Tires Seized - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-23-2013, 05:07 AM   #1
dutd33
Fan#: 104381
What I Drive: 2012 White Platinum SEL Hatch
Points 1,977, Level 26
Points: 1,977, Level: 26 Points: 1,977, Level: 26 Points: 1,977, Level: 26
Level Up 77% Completed
FF Reputation: 1 dutd33 Good Standing Member
Tires Seized
Hi All,
Since it was sunny today I decided to remove my winter tires and go back to the all seasons. However, after loosening the lug nuts and jacking up the car, I noticed that the tire has seized! Has anyone had this happen to them and also what methods are good to remove them?
On a side note, I just want to say I really like this car because it actually has arrows which show where the jacking points are on the car. Not bad, Ford, not bad!
dutd33 is offline
Old 04-23-2013, 07:12 AM   #2
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 592, Level 11
Points: 592, Level: 11 Points: 592, Level: 11 Points: 592, Level: 11
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
Yes I have heard of this happening before on other cars. Alittle anti-seize on the mating surface in the future could help.
I peice of wood and a sleg hammer might pop the wheel off. I have heard of other loosening the lug nuts and then driving a few feet to pop the wheel free.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
Old 04-23-2013, 07:47 AM   #3
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,707, Level 94
Points: 23,707, Level: 94 Points: 23,707, Level: 94 Points: 23,707, Level: 94
Level Up 36% Completed
Forum Activity 13%
Yeah it happens quite often. it's called galvanic corrosion and occurs when two dissimilar metals are set together for awhile.
I'd try everything else before driving a few feet on it, but it does work. I just pulled the wheels on my focus after it sat for about three years. Took a couple karate kicks but I got it. Normally a dead blow hammer to the inside rim of the wheel will pop it loose though.
mikebontoft is online now
Old 04-23-2013, 08:27 AM   #4
Superd
Superd's Avatar
Fan#: 87917
What I Drive: '12 candy red titanium hatch
FF Reputation: 1 Superd Good Standing Member
I've gotten them unstuck by loosening the nuts so there is just 1/2 a turn clearance between the nut and wheel then move the car slowly just a few feet and stamp on the brakes.
Like mentioned,anti seize allows easy rim removal next time around.
Superd is offline
Old 04-23-2013, 08:43 AM   #5
focusstu
Fan#: 103157
What I Drive: 2012 Oxford White Focus S 5MT
Points 533, Level 10
Points: 533, Level: 10 Points: 533, Level: 10 Points: 533, Level: 10
Level Up 66% Completed
FF Reputation: 2 focusstu Good Standing Member
Wheels seizing is a common problem on the Mazda3. I used a piece of 2x4 and a hammer to get them off. I remedied the problem with a light coat of lithium grease on the flat surface of the hubs. Just make sure you don't get any on the studs.
focusstu is offline
Old 04-23-2013, 11:33 AM   #6
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,412, Level 29
Points: 2,412, Level: 29 Points: 2,412, Level: 29 Points: 2,412, Level: 29
Level Up 75% Completed
Forum Activity 8%
FF Reputation: 13 BetaDnB Great Standing Member
If the wheel is up in the air, turn your back toward the car and give the bottom of the tire a good heel kick on the sidewall.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 04-23-2013, 11:39 AM   #7
redwake
redwake's Avatar
Fan#: 100718
What I Drive: 00 Black ZTS
Points 967, Level 16
Points: 967, Level: 16 Points: 967, Level: 16 Points: 967, Level: 16
Level Up 67% Completed
FF Reputation: 3 redwake Good Standing Member
bfh
gigity
MK1 ZTS w/Lentec ATX - More economical than a Prius
2" drop - projectors - boost by vortech - tune by fswerks
My Car: http://tinyurl.com/8mpden8
Sr# 256.
redwake is offline
Old 04-23-2013, 03:54 PM   #8
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
rubber mallet, and hit it from the back of the wheel (please be very careful and make sure it's very securely jacked.)
A trick I learned from a fellow member, Geezer, is to wipe a very thin layer of motor oil on the back of the hub. Anti-seize works too I guess, but I usually have motor oil more readily available.
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 04-23-2013, 04:21 PM   #9
MetalMuffins
MetalMuffins's Avatar
Fan#: 107135
What I Drive: 2013 Tuxedo Black Focus SE Hatch
Points 548, Level 10
Points: 548, Level: 10 Points: 548, Level: 10 Points: 548, Level: 10
Level Up 96% Completed
FF Reputation: 3 MetalMuffins Good Standing Member
I'll chime in. I did this last weekend, and had the same issue. The fronts I ended up loosening the lugs a few turns and rocking the top of the tire back and forth using the rocking weight of the car. To get the rears off, I had to loosen the lugs and roll the car in the driveway, than lock the e-brake. just be careful that you don't loosen the lugs too much.
2013 HB MTX, Tux Black w/ Black Pack - Steeda RSB, Snorkel DLT, K&N Drop in, E-Focus RMM, Redline Tuning Hood Struts, Custom Al. Skid-plate, 180 Stat, Custom SCT Tune by Tom @ Focus-Power
MetalMuffins is online now
Old 04-28-2013, 07:32 PM   #10
dutd33
Fan#: 104381
I took a mallet to the steelie and hit at different angles and they finally came off! Thanks everyone for the responses! :)
dutd33 is offline
