Found a rat's nest in my car - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2013, 12:57 PM   #1
jtrain
Fan#: 97289
What I Drive: 2012 Black Focus
FF Reputation: 1 jtrain Good Standing Member
I cleaned my car on the weekend after a long winter and the last step was to check my fluid levels and oil. I probably haven't done this since November. I know, my bad. So I pop my hood and there is a rat's nest sitting on the engine It was a bit of straw, mostly foam insulation, and a ton of rat droppings. This makes sense because during the winter I would notice my fans sometimes had a bit of a dank/burning smell and I park outside near a garbage can. Now I know it was burning foam and rat smell. So I proceed to pull the nest out, vacuum the droppings, and carefully spray out what I could not get with the vacuum. I did a visual check and thankfully it looks like all the wires are intact.
On the drive to work today I noticed the smell was still there though. I tried to air it out and I turned my fans up to the max speed. On the top 3 fan speeds, there is a pretty loud whistling noise. Does anyone have an idea what's causing that? And any suggestions on how to get rid of rat smell?
jtrain is offline
Old 04-24-2013, 01:05 PM   #2
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,076, Level 34
Points: 3,076, Level: 34 Points: 3,076, Level: 34 Points: 3,076, Level: 34
Level Up 18% Completed
Forum Activity 4%
FF Reputation: 15 PratoN Great Standing Member
Happens to me when my dash vents are closed or very close to being closed. Try wiggling them around? (including the passenger's side)
PratoN is online now
Old 04-24-2013, 01:06 PM   #3
Ethie1990
Fan#: 113894
What I Drive: 2007 silver st
FF Reputation: 1 Ethie1990 Good Standing Member
there might be rat crap in the air ducts going to your blower motor if i were you i would locate the ducts usually under the fascia of the wipers and try and blow air through there if all else fails get an air freshener.
Ethie1990 is offline
Old 04-24-2013, 01:07 PM   #4
nseah
Fan#: 101824
What I Drive: 2012 Sterling Grey Ford Focus SEL
FF Reputation: 1 nseah Good Standing Member
This is actually a pretty common issue. On my work truck There's rat's nests everywhere. Last winter there was one in the radiator grille, which caused my engine to overheat all the time. Next was in my exhaust pipe. Gotta be careful of these guys
-Nate
2012 Sterling Grey Ford Focus SEL Hatchback
nseah is offline
Old 04-24-2013, 01:48 PM   #5
skiboarder119
Fan#: 98455
What I Drive: 2012 black TI 5spd
Points 373, Level 7
Points: 373, Level: 7 Points: 373, Level: 7 Points: 373, Level: 7
Level Up 46% Completed
FF Reputation: 1 skiboarder119 Good Standing Member
I also thought I had a rat/mouse nest. Checked my fluids the other day and there was a ton of small leaves and grass all around my coil packs - it looked more like 3 nests (between the 4 coil packs). I dug through it looking for poop, found nothing.
I'm wondering if maybe it wasn't a mouse and crap just accumulates there? I have no engine cover.
skiboarder119 is offline
Old 04-24-2013, 01:56 PM   #6
jtrain
Fan#: 97289
I wish it wasn't a mouse. But I had TONS of rat droppings and some of the insulation was chewed. From what I could see, they had a bit of the insulation on the underside of the hood and some other foam thing. None of the wires look chewed though.
And correct me if I'm wrong but the air ducts are literally right under the wipers. The first time I saw that on a car I thought they were speakers lol. Those are clean so I'll probably have to just get an air freshener.
jtrain is offline
Old 04-25-2013, 07:30 AM   #7
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 4,354, Level 42
Points: 4,354, Level: 42 Points: 4,354, Level: 42 Points: 4,354, Level: 42
Level Up 2% Completed
Forum Activity 2%
FF Reputation: 1 raptor1956 Good Standing Member
You gotta be careful with rat dropping as it can carry the Hantavirus and that's kind of like the plague -- not good. Be sure to clean everything and disinfect. I don't know how it could get into the duct-work but that could be real bad.
Brian
2012 FF Ti HB Sonic Blue, Built 5/7/12, 401A + Parking Technology Package and MFT w/NAV 3.0.2 -> 3.2.2 -> 3.5.1 -> 3.6.2
raptor1956 is offline
Old 04-25-2013, 07:39 AM   #8
2008 Ford Focus
Fan#: 91826
What I Drive: 2008 Focus SES 5 speed
Points 454, Level 9
Points: 454, Level: 9 Points: 454, Level: 9 Points: 454, Level: 9
Level Up 8% Completed
FF Reputation: 0 2008 Ford Focus Newbie
Could it be the rats whistling along with your tunes?
2008 Ford Focus is offline
Old 04-25-2013, 09:42 AM   #9
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 509, Level 10
Points: 509, Level: 10 Points: 509, Level: 10 Points: 509, Level: 10
FF Reputation: 1 asting Good Standing Member
If you haven't done so already, I'd clean out your engine bay. Start by pulling off the cover under the engine bay. Then cover the alternator, battery, air intake, fuses with a bag. The battery and fuses have a quasi cover, and the stock air intake is probably pretty well protected too. With a hose on shower spray down the entire engine bay. Then spray it down with a foamy application of your degreaser of choice. Let it soak 2-3 minutes and scrub any problem areas. Rinse the engine down, drying it by hand if you want to avoid water spots and then remove the bags and put your stock skid plate/engine cover back.
It should take you half an hour or so, and if it's stuff in the engine (perhaps rat crap burning on a warmed up engine) this will take care of it.
2012 SE Hatch - 5 Speed - Tuxedo Black
Engine: K&N Typhoon CAI, Magnaflow 2.25 exhaust 15072
Suspension: MS3 Springs, Focus electric RMM.
Audio: LC6i, Polk Audio db6501 front, db651s rear, db1040DVC sub, Rockford R600-5 Prime, Fatmat
asting is offline
Old 04-25-2013, 11:58 AM   #10
jtrain
Fan#: 97289
I cleaned my engine bay for the most part. I didn't know how to remove the cover underneath so I skipped that step. I sprayed it down, applied the motorcraft engine shampoo, scrubbed it down, and then rinsed clean.
What's annoying though is that I checked it this morning and there were a couple new droppings. I need to find a new place to park.
jtrain is offline
