back again with anotehr turbo question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2013, 03:23 AM   #1
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
ive been piecing stuff together for a long time now and i finally ahve the cash to afford a somewhat inexpensive turbocharger
ive been eyebaling this one for my daily driven svtf
http://www.precisionturbo.net/turboc...--5431E-MFS/58
this is mainly a street car that gets autocrossed occasionally and sees lapping days a few times a year.
i have a toms first generation zetec turbo kit that i'll be using most likely a majority of the piping from (manifold and charge pipes are in great shape, downpipe not so much) otehr parts i can make if need be or source.
my goal is at max something that can put 300 hp down. maybe a bit more.
my kit may not be teh best performing, or teh prettiest but the main goal is function and good solid performance on a bit of a budget.
any help in picking out a turbocharger taht fits a t3 pattern manifold would really help.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 04-20-2013, 12:50 PM   #2
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
bumping. for bewst?
Paladin is offline
Old 04-20-2013, 01:15 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,554, Level 100
Points: 52,554, Level: 100 Points: 52,554, Level: 100 Points: 52,554, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (28)
The turbonetics T3 S60 STGIII is a good turbo for what your looking for
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-20-2013, 10:58 PM   #4
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
mmkay. i still have teh one from the kit but its in pieces (seals bad and took it apart. i ahve all of the parts though. would it be feasable to rebuild it at home and have it balanced? (does it need to be balanced after a rebuild?) ifi can find a model number for it that should tell me which turbo i have (i ahve noticed updated shafts and things like that) also how hard would it be to swap out my turbine housing for a 4 bolt. since i want to re do the downpipe, not really that important. but it has what looks to be an egt bung post turbo, as well as a larger bung (o2 sensor?) so i'd need to do some weld work to it.
EDIT
http://www.ebay.com/itm/AiResearch-T...f52db2&vxp=mtr
would this one do teh trick? or would she be too slow to spool in teh svtf to ahve any sort of fun?
Paladin is offline
Old 04-22-2013, 04:30 PM   #5
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
bump for bewst.
Paladin is offline
Old 04-23-2013, 07:45 AM   #6
turbosvtfocus04
turbosvtfocus04's Avatar
Fan#: 100806
What I Drive: 2004 black svt
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 turbosvtfocus04 Good Standing Member
If you go with the 5431E precision, you won't be disappointed. It's a great turbo for the price. That turbo has had a lot of success.
turbosvtfocus04 is offline
Old 04-23-2013, 05:43 PM   #7
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
well ive already jumped on a turbo that was a really good price. its a borg warner s252 wit ha billet compressor wheel and extended tips it has a t3 flanged exhaust housing that currently has an internal waste gate (going to remove when that arrives as i dont need) has a ported shroud on the compressor side as well. what can i say other than sometimes you can find good things on beay. if you be patient and look hard enough.
i have the numbers for both sides if anyone is interested.
Compressor side
53mm inducer
79mm exducer =40 trim if my math is right
Turbine side
73mm inducer
58mm exducer =64 trim? not quite sure on the exhaust side.
either way its the turbo i'm using and we'll find out soon if it can make power or if she sits there and just takes forever to spool.
Paladin is offline
Old 04-23-2013, 06:18 PM   #8
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
I don't think it's going to take as long to spool the turbo up as you think.
Old 04-23-2013, 06:32 PM   #9
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
i hope not. i'm still kind of a novice when it comes to this math and this is my first attempt at a turbocharged car. but i am willing to learn as much as i can. unfortunately i learn best by doing, not looking or reading, so this is gonna be fun. i know you need a restrictor for a journal bearing turbo. but what size should i run with and are there many sizes?
Paladin is offline
Old 04-23-2013, 06:44 PM   #10
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
.065" is the common restricter
As far as spool time, every motor is different. Tuning has a big roll in it as well. To many variables to tried to figure out spool time on a turbo.
