Not Sure Where to Start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-28-2013, 08:43 PM   #1
lacole725
lacole725's Avatar
Fan#: 85112
What I Drive: 2010 Ingot Silver Focus SE Sedan
Points 3,148, Level 34
Points: 3,148, Level: 34 Points: 3,148, Level: 34 Points: 3,148, Level: 34
Level Up 66% Completed
Forum Activity 2%
FF Reputation: 3 lacole725 Good Standing Member
Hey everyone,
I want to start doing some suspension mods, but I'm not sure what to do first. I was thinking adding a rear sway bar since I don't have one, but I don't know which one is best. I would also probably have to upgrade the front sway bar if I put in a good size rear one. I was also thinking about doing some stress bars. I do not want to do coilovers, though. Also, if I were to install some lowering springs, would I have to install new dampers? I'm considering Road Magnet springs because they are kind of local to me and I have heard good things about them, plus their springs come in a ton of colors. I just don't know if springs are the best place to start. Thanks for the help.
Sent from my SCH-I535 using FF Mobile
Adam
lacole725 is offline
Old 04-29-2013, 12:18 AM   #2
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
well, you have many options here. the general consensus is that yes, if you lower you should also get new dampers, too. sway bars will greatly increase cornering. lowering will decrease your body roll, and it looks nice (if not too much). strut tower bars are okay, start with the rear though, as the front is basically just looks because of how the strut towers are right next to the firewall. otherwise, there's hundreds of threads out there with people's set-ups, all with reviews of how they feel about em.
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 04-29-2013, 01:06 AM   #3
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
Please don't choose suspension components because they come in a color you like.
If you want to lower your car while still retaining drivability I would strongly suggest H&R Sport Springs coupled with some KYB AGX shocks and struts.
You can simply replace your springs out for aftermarket ones but your stock shocks and struts will be at risk of blowing pretty quickly. Keep in mind that you will want to get a full 4 wheel alignment every time you swap your suspension.
A rear sway bar will be a nice addition, but if you don't already have provisions for one it can be a little costly. That money would be much better spent on springs. Stress bars would be the absolute last suspension mods I'd suggest doing. Again, money is much better spent elsewhere.
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 04-29-2013, 11:26 AM   #4
06zx5guy
Fan#: 110644
What I Drive: 2006 sonic blue zx5
FF Reputation: 1 06zx5guy Good Standing Member
If you can do the work yourself, you should be able to get a rear subframe with a stock 20mm sway bar fairly cheap. My 06 se didn't have a bar, got the rear subframe with the bar out of a 2010 ses for about a hundred bucks from Lkq. (Pretty sure they are nationwide, not sure how close they would be where you're at) http://www.lkqonline.com/
06zx5guy is offline
Old 04-29-2013, 12:22 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,797, Level 73
Points: 12,797, Level: 73 Points: 12,797, Level: 73 Points: 12,797, Level: 73
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 99%
There are bolt on kits to add the rear sway bar, but I've seen many who had them welded later because of looseness/squeaking (shouldn't be too expensive, something to plan on though).
Reading up here for a while, to get ideas of the pro's & con's of the various setups would be worth your while. You'll get info. that will help put your catalog reading in perspective.
"SVT" level up-grade for example, does quite a bit for handling & feel while still being near stock level comfortable for a DD (as comfortable as many "stock" setups on other vehicles).
Each level of change in stiffness/lowering brings additional trade-offs, so determining what you want first, then looking at others experiences can lead you to the right combination for YOU.
Luck!
sailor is online now
