Up 84% Completed
FF Reputation: 1 Eric1973 Good Standing Member
Clutch HELP
Can anyone help me.. I just spent 2 days replacing the clutch in an 02 Ford Focus.. All went very well until it was time to start it.. Car started fine. But will not shift when the car is running at all. I will try to give all specifics, Car will shift when OFF. If I put the car say in reverese and then start it the car wants to move on its own with the clutch pushed in.. Same thing in 2nd gear but alittle worse the car will shake or stall with the brake applied..
I have tried to bleed it acouple times.. Not sure if I am doing that correctly. I guess the biggest question is should I continue to try and bleed it or should I check my linkages. (And I have checked the brake or clutch fluid has plenty I am adding more everytime I bleed it so that is not dry and has enough..) Or could it be a different problem other than linkage. I replaced the clutch master cylinder about 6 months ago on the clutch pedal. And thank you to Ericthecarguy video for the clutch replacement Awesome video, very detailed, saved me alot of problems..
Thank you in advance for your help,
Eric
Eric1973 is offline
Old 04-30-2013, 02:39 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,120, Level 50
Points: 6,120, Level: 50 Points: 6,120, Level: 50 Points: 6,120, Level: 50
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (22)
Continue to bleed the slave cylinder. Is anyone helping you?
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 04-30-2013, 03:18 PM   #3
Eric1973
Fan#: 114155
Points 42, Level 1
Youre the Man!!!
I just got back from a test drive and you are absolutely right!!!
I bled it and bled it and bled it and bled it and what do you know that was the problem... WHEN IN DOUBT BLEED IT..... LOL... Car drove smooth thank you for the reply and the help.... I was convinced I had to pull the tranny again.. Thank god...
Eric1973 is offline
Old 04-30-2013, 03:49 PM   #4
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 54%
You are very welcome. That is why we are here.
Welcome to the site.
Hatch Nation #140
freemind is offline
