Do i need seat brackets - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 04-22-2013, 11:53 AM   #1
jugglethese
jugglethese's Avatar
Fan#: 108852
What I Drive: 2007 focus gloss black SAP zx3
Points 1,619, Level 23
Points: 1,619, Level: 23 Points: 1,619, Level: 23 Points: 1,619, Level: 23
Level Up 19% Completed
FF Reputation: 1 jugglethese Good Standing Member
i came across what i think is a good deal. i might be a knock off sparco seat. he wants 300$ for 2 seats. is there a way to mount them to my stock seat brackets? seat brackets are very expensive, unless someone knows of somewhere i can get them cheaper than 150$ each. he selling them with honda civic seat brackets but i doubt that it will fit on the focus?
jugglethese is offline
Old 04-22-2013, 01:50 PM   #2
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 27,921, Level 98
Points: 27,921, Level: 98 Points: 27,921, Level: 98 Points: 27,921, Level: 98
Level Up 58% Completed
Forum Activity 2%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
corbeau sells some nice brackets that are a perfect fit for 99/each. or weld up your own if you can
youll also need to do something about the airbag sensors (if you have side airbags) and the pressure bladder in the passenger seat
finally, I dont know if Id trust a knockoff seat in an accident.
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 04-22-2013, 01:54 PM   #3
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Points 9,889, Level 66
Points: 9,889, Level: 66 Points: 9,889, Level: 66 Points: 9,889, Level: 66
Level Up 60% Completed
Forum Activity 99%
FF Reputation: 70 sailor Excellent Standing Member
How are your fabrication skills?
Have a friend who can cut & weld?
It's likely that the Honda brackets COULD be modified to fit, just remember that it can't be a "half bleeped" job, since your proverbial "butt" depends on it!
One Yo Yo hitting you in the back & YOU end up in the back seat if the brackets don't hold, so it's something that has to be done right...
NOT to deter you, it's probably worth the effort to get seats you like!
Cheers!
sailor is offline
Old 04-22-2013, 04:25 PM   #4
jugglethese
Fan#: 108852
all i got to do is cut the wires from the bladder? my driver seat is broken, its got a lean to the right pretty bad. so it would probably break even if i got hit.
Old 04-22-2013, 04:29 PM   #5
jugglethese
Fan#: 108852
Cheers!
there pretty nice for the price. ive been looking online for seats and in local shops and there all alot more expensive than this. i dont have alot of money to spend.
Im pretty handy when it comes to modifying things but this is a lot different than just welding something. this has to save my life haha
Old 04-22-2013, 06:49 PM   #6
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Options:
1. Seller near by - go measure the brackets, even make your own cardboard template to help.
2. Far away - see if the seller can measure widths, lengths, and drops so you can check how close it is to fitting
Either way, if 2 or more bolt right up & others need a spacer for example, might not be too bad.
3. At the price, you're close to getting one of the cheaper Corbeau's for example (driver only), and that would take care of your bad seat plus get you closer to the pair you want some day...
4. least attractive right now, junkyard a replacement for the damaged seat & keep looking. If these won't fit easy, or will break the bank getting it done...
Luck!
sailor is offline
Old 04-22-2013, 07:15 PM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 129,606, Level 100
Points: 129,606, Level: 100 Points: 129,606, Level: 100 Points: 129,606, Level: 100
Level Up 0% Completed
Forum Activity 91%
Activity: 91% Activity: 91% Activity: 91%
Buy-Sell-Trade Rating: (11)
Moved to the MK1 Interior Mods & Upgrades area
I'd stay away from knock off seats. I've had a set that didn't last long at all. There is a reason why good seats are expensive. Save your money and get something that will last and be worth it. As for seat brackets it took me a long time to find a set that wasn't outrageously.priced. I ended up finding a set of custom made seat brackets. I had them for sale a long time ago but no one wanted to buy them. Don't try to rig up the seats to fit, in the event of a crash it can and will break the mounts causing you to fly all over the cabin or even out the window.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 04-22-2013, 07:32 PM   #8
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
Forum Activity 2%
youll need some sort of resistor wired in to trick the system into thinking the bladder is being sat on. downside is the airbag is always "on" in a crash
otherwise ive heard of people transplanting that bladder into an aftermarket seat. without one of those two youll have an airbag light which means they may or may not go off in a crash. not something id want to test
==1972 Skylark==
Buickboy is offline
Old 04-22-2013, 08:02 PM   #9
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,255, Level 64
Points: 9,255, Level: 64 Points: 9,255, Level: 64 Points: 9,255, Level: 64
Level Up 69% Completed
Forum Activity 6%
I still need to fix my airbag light tried transplanting the one from the oem seat and didn't work. I have an 03 with no seat airbags. If you happen to figure something out definitely post a how to.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 04-22-2013, 09:07 PM   #10
jugglethese
Fan#: 108852
i didnt really want to make something up. i cant really trust myself with welding something thats going to save my life. not to mention i dont know if insurance would even cover me if i did that, if i got in a serious crash. ill do some more shopping online to see if i can find something. but its either a broken seat or a knock off. i think the knock off is still better than what im sitting in right now haha
