Possible clutch replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2013, 12:38 PM   #1
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Points 1,607, Level 23
Points: 1,607, Level: 23 Points: 1,607, Level: 23 Points: 1,607, Level: 23
Level Up 7% Completed
Forum Activity 3%
FF Reputation: 3 replica81 Good Standing Member
I've noticed recently that sometimes it seems like my clutch is slipping. If I shift around 6,000 rpm, quickly, in 1st and second, I get a normal amount of wheel spin and the clutch grabs hard. However, over the weekend, I noticed when shifting from 3rd to 4th at around 6,000 rpms, the RPMs would float for a second, then finally go down and the car would start pulling again. It feels like it's slipping. Due to the speeds required to test this again, I'm hesitant to try it.
The car seems to do fine going up steep inclines when at low rpms in tall gears. Perhaps I just need to bleed the clutch slave cylinder?
SR #272
Beer and Metal.
replica81 is offline
Old 04-29-2013, 01:12 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
It could be on its way out. How many miles do you have on it?
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 04-29-2013, 01:21 PM   #3
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Forum Activity 3%
I'm curious what Ford will charge to replace it.
SR #272
Beer and Metal.
Old 04-29-2013, 01:55 PM   #4
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Forum Activity 3%
Calling around, the parts/labor is around $1,200. Lol. What the hell.
SR #272
Beer and Metal.
Old 04-29-2013, 02:53 PM   #5
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Dealerships are expensive. Did you try calling an independant shop? Its about a 4-8 hour job, and an OEM style clutch (LUK, etc) is going to be about $150 plus shop markup.
How is the pedal feel? If it still feels normal, I would be hesident to say its the slave cylinder. You could try bleeding it, which is obviously far cheaper than a clutch, but I don't have high expectations it will fix it.
Egz is offline
Old 04-29-2013, 03:28 PM   #6
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Forum Activity 3%
Pedal feels fine. Slightly mushy on that 3/4 redline shift. Like the clutch isn't fully disengaging. I'll give it a bleed and see. Since it's pretty much free to bleed it.
SR #272
Beer and Metal.
Old 05-10-2013, 01:57 PM   #7
brady2005
brady2005's Avatar
Fan#: 110534
What I Drive: 2005 silver zx5
Points 539, Level 10
Points: 539, Level: 10 Points: 539, Level: 10 Points: 539, Level: 10
Level Up 78% Completed
FF Reputation: 1 brady2005 Good Standing Member
I just had my clutch/slave/p.p and flywheel replaced at the dealer, almost 2000.00 . Thankfully they did it under warranty because I was still in the 90 day warranty I got with it. If you do get it replaced, be ready for them to say you need a new flywheel too if its dual mass which is $$$$, youd be better off getting a ( if your focus has a dual mass) aftermarket like exedy with a solid flywheel conversion. I hear there a bit more noisy and vibrant but not bad.
brady2005 is offline
Old 05-10-2013, 03:03 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
FWIW - I didn't notice my clutch pedal return spring was broken/missing since before I bought the car, until it was time to replace the clutch master cyl.. (me bad)
Might help just a touch in getting it to grab quicker if you have the same issue...
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
