02 ford focus Check engine read trick - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2013, 03:14 PM   #1
ratedterror
Fan#: 103865
What I Drive: 2000 white focus
FF Reputation: 1 ratedterror Good Standing Member
Once upon a time i came across a post somewhere on the net of a method using a light pen(w/e they're called) to touch some wire under the hood, and the bulb will flash the engine codes.
I know some of you will say get a code reader but here in Canada they cost upwards of 300, and there no shop which reads them for free(60 bucks)
Plus i know i got a cat deficiency code that i have yet to replace the cat. But i have suspicions some other sensor has gone so hopefully someone here knows of this method to read the code and can share this knowledge, thanks guys
ratedterror is offline
Old 04-29-2013, 04:27 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,790, Level 73
Points: 12,790, Level: 73 Points: 12,790, Level: 73 Points: 12,790, Level: 73
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 99%
Remember that from some pre-OBDII cars, some even had the test of that type built in under the hood.
For ours, the "ODO trick" can get you part way there (only gives code #'s).
It's detailed in the "stickies" at the top of this page, but basically all you have to do is hold the reset button while turning it on to get into a diagnostic mode. From there you can "toggle" through different functions by pressing the button repeatedly. This is often used to get numeric readings for temp, tach. etc.. it'll also give you any codes, then someone can help with what the numbers mean....
Luck!
sailor is offline
Old 04-29-2013, 04:27 PM   #3
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
You beat me to it...............LOL.
amc49 is offline
Old 04-29-2013, 05:20 PM   #4
ratedterror
Fan#: 103865
Luck!
this has been explored before, as I know for a fact one of the codes will read a cat malfunction. But on the odo codes doesn't show this at all. It has also been said that the odo has only basic codes and is not used for diagnostics but for use in testing from the dealership. The odo test mode does not give you engine trouble codes. Least not mine and according to other also.
Ill go try again tho and post anything i find.
Old 04-29-2013, 11:33 PM   #5
amc49
Fan#: 96610
Forum Activity 9%
A good scanner will pick up 'pending' codes which don't trigger a CEL. PCM finds them but they are not flagged as hard faults yet. That's possible with many of them.
amc49 is offline
Old 05-01-2013, 02:30 AM   #6
mikew
Fan#: 114186
What I Drive: 2002,White,Focus Wagon aka The Tank
FF Reputation: 1 mikew Good Standing Member
Where are you in Canada? PartSource will scan your car for free and tell you the code and fix.
http://www.partsource.ca/store/canad...ive-stores.asp
mikew is offline
Old 05-01-2013, 03:13 AM   #7
ratedterror
Fan#: 103865
Im in Saskatoon Saskatchewan. the only thing part source is willing to scan is your car battery. they don't read engine codes.
Old 05-01-2013, 03:40 AM   #8
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 945, Level 16
Points: 945, Level: 16 Points: 945, Level: 16 Points: 945, Level: 16
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 3%
FF Reputation: 3 CotyM Good Standing Member
Does the ford focus Canadian not use OBD-II like the US versions?
I went on the canadian amazon (amazon.ca) and found my code reader:
http://www.amazon.ca/Professional-Di..._sim_sbs_ce_17
For some reason it only has 2 stars, but the US website is rated 4 stars Anyway, mine works great, it includes a book that list how to use it and all error codes...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is online now
Old 05-01-2013, 07:14 AM   #9
02ztsian
02ztsian's Avatar
Fan#: 14466
What I Drive: V6Mistake, 03 ZX3
Points 3,019, Level 33
Points: 3,019, Level: 33 Points: 3,019, Level: 33 Points: 3,019, Level: 33
Level Up 80% Completed
Forum Activity 3%
FF Reputation: 9 02ztsian Good Standing Member
Buy-Sell-Trade Rating: (14)
Princess Auto has a AutoLink AL419 OBDII scanner on right now for $80.
http://www.princessauto.com/pal/prod...-CAN-Scan-Tool
Plus there is a Princess Auto in Saskatoon.
02ztsian is online now
Old 05-03-2013, 01:19 AM   #10
mikew
Fan#: 114186
they've done it here before, (regina)
Sometimes Canadiantire has them on sale or you could check Cashopolis, the one here has some for cheap.
mikew is offline
