Rally Racer needs 2.3L / 2.5L Help - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 05-17-2013, 05:45 PM   #71
MainiaxMotorsports
Fan#: 84528
What I Drive: 2002 Rally-Spec SVT w/ 2.5L swap
Points 1,049, Level 17
Points: 1,049, Level: 17 Points: 1,049, Level: 17 Points: 1,049, Level: 17
Level Up 49% Completed
FF Reputation: 2 MainiaxMotorsports Good Standing Member
Originally Posted by waraya View Post
Now I kick myself for not figuring out the pictures earlier. See attached.
Thanks Man - this should be a helpful thread to others doing HEAD / Motor Swaps -
I am sooo pissed i broke a bolt - i know better than to re-use head bolts - but NOOOOOO - i wanted to keep moving -----stupid me
MainiaxMotorsports is offline
Old 05-17-2013, 10:12 PM   #72
MainiaxMotorsports
Fan#: 84528
Compression Ratio Time
Ok, so, sitting on my hands waiting for my new head bolts to show up on the morning - EZ Out the broken Bolt - and thought i would do some math (or find a compression Ratio Calculator) and figure out the specs of "Frankenstein" - my pet name for this swap/build
Can someone check my math on the specs - again 2.5L Stock Block/Pistons/Rings with 89 x 100 Bore and Stroke - and a Stock 2.3L Head (with port work done, but for sake of calculations)
Combustion Ratio - calculated - +- 11.03:1 not too shabby - but right???
Old 05-17-2013, 10:51 PM   #73
MainiaxMotorsports
Fan#: 84528
And also curious if anyone on this board has done the TB Port mod - taking the stock TB up from 63mm to 65mm? Not sure i am going to mess with the butterfly plate as i suspect the edges are fabricated to meet the TB bore as designed - vs just flat - and that is too much work - so - thinking about increasing the bore but tapering it near the flap - that tapering should also speed flow velocity even through the final bore at the site of the flap will be stock
Old 05-19-2013, 05:17 PM   #74
MainiaxMotorsports
Fan#: 84528
Home Stretch - almost
Ok, so, first tackled the broken head bolt, and picked up my new head bolts so that does not happen again :) - got them all torqued....and put to bed.
Surgery - the patient is ready Doctor !!
OUT !
Another Tip i figured out - that freaking CHAIN TENSIONER - you can only move the safety guide when the piston is pressed in - so - ZIP TIE to the rescue (c/clamp kept slipping off) - i should be nice - bad things happen when timing chains go boom
OK - anyone have tips on how to best put the crank bolt back in without moving anything....i have the flywheel hub locked up - Pistons at TDC - and the cams are perfect - but man would be sooooo meach easier if FORD keyed the crank on the pully side - i was tired so decided that is for any breaks i get tomorrow
Starting to look like a race motor.
Tomorrow -Crank Bolt - Valve Cover - FlyWHeel - Clutch - Bolt back up the Tranny - go over every thing again 10 times - then decide whether we are ready to press her back into the car
Old 05-19-2013, 06:04 PM   #75
waraya
Fan#: 114416
What I Drive: 2003 Ford Focus SVT (black)
Points 189, Level 3
Points: 189, Level: 3 Points: 189, Level: 3 Points: 189, Level: 3
Level Up 78% Completed
FF Reputation: 1 waraya Good Standing Member
Looking good!!! To hold that crank in place you can probably take about a 24 inch piece of metal something similar to a "metal ruler" and drill holes for the flywheel bolts (2) and then drill holes for the transmission bolts (one on each side). Just a thought.
Walt
waraya is offline
Old 05-19-2013, 07:55 PM   #76
MainiaxMotorsports
Fan#: 84528
THanks Walt
So....
1. I know i have the cams locked via the flat plate. Cam position is right
2. I think i have the crank locked, i KNOW i have it TDC
3. I hope the crank pulley stays put via that small 6mm bolt - if you recall i broke part of the timing cover where it threads in loosening the crank bolt - luckily - righty tighty -
I am going to ford in the morning to get a new crank bolt - after my head bolt fiasco i am going new vs. re-use
Might also get the crank lock service tool if they will let me borrow it
Old 05-19-2013, 08:03 PM   #77
MainiaxMotorsports
Fan#: 84528
Hey - did some more work with the GOOGLE BUTTON and VOILA
http://www.enginebuildermag.com/Arti...ft_pulley.aspx
check out Crankshaft Timing Peg p/n 303-507 lock the crank !!!
Also - its a ranger 2.3L tech page - but this is one of the best tightening sequence and torque setting pages i have seen for the 2.3L Duratec
http://www.fordrangerforum.com/4-cyl...fications.html
And a video on Cam Timing http://www.youtube.com/watch?v=IL5P7wEIymM
Old 05-19-2013, 09:10 PM   #78
waraya
Fan#: 114416
Points 189, Level 3
might as well get the set http://www.amazon.com/OTC-6486-Tool-.../dp/B000RF9YA0
waraya is offline
Old 05-20-2013, 11:09 AM   #79
MainiaxMotorsports
Fan#: 84528
agreed - went out and bought this this morning
http://massivespeedsystem.com/_massi.../i-273565.aspx
few days of downtime - and with this - cna go ahead and bolt up the tranny!! (and clean the shop)
Old 05-20-2013, 03:58 PM   #80
MainiaxMotorsports
Fan#: 84528
Final Stretch....
So as stated, went ahead and got the TDC Timing Peg from Massive, and while i have a cam blade will go ahead and use the one they ship in the $35 kit - what a deal. Since we dont need to hold TDC from the flywheel side when we torque down the new crank pulley bolt - bolted up the tranny !
Now - you might ask - what - how are you going to LIFT that back into the car?
Well, we are not - i am gonna lift the nose of the car up again, and then the dolly lets me wheel her right under - motor tranny and all. We have two lifts in the shop here but didnt need them once.
Fingers crossed the new crank bolt and TDC Kit come in tomorrow - then she can get tucked back in.
OH, never actually checked out teh block when i bought the donor - so, brought a smile to my face when i came across this today....
