exhaust leak only when accelerating? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-22-2013, 12:14 AM   #1
whimsicalpouch2
Fan#: 87978
What I Drive: 2002, black SVT focus
Points 4,736, Level 43
Points: 4,736, Level: 43 Points: 4,736, Level: 43 Points: 4,736, Level: 43
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 4 whimsicalpouch2 Good Standing Member
Buy-Sell-Trade Rating: (6)
when i rev the engine, it makes normal revvs and and sounds fine. i can be moving however fast in neutral and rev it and it sounds fine. however, if i am accelerating, it will make a love vibration noise from the exhaust around 2500rpms. and it is really loud aswell, people definitely hear it and it sounds terrible.
what could this be?
Most Excellence!
#586 of #4788
whimsicalpouch2 is offline
Old 04-22-2013, 12:53 AM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,634, Level 94
Points: 23,634, Level: 94 Points: 23,634, Level: 94 Points: 23,634, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
that's the difference between no load revving and accelerating with a load on the engine. Check for a loose heat shield or any dark discoloration around any gaskets that may indicate a leak.
mikebontoft is online now
Old 04-22-2013, 08:29 AM   #3
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,855, Level 25
Points: 1,855, Level: 25 Points: 1,855, Level: 25 Points: 1,855, Level: 25
Level Up 55% Completed
Forum Activity 3%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
If you truly suspect an exhaust leak, check your motor mounts for excessive movement. A bad mount will allow movement under load, which might not be sufficent to cause the symptom without load.
mainest is online now
Old 04-22-2013, 01:52 PM   #4
whimsicalpouch2
Fan#: 87978
i recently installed 3 poly mounts on my SVT, so i would assume the movement would be less than rubber, but i'll take a look at them.
i'll see if there are any gasket problems,
it sounds like the sound is come from the rear, when i'm in my car wit hthe windows up, its faint but sounds behind the passenger seat, windows down definitely sounds towards the rear,
could there be something broken possibly in a muffler?
Most Excellence!
#586 of #4788
Old 04-29-2013, 04:52 AM   #5
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
Points 625, Level 12
Points: 625, Level: 12 Points: 625, Level: 12 Points: 625, Level: 12
Level Up 50% Completed
FF Reputation: 3 Kodyston Good Standing Member
Does it sound like it echo's off of whatever your driving by? Cuz what you described sounds like what mine also does. And it sounds like it's coming from under that car where my doors are. And it sounds terrible...
Kodyston is offline
Old 04-29-2013, 09:28 AM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Forum Activity 5%
^ The exhaust sealing gasket between the tail end of the flex pipe and horizontal exhaust section has likely burnt through. In my experienece, it starts to make a rasping noise before opening up completely and becoming quite loud. The pipe junction is just ahead of the front edge of the doors.
BC_ZX3 is offline
Old 05-01-2013, 02:45 AM   #7
Kodyston
Kodyston's Avatar
Fan#: 112498
Well, when I had it at the garage last, my mechanic said he couldn't find any leaks anywhere. Maybe he just overlooked it? I'll crawl up under the sometime this weekend and check. Thanks for the input.
Kodyston is offline
Old 07-26-2014, 01:04 AM   #8
camaddox1
camaddox1's Avatar
Fan#: 114671
What I Drive: 2003 CD Silver SVTF
Points 392, Level 7
Points: 392, Level: 7 Points: 392, Level: 7 Points: 392, Level: 7
Level Up 84% Completed
FF Reputation: 1 camaddox1 Good Standing Member
Hate to resurrect a thread but did this ever get solved? Mine is doing the exact same thing. Raspy rattle only under load. Sounds like it's coming from the back. I have a cat back and went as far as to weld in a new muffler cause I was sure that's what it was. I don't see any leaks around gaskets but it's so split second that it could be. I recently got an off-road pipe and that's when it started. I can't believe what I'm hearing is the rasp that comes with the pipe though.
camaddox1 is offline
