Question about bumper insert replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2013, 04:19 PM   #1
hoss27055
Fan#: 113937
What I Drive: 2010 silver Ford Focus
FF Reputation: 1 hoss27055 Good Standing Member
I am sorry if this is asked somewhere else before but since I dont know the name of the part I was not able to find anything. I have a 2010 Focus SE. Across the bumper is 4 small looking grill inserts. My wife was driving this morning and hit an animal. Luckly the bumper is fine but one of the inserts was busted. I noticed it is one peice. My question is how do you change that out? Does it just slid out from the front or rear? Do you have to take the bumper cover off? Because we work diffrent shifts I was not able to look at it too long. I found the forums here and hoped someone had to replace it before. Thank you for any help or advice on this.
hoss27055 is offline
Old 04-25-2013, 12:38 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,863, Level 74
Points: 12,863, Level: 74 Points: 12,863, Level: 74 Points: 12,863, Level: 74
Level Up 4% Completed
Forum Activity 99%
Moved.
sailor is offline
Old 04-25-2013, 01:22 PM   #3
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 14 mac.mogul Great Standing Member
The lower grille is one piece. Is that what broke?
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 04-25-2013, 01:36 PM   #4
hoss27055
Fan#: 113937
That is correct. It appears as 3 peices across the bottom but I know it is one peice. I am not sure if I have to take just the bumper cover off or the entier bumper.
Old 04-25-2013, 01:41 PM   #5
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Forum Activity 9%
I think you can replace it without removing the bumper, you'll just need to remove the bottom air dam to reach it.
I would recommend ordering the part from TousleyFordParts.com and hopefully someone with an SE bumper can chime in. I assume it is the same process as the SES bumper.
Old 04-26-2013, 11:15 AM   #6
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
I believe you are talking about this piece right hrrrrrr
front by DarderSauce, on Flickr
That is all one piece held into the bumper with little clips. Like mac said, take off the bottom air dam (directly under the bumper) and you should be able to pop it out one side at a time. You can get it pretty cheap, here is the first one I came across on eBay but again, like Mac said, Tousley Ford probably has it cheaper than anywhere you can get it online.
http://www.ebay.com/itm/New-Bumper-G...ht_1451wt_1129
Hope that helped.
If you can't wear it out, burn it off
DarderSauce is offline
Old 05-27-2013, 07:11 PM   #7
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
What are the possibilities of anything bad happening, if say, I just wanted to remove the lower grille for the sake of just having something different, i.e. an open front?
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 07-31-2014, 05:51 PM   #8
JLokiG
Fan#: 172937
What I Drive: 2009 Silver Focus SE
Points 583, Level 11
Points: 583, Level: 11 Points: 583, Level: 11 Points: 583, Level: 11
Level Up 66% Completed
FF Reputation: 1 JLokiG Good Standing Member
Looking for an answer to this question!
JLokiG is offline
Old 07-31-2014, 06:22 PM   #9
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
piece of retread </3
badazz2010focus is offline
Old 08-02-2014, 10:47 PM   #10
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,032, Level 45
Points: 5,032, Level: 45 Points: 5,032, Level: 45 Points: 5,032, Level: 45
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 13%
FF Reputation: 6 SlickWilly Good Standing Member
Is your name Lance ?
K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - N2O
SlickWilly is offline
