car wont start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-18-2013, 02:37 AM   #1
Luis360
Luis360's Avatar
Fan#: 35708
What I Drive: 2002 Black ZX3
Points 1,781, Level 24
Points: 1,781, Level: 24 Points: 1,781, Level: 24 Points: 1,781, Level: 24
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 1 Luis360 Good Standing Member
car wont start
ok guys i have a HUGE problem. i went to a car show on Sunday. as i was getting ready to leave, i went to start my car and it didnt. I thought it was a dead battery. Anyways, i get my jumper cables to charge my battery. car still wont start. wont even click. I then use my brothers Focus SE battery and get the car running. i quickly disconnect the battery and put mine in. i soon start to smell a weird scent. i pop my trunk and see my subs capacitor is boiling up and smoking. i quickly disconnect my capacitor so it wont catch fire. Anyways, i drive off and notice the battery light turns on. i knew the battery was going bad so i was going to replace it. i stop at a Cicis pizza to have lunch with my friends. when i get out to leave, the same thing happens. this time the car wont start for nothing. starter wont click or turn over. i also noticed that when i was leaving the car show, my headlights and fog lights burnt out. i had to get my car towed. i noticed that my fuel pump isnt turning on. i changed the starter and still the same. i plug in my scanner to scan for codes but all i get is an error. could my ecu be fried? all fuses are fine.
Luis360 is offline
Old 04-18-2013, 04:18 AM   #2
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,505, Level 100
Points: 35,505, Level: 100 Points: 35,505, Level: 100 Points: 35,505, Level: 100
Level Up 0% Completed
Forum Activity 6%
You guys are having a really ruff time with your cars. Glad to see giovanie got his car going again. I hope you can get your figured out.
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is online now
Old 04-18-2013, 06:40 AM   #3
cpalz
Fan#: 105682
What I Drive: 2002 Zx5 Focus, 2005 Zx4 Focus
FF Reputation: 1 cpalz Good Standing Member
Did you remove the battery while the car was running? It is very possible that created an overvoltage situation that cooked the electronics. Bulbs if turned on will be the first to go. If the alternator sees no voltage on the chargeback wire from the battery, it could go into full output. Or a voltage regulator starting to go. If the voltage regulator is bad, the battery could be the only thing holding the voltage down for a while. That has happened before, so many people believe in the old procedure that to test your alternator, get the car running, and remove the neg. cable. If the car stays running, alternator is good. That is never a good idea on newer cars with all the electronics. Same thing with removing the battery while running. Hope it turns out well for you, and best of luck.
cpalz is offline
Old 04-18-2013, 07:04 AM   #4
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2008 chevy cobalt SS/TC.
Points 2,826, Level 32
Points: 2,826, Level: 32 Points: 2,826, Level: 32 Points: 2,826, Level: 32
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 6 05focusST91 Good Standing Member
Well swapping batteries with the car running you most likely spiked the alternator since thats where all the power was going to while the battery was out
Funtion>form.
FLOOR IT!
2005 focus ST (gone)
Still here!
05focusST91 is offline
Old 04-18-2013, 07:06 AM   #5
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
Disconnected the battery while the car was running???
Please see this link to back up what cpalz is saying and me
http://www.troubleshooters.com/dont_...ct_battery.htm
You toasted everything
mikeeshaq is offline
Old 04-18-2013, 12:59 PM   #6
Luis360
Luis360's Avatar
Fan#: 35708
Unfortunately I did remove the battery while the car was on. I didn't know modern cars didn't work like old Ines did. This was the only way to get the car moving. I took the ecu to do a smell test and kinda smelled burnt electronics. Opened up the ecu and guess what? I fried my ecu. Now I need to get a new ecu and get it flashed so it can work with my car.
Luis360 is offline
Old 04-18-2013, 01:00 PM   #7
Luis360
Luis360's Avatar
Fan#: 35708
Ones*
Luis360 is offline
Old 04-18-2013, 01:48 PM   #8
Luis360
Luis360's Avatar
Fan#: 35708
https://www.facebook.com/photo.php?f...=photo_comment
Luis360 is offline
Old 04-18-2013, 07:37 PM   #9
mikeeshaq
Fan#: 72526
Bro I feel for you
The space capsule that went to the moon and back well today's cars have more computing power than that.
!2 Volts isn't much and any deteriorated cables/connections will drop precious Volts and render the car unusable. Years ago I read stories about cars would have higher Voltage systems such as 24 or even 48 Volts ,save on copper too as the wires would be thinner, I don't know what happened to that plan.
By the way the ECU isn't the only black box on a car either
Old 04-18-2013, 07:51 PM   #10
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
Originally Posted by mikeeshaq View Post
Bro I feel for you
Electronics got smaller, more efficient and require smaller voltages (< 5 volts), so no need for changing to an electrical system >12 volts. Really big vehicles (big trucks, big military vehicles, ships, etc.) will use 24/48 volt systems. They need to run big motors, compressors, etc.
Milton is offline
