cfm tubular control arms install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-26-2013, 09:04 PM   #1
Blackhatch01
Blackhatch01's Avatar
Fan#: 67285
What I Drive: 2001 Black ZX3
FF Reputation: 1 Blackhatch01 Good Standing Member
I just received a set, and I'm not sure how the ball joint goes together?
HATCH NATION #119
Blackhatch01 is offline
Old 04-27-2013, 08:53 AM   #2
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
It's not already installed on the arm?
I now drive a Japanese Ford.
macdiesel is offline
Old 04-27-2013, 09:53 AM   #3
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,743, Level 76
Points: 13,743, Level: 76 Points: 13,743, Level: 76 Points: 13,743, Level: 76
Level Up 24% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
The helm joint screws into the arm. the pinch bolt attaches to the hub where the original ball join attached then the 2 just go into each other. Its all in the directions..
SkyPilot is offline
Old 04-27-2013, 02:23 PM   #4
Blackhatch01
Fan#: 67285
I can only get them 3/4 of the way. Vise?
HATCH NATION #119
Old 04-27-2013, 03:16 PM   #5
rent
rent's Avatar
Fan#: 12823
What I Drive: 03' SVTF
Points 669, Level 13
Points: 669, Level: 13 Points: 669, Level: 13 Points: 669, Level: 13
Level Up 38% Completed
FF Reputation: 2 rent Good Standing Member
Vise? No no no!
What are you having an issue with? Screwing the heim joint into the arm or re-assembling the lock pin & pinch bolt?
For reference, this is how they looked when I installed :
If you're having trouble screwing the heim joint into the arm, take the joint out completely and look at the threads in the arm. You don't want these cross threaded, it would be a very expensive mistake.
I found that initially assembling the arms, I had problems screwing the heim joint into the arm. After inspecting the threads, it appeared to be that when CFM had the arms powder coated, they didn't close off the opening to the threads and a lot of gunk got in there. I cleaned it out as much as I could with a dremel + wire brush and some old gun cleaning gear I had laying around. Not many issues after that.
-James
'03 SVTF *FOR SALE*
'14 FoST Ingot Silver, bone stock...
rent is offline
Old 04-27-2013, 04:29 PM   #6
Blackhatch01
Fan#: 67285
Screwing the Heim joint in, I did notice it was dirty and blew it out. I'll try using the wire brush. Thanks for the photo this definitely helps with reassurance.
HATCH NATION #119
Old 04-28-2013, 09:05 AM   #7
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 99%
Just to add, what I did was replace the nylock w/ 2 jam nuts (easier to pull a part if you need to)& I have 4.5 threads showing vs the 3 threads like they say. And for sure get the boots too.
felixthecat is offline
Old 04-28-2013, 06:57 PM   #8
Blackhatch01
Fan#: 67285
The boots are for the Heim joint? Do I need to grease the joint?
HATCH NATION #119
Old 04-28-2013, 08:49 PM   #9
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Forum Activity 16%
When I did mine and got it aligned the guy turned the joints a turn and a half out so im at 4.5 as well.
No need to grease the helm joints on the install
SkyPilot is offline
Old 04-28-2013, 09:30 PM   #10
Blackhatch01
Fan#: 67285
I cleaned up the control arms where the joint screws in. I took me an hour to clean the treads on one control arm. There was alot of powder caked up on the inside. Goes together smooth now.
HATCH NATION #119
