a long read but great info on capacitors - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2013, 04:13 PM   #1
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
Points 4,255, Level 41
Points: 4,255, Level: 41 Points: 4,255, Level: 41 Points: 4,255, Level: 41
Level Up 53% Completed
Forum Activity 3%
FF Reputation: 6 alaskanzx5 Good Standing Member
tons of info from a lot of people in the car audio world. including someone that is one of the most knowledgeable people on car electronics. some real world testing with caps. the last 3-4 pages have the videos for the testing and the results of the testing. enjoy
http://www.stevemeadedesigns.com/boa...-story/page-12
hn155: Rockford punch pro speakers, t400.4 deh 80prs, full audio build to come. working towards 175hp n/a, simple but fun.
alaskanzx5 is offline
Old 04-25-2013, 06:10 AM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
I am a believer that caps are a band-aid for a larger issue.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 04-25-2013, 09:43 AM   #3
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 509, Level 10
Points: 509, Level: 10 Points: 509, Level: 10 Points: 509, Level: 10
Level Up 18% Completed
FF Reputation: 1 asting Good Standing Member
So am I. Get a bigger alternator if you're having issues or downsize.
2012 SE Hatch - 5 Speed - Tuxedo Black
Engine: K&N Typhoon CAI, Magnaflow 2.25 exhaust 15072
Suspension: MS3 Springs, Focus electric RMM.
Audio: LC6i, Polk Audio db6501 front, db651s rear, db1040DVC sub, Rockford R600-5 Prime, Fatmat
asting is offline
Old 04-25-2013, 12:55 PM   #4
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
a good electrical for any high output stereo starts with the alt and grounds. improve your grounds and get a nice sized alt ( as big as you can that is known to do good not ebay junk). then improving the power wire from alt to batt and batt to amp. if your pulling more then your alt can put out then your dropping down to battery voltage (12.6-12.7). add in enough high grade caps ( not cheap junk) and the caps will charge at the highest available voltage (alt, 14.4-14.8). the amp will then draw from the highest voltage with the least resistance. meaning the cap ( 18" or less from the amp). then the alt and then the batts. a good stout electrical wont drop below 13v, but adding in some caps could gain about 1v if done right. meaning more power to the amps from a closer source.
before I left ak I had a 1500.1bdcp, stock alt, simple interstate batt under the hood, interstate rv batt for extra storage, big 3, and a 10 farad Rockford cap. with out the cap installed my voltage was dropping to about 11volts ( song dependent ). music sounded good bass was deep. installed the cap and I wouldn't drop below 12 volts and the music was louder, cleaner and sounded deeper. the amp was getting a higher voltage and so was performing better. I also had a 250 amp alt that I installed and wouldn't drop below 13volts and that too gave me the same increase that the the added cap did.
conclusion, the higher the voltage you give your amp the better it performs. caps and alt sit at a higher voltage then batts, that is the benefit. it can cost more and if not done right will only be putting a band aid on the issue yes. but correctly done and will see a gain.
Old 04-25-2013, 04:39 PM   #5
asting
Fan#: 98342
It has more to do with the rate at which you listen to music. If you want to blast music every half hour on a long drive, then yes a cap would work. But you need time to charge the cap later. It doesn't really increase the total output of your system over a period of time unless you have periodic breaks to let it charge and take advantage of the full output of your alternator.
asting is offline
Old 04-25-2013, 05:35 PM   #6
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 49%
Many things come into play in this subject. Like when I ran my old Xtant 3300x, I had no issues with current because that amp is a tank with lots of on-board capacitance. I never should have sold it.
When do you do most of your listening? Key on or, key off? That makes a diffidence between using a big Alt or extra batteries.
Caps can work of course but, IMO that is because of small on-board capacitance, too much wiring resistance, insufficient ground and the like.
Hatch Nation #140
freemind is offline
Old 04-25-2013, 05:36 PM   #7
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
And that is why its install dependent. Im not wanting any aurguing just trying to bring more info with some real world testing to people that would like to know more.
Old 04-25-2013, 05:39 PM   #8
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 49%
No worries man. This has been a debated subject for the last 20 or so years. I appreciate you bringing this to the site. It is good info and I am sure it is useful.
I would add the Rep point but it will not let me.
Hatch Nation #140
freemind is offline
Old 04-25-2013, 05:47 PM   #9
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
All the real world testing that can be done the better. And the easier for people to find the info the better.
A good electrical should always have a big enough alt (or the biggest that wil fit), a batt bank, cap(s) and of course some really well planned and upgraded wiring. If there is a chance something can increase your electrical I say try it.
I personally believe that a good electrical can benefit from a an added cap or 2. Just because it allows your amps to draw its power from a closer source.
Old 04-25-2013, 05:51 PM   #10
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
Forum Activity 3%
FF Reputation: 17 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
The only reason I have one is because I won it. I have it and a small extra battery, I couldn't tell you which one is more effective.
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
