cfm tubular control arms install - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2013, 12:11 AM   #11
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Originally Posted by Blackhatch01 View Post
I cleaned up the control arms where the joint screws in. I took me an hour to clean the treads on one control arm. There was alot of powder caked up on the inside. Goes together smooth now.
Thats great, you got it going, I've never had issues w/ these arms. I've installed 3 sets before. Hey Skypilot, Whats your camber at?
felixthecat is offline
Old 04-29-2013, 12:20 PM   #12
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,910, Level 76
Points: 13,910, Level: 76 Points: 13,910, Level: 76 Points: 13,910, Level: 76
Level Up 65% Completed
Forum Activity 8%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
I honestly dont remember off the top of my head. I bought the arms to get a proper alignment not for performance. the Camber is around 0 or very slightly negative. Either way my tires have a nice and even wear now.
SkyPilot is online now
Old 04-29-2013, 03:37 PM   #13
Blackhatch01
Blackhatch01's Avatar
Fan#: 67285
What I Drive: 2001 Black ZX3
FF Reputation: 1 Blackhatch01 Good Standing Member
I luckily I have an alignment machine at my school. I need to press out sleeve on the old control arms and transfer the hub bearing to the new knuckles. This is going to be a big change since I'm putting the svt brakes on the front and st rear.
HATCH NATION #119
Blackhatch01 is offline
Old 04-29-2013, 05:42 PM   #14
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Replace the nylocks w/ 2 jam nuts & have 4.5 threads showing.
Thats great that you have access to a alignment rack. Set the rear toe first then the front. Set the rear at .010 per side & then the front at zero toe w/ the steering wheel straight. Your in school? what? 4.5 turns out for me gets 2 degrees negative camber.
Old 04-29-2013, 09:41 PM   #15
Blackhatch01
Fan#: 67285
There's a factory rear toe adjustment? The hatch is being built for autox. I probably play of the alignment each time I go to the track.
HATCH NATION #119
Old 04-30-2013, 01:32 PM   #16
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Yes. ^^^ As far as a easy rear toe adjustment, get a set of rear toe links. They make it easier. You probably found toe out on the front will help a lot.
Old 04-30-2013, 08:11 PM   #17
Blackhatch01
Fan#: 67285
How do you get the outter bushing sleeve off? Is it just the two welds?
HATCH NATION #119
Old 04-30-2013, 09:02 PM   #18
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
I used a press. Press the old bushings out.
Old 04-30-2013, 09:04 PM   #19
Blackhatch01
Fan#: 67285
So I still need the inner sleeve?
HATCH NATION #119
Old 04-30-2013, 09:32 PM   #20
rent
rent's Avatar
Fan#: 12823
What I Drive: 03' SVTF
Points 669, Level 13
Points: 669, Level: 13 Points: 669, Level: 13 Points: 669, Level: 13
Level Up 38% Completed
FF Reputation: 2 rent Good Standing Member
The arms should have come with a bushing and a new inner sleeve.
The outer sleeve is needed, but nothing else (unless you are reusing original nuts/bolts)
Sent from my HTC Sensation using FF Mobile
-James
'03 SVTF *FOR SALE*
'14 FoST Ingot Silver, bone stock...
rent is offline
