iPod Question - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 04-18-2013, 07:22 AM   #1
dan03833
Fan#: 87798
What I Drive: 2012 Ford Focus SE (Silver)
FF Reputation: 1 dan03833 Good Standing Member
iPod Question
I have a 160 gig iPod Classic with about 8,250 songs on it. For the last couple of days when using it in my car, when I try using voice commands to request it play a playlist or specific artist, it tells me that it is indexing and to try again later.
Does anyone have an knowledge or information to share about this? Thanks for you help.
dan03833 is offline
Old 04-18-2013, 08:04 AM   #2
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
I have the same ipod with about ~6000 songs on it. When I had the fusion SEL with sync it did the same thing. You can try unplugging the ipod and reset the sync and then plug it back in after the reset. Sometimes it works.
I now have the same ipod plugged into my 12 focus with MFT and it works flawlessly, all ~6000 songs available.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 04-18-2013, 08:27 AM   #3
mmmfloorpie
Fan#: 72039
What I Drive: 2012 Red Candy Metallic SE
Points 100, Level 1
Points: 100, Level: 1 Points: 100, Level: 1 Points: 100, Level: 1
Level Up 50% Completed
Forum Activity 5%
FF Reputation: 1 mmmfloorpie Good Standing Member
The best way to listen to music through Sync is with a USB stick. I've never had an issue.
mmmfloorpie is offline
Old 04-18-2013, 08:51 AM   #4
Focus805
Fan#: 90582
What I Drive: 2012 Frosted Glass SEL HB 300A
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
FF Reputation: 1 Focus805 Good Standing Member
Ditto. It's flawless. Just copy your itunes music folder to a flash drive
Focus805 is offline
Old 04-18-2013, 08:52 AM   #5
Focus805
Fan#: 90582
Ditto. It's flawless. Just copy your itunes music folder to a flash drive. I dunno about a 160GB flash drive though
Focus805 is offline
Old 04-18-2013, 09:45 AM   #6
I Bleed Ford Blue
Fan#: 94113
They do make a 128 GB flash drive. For the amount of songs he has, a 64 GB would work also and they are cheap. less than 100 bucks.
L-CCC #18/HOIA #37
Old 04-18-2013, 10:11 AM   #7
bwainwri
bwainwri's Avatar
Fan#: 113619
What I Drive: 2012 Sterling Grey Focus SEL
FF Reputation: 1 bwainwri Good Standing Member
I had this issue once before with my 80GB ipod classic but it only happened the first use after plugging it into the SYNC. I assume each time the USB device is switched it has to sync and index it to get all the music data and voice commands and after a minute or two its good to go.
Are you unplugging your ipod everytime you get out of the car?
bwainwri is offline
Old 04-18-2013, 10:57 AM   #8
valmundo
Fan#: 89368
What I Drive: 2012 Focus SE & 2013 ST2
Points 3,802, Level 39
Points: 3,802, Level: 39 Points: 3,802, Level: 39 Points: 3,802, Level: 39
Level Up 2% Completed
FF Reputation: 11 valmundo Great Standing Member
One reason why I like to use my iPod instead of a flash drive is that I haven't figured out how to do playlist with a flash drive. My ipod has tons of playlists and I can use the sync commands to play whatever playlist I want.
It is possible to do playlists on a flash drive?
valmundo is offline
Old 04-18-2013, 09:30 PM   #9
mmmfloorpie
Fan#: 72039
Points 100, Level 1
Forum Activity 5%
Playlists are possible. Copy the playlist file onto the flash drive and say "Play playlist: <name>".
Oh, and just as an aside, it always astounds me when people say they have XXXX number of songs...
I have just about every single song I've ever heard in my entire life on my computer and that's still just under 1000 songs.
Old 04-19-2013, 06:57 AM   #10
dan03833
Fan#: 87798
Here's an update. I did the System Reset, which worked just fine. This meant I had to re-pair my cel to the system as well, which went fine, with one exception. Before I did this reset, my cel would connect automatically when I got in the car, now it's not doing that. I went thru the settings on both the phone & Synch with no luck. Any ideas?
Thanks
dan03833 is offline
