need help ztech missing and spuddering - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2013, 09:56 AM   #1
Jason1906709
Fan#: 110909
What I Drive: 2000 Forest green ZX3
FF Reputation: 1 Jason1906709 Good Standing Member
need help ztech missing and spuddering (SOLVED!)
so i just put a new motor in my zx3 hooked it all up but now its missing when on gas or accelerating not sure what to do... checked wires and plugs there fine cleaned up the throttle body,replaced TPS cleaned up MAF switched coil packs. i did have one rubber hose that would not stop pinching shut i do believe that is the main vac line so i did replace that hose. i checked the wiring unplugged the injectors checked the insides of wires checked the coil pack wires i dont know what else to do... i do think its a vac leak somewhere but idk i did spray carb cleaner on hoses with nothing from the motor as in a rev up so anyone seeing something im not?!
FREE ZX3 PARTS ARE ALWAYS WELCOME! :D THANKS SO MUCH!!!!!!!
Jason1906709 is offline
Old 04-20-2013, 09:47 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,153, Level 74
Points: 13,153, Level: 74 Points: 13,153, Level: 74 Points: 13,153, Level: 74
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 30%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat".
zetecDon is offline
Old 04-21-2013, 08:58 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Sputtering?
Pull on the individual wires on the coil-pack connector. Those cause problems sometimes, but typically the engine cuts out.
Ok vacuum: there are only so many vacuum lines. You've got the big one to the power brake booster. The PCV line, which might be one that you had collapsing- IDK. You've probably got one small one going to the EGR, and there's one going to the Evaporative emissions Purge valve. There might even be one going to the canister itself depending on how it works in a Zetec. There is a vacuum schematic called the Vehicle Emissions Control Information sticker under the hood somewhere. It might be on the bottom of the hood, or it might be on the firewall. That shows you where all your vacuum is connected.
That reminds me- the DPFE might be the issue. That one causes issues. The DPFE is what senses exhaust flow to tell the EGR when to open.
You should also pay very close attention to the routing of your wires around the EGR tube- the hot pipe that comes off the exhaust manifold. More than one FF has had problems with harnesses in that area getting moved around and melted. That can cause issues, and has caused engine running issues.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-22-2013, 12:38 PM   #4
Jason1906709
Fan#: 110909
well the hose that i had problems with and replaced was the main vac line. the motor is running rich i can smell it when im running the car. i did have a code come up so i had it tested it came up O2 sensor bank 1 and 2 so looked around noticed the sensor was not connected on the bottom of the cat so i hooked that up and replaced the other bank 1 sensor light went out but still running rich i checked the coil pack harness a few times and nothing.. cleaned up the MAF and its driving me nuts.. just cutting out i thought maybe it was my firing order but its not i have them right and i replaced the DPFE. im not sure where to look now. im going to replace the MAF and see what happens ill keep everyone posted.
Old 04-22-2013, 04:36 PM   #5
Jason1906709
Fan#: 110909
ok so i just replaced my MAF and still the same... going to check the coil pack wires now also ill keep you updated and if someone sees something im not then please let me know
Old 04-23-2013, 12:43 PM   #6
Jason1906709
Fan#: 110909
checked coil pack wires there fine i changed out the DPFE nothing changed but its a constant miss not just at low rpm so someone else help me out here?! this is driving me nuts i keep looking around and looking at wires and hoses im just going nuts...
can someone take a pic of where all the hoses go? like the vac lines. i cant understand the black and white pic that i have found so thanks in advance.
Old 04-25-2013, 11:01 AM   #7
Jason1906709
Fan#: 110909
well guys i guess noone else knows whats wrong with this car... i guess im going to try to look at timing i know its a bitch in this car cause of the DOHC... really dont wanna mess with the timing but i guess thats the only other option...
Old 04-25-2013, 11:21 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,380, Level 75
Points: 13,380, Level: 75 Points: 13,380, Level: 75 Points: 13,380, Level: 75
Level Up 33% Completed
Forum Activity 99%
Can't remember who it was offhand that recently did a swap & ended up finding an issue with one of the main harness connectors...
Just a quick thought in case it applies...
sailor is online now
Old 04-25-2013, 06:36 PM   #9
Jason1906709
Fan#: 110909
hmm main connectors?... ill check into it now my fan isnt working so car is getting hot im like ripping my hair out here uggggg
Old 04-25-2013, 08:23 PM   #10
Ptreezx3
Ptreezx3's Avatar
Fan#: 97773
What I Drive: 2003 red svt, 06 blue escape,
Points 63, Level 1
Points: 63, Level: 1 Points: 63, Level: 1 Points: 63, Level: 1
Level Up 26% Completed
FF Reputation: 1 Ptreezx3 Good Standing Member
Mine just started acting up yesterday and im gonna replace my o2 sensors tomorrow and pcv valve with elbow tube. Will see what happens. Will update
Ptreezx3 is offline
