Projector Headlamps and hid's - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 04-25-2013, 03:46 PM   #1
Placervillebrewer
Placervillebrewer's Avatar
Fan#: 113337
What I Drive: 2003 Ford Focus Svt Zx5
Points 341, Level 6
Points: 341, Level: 6 Points: 341, Level: 6 Points: 341, Level: 6
Level Up 82% Completed
FF Reputation: 1 Placervillebrewer Good Standing Member
Hello fellow fanatics,
So I'm new to owning my Focus Svt and the previous owner had projector headlights but unfortunately the sun had baked them to where they had tiny cracks all through the lenses. So I used eBay to find some new ones and they have new standard bulbs, but I have tons of deer out by me and an hid would be the preferred light. Has anyone done the hid conversion with aftermarket projector lights? Any red flags to look for or advice would be helpful.
With So many gears its hard to pick a favorite!
Placervillebrewer is offline
Old 04-25-2013, 04:05 PM   #2
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
ebay projector headlights are not hid ready. either retrofit stock halogen headlights with a kit from theretrofitsource.com, or find a pair of hella mach or dynabeam headlights (about 500). hids in those projectors or reflector bowls is terrible. I highly recommend a morimoto mini h1 retrofit. 270 for everything you will need. bake the headlights open, mount the projector, tighten the bolt, put on the shroud, reseal and go with the cheapest and best setup available aftermarket
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 04-25-2013, 04:16 PM   #3
calebstubstad
Chef Boyardee
Fan#: 103240
this kit will literally bolt right in to a pair of stock reflector bowl headlights, with zero modification. someone new to it could do it in a few hours. there are also TRS videos on youtube about how to do it. that kit has everything you need from bulbs, ballasts, to the projector, shroud, everything. all you need is an oven to bake the headlights open
http://www.theretrofitsource.com/pro...roducts_id=227
[HOONIGAN]
Old 04-25-2013, 04:59 PM   #4
Placervillebrewer
Fan#: 113337
Points 341, Level 6
Sweet thank you for the information very much, I will look into buying that kit.
Old 04-26-2013, 01:07 AM   #5
calebstubstad
Chef Boyardee
Fan#: 103240
If you have any questions, email them, and go onto the hidplanet.com forums. Matt @ TRS is on there almost always with answers, and the morimoto mini h1 is a favorite. the version 6 just released, and this is the pics of the light throw/cutoff
I can also answer some questions, as I was like 99% sure I was going to do this, then I got an amazing deal on the Mach hid's.
keep us posted on what you do!
also, here's a pic of a retro'd focus
how-to over on FJ (very good write up)
http://forums.focaljet.com/mk-i-exte...storation.html
[HOONIGAN]
Old 05-15-2013, 12:24 AM   #6
Placervillebrewer
Fan#: 113337
Points 341, Level 6
Hids once again
Does the kit you suggest have the high beam also, how does that work?
Old 05-15-2013, 12:53 AM   #7
Placervillebrewer
Fan#: 113337
Points 341, Level 6
Feeling Slightly Retarded But Justified.
So I really liked the appearance of the projectors in my avatar picture but even after extensive cutting and polishing the sun cracks were still there, I ordered a killer looking set of standard halogen style reflector headlamps and used them for a whole week when I decided crap these look fine but really are not what I had my heart set on.
With a little research I found a nice looking set of projector headlamps complete, And the existing kit was indeed not HID so now the search continues. I really appreciate the info on baking the housing open but I worry about getting a good seal and prefer the look of the ones I purchased. It does appear the H1 size will fit the low beam projector side, Next I will try and find a high beam to incorporate. Thanks all for reading this and your patience, take care
Sincerely, Jeff
Old 05-15-2013, 12:56 AM   #8
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
Points 2,818, Level 32
Points: 2,818, Level: 32 Points: 2,818, Level: 32 Points: 2,818, Level: 32
Level Up 46% Completed
FF Reputation: 4 jinstall Good Standing Member
If you crack open the lights to do a retro fit kit you might as well reuse the originial lights that came with the car.
2001 Focus ZX3-Ours IMPOUNDED BY CUSTOMS!!
2010 Renault Clio 1.2 16V in Germany-Hers FOR SALE
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is offline
Old 05-15-2013, 01:10 AM   #9
Placervillebrewer
Fan#: 113337
Points 341, Level 6
The quick look
Here's a quick look at the headlights I installed the prior pictures are the high beam and hid side by side I believe with a little work it will all jive very nicely.
