Rear Suspension Trailing Arms (dog-bone) replacement. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2013, 03:34 PM   #1
hfxbomberfan
hfxbomberfan's Avatar
Fan#: 92578
What I Drive: 2007 Silver ZX5 SES
FF Reputation: 1 hfxbomberfan Good Standing Member
I have to replace my rear trailing arms (dogbones) in the rear suspension of my 2007 Focus SES ZX5.
The Chilton repair book says you have to take off the rear springs and strut. Is this really necessary ? Can't I just compress the rear spring with a Spring compressor and then swap out the dog-bones ?
hfxbomberfan is offline
Old 04-20-2013, 07:12 PM   #2
old school focus
old school focus's Avatar
Fan#: 64365
What I Drive: 01 zx3/ 03 svt jrsc/02 turbo svt
Points 26, Level 1
Points: 26, Level: 1 Points: 26, Level: 1 Points: 26, Level: 1
Level Up 52% Completed
FF Reputation: 1 old school focus Good Standing Member
If your talking about the rear control blade bushing I believe you have to remove the whole arm and use a press to get bushing out and replace new. Are you replacing with prothane or energy suspension.If so only press out rubber part. the metal sleeve must stay in. After you install bush then you have to shove the bone thru. its tight.
old school focus is offline
Old 04-20-2013, 07:18 PM   #3
old school focus
Fan#: 64365
Points 26, Level 1
Maybe you ment the main rear control arms. there is no strut. Just coil spring and shock. If you put a jack under the arm near the wheel and compress the suspension you can remove the lower shock bolt. you will need to disconnect sway if u have one. then unbolt outer bolt on arm near wheel. now you can lower jack and arm will drop allowing spring to come out. You can google replace rear control arm zx5 and prob find a video. Hope that helps and good luck.
