Rally Racer needs 2.3L / 2.5L Help - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 04-24-2013, 12:42 PM   #11
MainiaxMotorsports
Fan#: 84528
What I Drive: 2002 Rally-Spec SVT w/ 2.5L swap
Points 1,049, Level 17
Points: 1,049, Level: 17 Points: 1,049, Level: 17 Points: 1,049, Level: 17
Level Up 49% Completed
FF Reputation: 2 MainiaxMotorsports Good Standing Member
Quick Notes:
1. Battery has been moved to the back of the car
2. you will see a voltage regulator under the hood on the right - that was to trouble shoot an electric gremlin we finally tracked down - just left it in- lazy ;)
3. stock plenum, but REALLY would like to get the Cosworth style for flow - know the 2.5L inlets are larger - we shall see if that mates up
4. Tune will be critical (but i know a guy ;)
5. you will also see an aluminum braille battery box unit we had built - under the motor mount bolt - cosmetic at this point
6. Run HotBits suspension with 250 lbs springs for gravel, and 450lbs springs all around for tarmac - sways on tarmac, rear sway disco'd for gravel
7. Someone asked - i ran Advan A048 tires in a 225/50/16 config for the Tarmac Rally - however, should have run proper tarmac tires for another edge - lesson learned
MainiaxMotorsports is offline
Old 04-24-2013, 01:30 PM   #12
Fernando_221
Fan#: 79468
What I Drive: '06 ZX4 2.0L Dtec, '11 MK2.5 2.0L
Points 1,806, Level 25
Points: 1,806, Level: 25 Points: 1,806, Level: 25 Points: 1,806, Level: 25
Level Up 6% Completed
FF Reputation: 3 Fernando_221 Good Standing Member
Originally Posted by 1turbofocus View Post
Actually the VCT doesnt work off 12 volts and never hits 12 volts it like most VCT works off of variable voltage off load vs RPM
If this isnt hooked up properly or a VCT Elim then he is loosing some TQ and HP
Humm I was suspecting about that, the VCT solenoid works with a voltage curv.
Fernando_221 is offline
Old 04-24-2013, 01:32 PM   #13
Fernando_221
Fan#: 79468
Originally Posted by MainiaxMotorsports View Post
Ok, thanks to the ninjas on this forum - i am going for it. Here is what we are doing.
1. I have a 2002 Focus SVT Rally car - that started life as a production class vehicle in Rally America, USRC, and NASA
2. We then did a Zetec (out) for a 2.3L Duratec (IN) swap - the car is now Open 2wd Heavy and Group 2 depending on the sanctioning body. Runs the MTX75 Tranny. She runs great, is "competitive", but is not fast and requires a LOT of rev management to stay in the power band, and torque is really not there to dig out of corners on either tarmac, track, or gravel (insert also ice/now) stages.
3. I just bought a 2.5L Duratec i4 out of a 2010 Ford Fusion !!!!!
Let the Build begin......will be documenting each step on this thread for others to follow - including all HIGH FIVES, and OH SHIT moments....enjoy.
The Car with 2.3L Duratec
The Engine Bay with current 2.3L Duratec Setup
The Bell Housing w MTX75
[pic pending]
The Dash Cluster w Custom Wire Harness Circuit Breakers
The Car on Stage moving right along ;)
NEXT POST:
The new (pulled) 2.5L I4 Duratec from a 2010 Fusion Arrives
[pic]
If you use the 2.5l from 2010 Fusion, you'll have to cut the front cover (timing cover) near the PS pump OR use the 2.3 front cover.
When you put the stock Focus PS pump, the belt will not fit, it hits the 2.5 timing cover. You have to modify the cover or use the 2.3 cover.
If you cut the 2.5 cover, you have to weld some plate inside.
We have to do this on the 2.5 Focus swap. Better thing is to use the Focus 2.3 cover.
Old 04-24-2013, 02:33 PM   #14
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,834, Level 100
Points: 51,834, Level: 100 Points: 51,834, Level: 100 Points: 51,834, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
Basically yes , It gets its info for the curve mostly from Load and RPM but many other things come into play as well , need to get VCT Elim for the 2.5 , something I will have out soon
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-24-2013, 03:10 PM   #15
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,207, Level 98
Points: 28,207, Level: 98 Points: 28,207, Level: 98 Points: 28,207, Level: 98
Level Up 86% Completed
Forum Activity 3%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
figures I sell my car the year before people get serious about 2.5 swaps
this is great. looking forward to more pics as this progresses!
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 04-24-2013, 04:28 PM   #16
MattDzx3
MattDzx3's Avatar
Fan#: 99676
What I Drive: 2002 Red ZX3
FF Reputation: 2 MattDzx3 Good Standing Member
Subscribed! Good luck with the swap
SVT header, SVT cat-back, H&R Cup Kit
Rally Revolution #78, NW Posse #44
Originally Posted by brekkebooboo View Post
One does not simply "unstance" Their car
MattDzx3 is offline
Old 04-24-2013, 09:01 PM   #17
MainiaxMotorsports
Fan#: 84528
PLENUM for 2.5L Build
So, one of the ideas i wanted to make sure i addressed was the ability to goto a Cosworth Style plenum vs. stock intake. So, i reached out to a manufacturer, and searched the web.
1. Here is a pic of the 2.3L Head inlets i found on another forum
2. here is a pic of the 2.5L Head inlets below it (credit goes to the other forum poster)
3. The manufacturer says the bolts will line up, however, to get full advantage of the airflow capabilities of the plenum - a bit of machining can be used to open up the inlets on the plenum side
Here is a pic of the inlet side of the plenum style i will go with - my thought is to machine out some of that metal to insure it is matching the head side inlets in diameter.This way my TUNER has more air to work with.
Engine is supposed to be delivered friday !!!
Old 04-24-2013, 10:23 PM   #18
reillydog
Fan#: 62231
What I Drive: 97 Cosworth Escort WRC & 2005 ZX3
FF Reputation: 1 reillydog Good Standing Member
Yea baby! Good luck Ty
Can't wait to see how this turns out.
reillydog is offline
Old 04-25-2013, 03:02 PM   #19
MainiaxMotorsports
Fan#: 84528
while i wait for new motor - why not FLOCK THE DASH
So, i am a wicked cheap but i have always wanted to Flock my Dash in the Rally Car (aka Lil Red) to cut down on the glare of the stock focus finish (see pics)
So, i looked online at all the Flocking kits, services, etc. Too much.
I went to the local JoAnn Fabric store, and bought .666 yards (72" x 24") of black FELT FABRIC
$7
I bought some loctite professional grade spray adhesive
$13
I then bought an Xacto knife
$4
TOTAL PARTS $ 24
I popped out the air vents
I sprayed on the glue
i layed the felt out over the dash
wearing rubber gloves i smoothed it all out when tacky
i then trimmed all the edges
I dont know about you...but it looks BEAUTIFUL !!!!
BEFORE
AFTER
Took 30 minutes and $24
Old 04-25-2013, 08:50 PM   #20
MainiaxMotorsports
Fan#: 84528
And out she comes ......
Had a little spare time this afternoon between conference calls - so started the 2.3L dis-assembly. And before i get flamed - YES, i know some of this could have stayed on the block as the new motor will have it - however, i may try to re-use some components (NOT THAT CHEAP PLASTIC INTAKE PLENUM - omg - what a pig - totally convinced the Cosworth Style Plenum is the only way to go......)
[IMG][/IMG]
