New T-Belt Tensioner Failure... :( - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2013, 08:10 PM   #61
limeyrider
limeyrider's Avatar
Fan#: 35376
What I Drive: 2004 SVT, infrared, '72 Bonny 650
Points 462, Level 9
Points: 462, Level: 9 Points: 462, Level: 9 Points: 462, Level: 9
Level Up 24% Completed
FF Reputation: 4 limeyrider Good Standing Member
Originally Posted by rent View Post
As long as you released the tensioner and then retensioned the belt with it, I don't see a problem.
I did loosen some but NOT all (to completely slack) before tightening again.
I would recommend observing the tensioner with the upper timing cover off to see how it reacts when you have the car running. Every car is somewhat unique in this regard even though it is within a small range of variance.
Exactly and I DID see it stay in the min and max 'fork' range both running and off, post adjustment.
Raleigh NC - Home of deep fried sushi....
limeyrider is offline
Old 04-24-2013, 09:04 PM   #62
rent
rent's Avatar
Fan#: 12823
What I Drive: 03' SVTF
Points 669, Level 13
Points: 669, Level: 13 Points: 669, Level: 13 Points: 669, Level: 13
Level Up 38% Completed
FF Reputation: 2 rent Good Standing Member
Got the head back from the machine shop today :
Head bolts and gasket are in tomorrow, should start getting it back together. Depending on the mechanics workflow, I might have her back on Friday, potentially Monday though.
I got my new T-Belt, Tensioner, and Idler from Steve @ Tousley. He rocks! I'll put up some detailed pictures of the tensioner tomorrow or Friday depending on when I have time.
Then off to get my RE-11a's :D
-James
'03 SVTF *FOR SALE*
'14 FoST Ingot Silver, bone stock...
rent is offline
Old 04-27-2013, 07:08 PM   #63
Hellspeaker
Fan#: 108527
What I Drive: 2002 Infra Red svt
FF Reputation: 1 Hellspeaker Good Standing Member
So from what I've read on here. When properly set up, the tensioner its self won't actually line up? Because my tensioner drops down about an inch. It spooked me a little when is seen it. I have honestly been trying to get it to line up lol!
Hellspeaker is offline
Old 04-28-2013, 06:25 PM   #64
limeyrider
limeyrider's Avatar
Fan#: 35376
Points 462, Level 9
If you have not already done it, ask Steve exactly what the alignment should look like and how far (IF AT ALL) it should go out of range.
Old 04-28-2013, 08:09 PM   #65
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
You guys are driving yourselves crazy. The tensioner can be correct and in range and the VCT blows all of that out of the water if the solenoid has leaked down while motor sat. Meaning you can see what appears to be abnormal looseness in the belt and still run correct. The VCT allows the cam to fall out of time with slack when motor is static. Why Ford tells you not to ever back off a tensioner once it's set. Besides that the belt breaking in the first five minutes of use means the tensioner range is incorrect after that point in time. Range is only correct on a brand new unstretched belt. The ONLY WAY you can recheck used belt tension is with the variable cam pulled up to the absolute zero end stop and all slack pulled to backside of tensioner after rolling motor around. Try that and see how difficult it is to get it all just right at the same time.
The tensioner, Ford branded or otherwise, is not high enough quality to hold exact setting once it has been banged on some by a running belt anyway. It was only intended to be used once at setup time and the pointer can change and sometimes drastically once run in, the range will not be like it was. Freaking out over that and over correcting for it will surely buy you grief.
Casted later design parts being bad? Nope. The only way would be if they were CRACKED, I see no mention or evidence of that at all. Casted parts don't deform, they crack, or the dead giveaway the part is substandard. You'd best look closer at your perceived 'better quality' Ford part, the base support in it it is cast also. I've seen your 'better quality' steel Ford tube insert in the center come apart too, as it is only held together by the cheapest quality stake job you can imagine. I've rebuilt them before. I for one cannot see the raving about castings when the freakin' pulley is PLASTIC, or the weakest part there, I've seen several of the plastic pulleys crack apart to let the bearings fall away free. FORD branded pulleys.................
Anybody figured out you can roll the tensioner eccentric in either of two directions yet? You can roll it in from the bottom or in from the top............I
amc49 is offline
Old 04-28-2013, 09:05 PM   #66
limeyrider
limeyrider's Avatar
Fan#: 35376
Points 462, Level 9
Some cast and powdered metal can bend before cracking - depending on which metals they're made of.
You're missing the OP..the tensioner allowed enough slack in the belt to cause bent valves. Something in it obviously went wrong.
Old 04-28-2013, 11:29 PM   #67
amc49
Fan#: 96610
Forum Activity 11%
Yes, it can bend slightly, but where bent on the part pictured to allow that? All I see is a pretty much polished bolt seating point, which could argue strongly not tight enough. No magic to a tensioner, if something went wrong with it then it would not spring properly anymore or broken somewhere, or roller locked up. Barring physical evidence of tensioner damage the tensioner did not do it. He has a case if tensioner is broken or collapsed to be able to see it somehow.
Somebody needs to take the tensioner apart to determine what you're looking for. That front casted part looks like aluminum to me.
amc49 is offline
Old 04-29-2013, 07:12 AM   #68
rent
rent's Avatar
Fan#: 12823
The entire kit is being returned through Amazon to Gates. If they find an issue I'll update here, but I have no idea how quick that will happen.
If I incorrectly installed the kit, I have no issue taking responsibility for flattening my exhaust valves, but something had to happen to cause the tensioner to lose tension and allow my exhaust cam to jump. The tensioner was torqued to spec. The mechanic who has my car now checked for this and verified my work and requested new all new parts for a timing fix, not just a belt. They've seen it happen before, one of those rare things that unfortunately happens.
-James
'03 SVTF *FOR SALE*
rent is offline
Old 04-29-2013, 02:33 PM   #69
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,179, Level 67
Points: 10,179, Level: 67 Points: 10,179, Level: 67 Points: 10,179, Level: 67
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
I'd be interested to hear of people that used the revised tensioner with SUCCESS, if the two failures mentioned are the only two that have occured then it would be easier to dismiss it as a freak accident and not an indicator of the general quality of the revised tensioner. I really want to swap my timing belt soon but having this part has me wary of putting it in....
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 04-29-2013, 02:50 PM   #70
Ralliman
Ralliman's Avatar
Fan#: 99721
What I Drive: 2003 Infra Red SVT ZX5
Points 721, Level 14
Points: 721, Level: 14 Points: 721, Level: 14 Points: 721, Level: 14
Level Up 21% Completed
FF Reputation: 2 Ralliman Good Standing Member
I've been running on mine since about March 17 or so. It's a Gates 294B kit, with tensioner and pulley. No issues so far, knock on wood.
Ralliman is offline
