New T-Belt Tensioner Failure... :( - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-21-2013, 01:52 PM   #51
ClutchDeath
ClutchDeath's Avatar
Fan#: 81304
What I Drive: 2002 Red SVT
Points 459, Level 9
Points: 459, Level: 9 Points: 459, Level: 9 Points: 459, Level: 9
Level Up 18% Completed
FF Reputation: 1 ClutchDeath Good Standing Member
The a kit uses a 70mm upper idler pulley, the b kit uses a 60mm pulley. They also have different mounting locations on the cylinder head. I would think that if the wrong kit was used there would be too much tension on that belt.
Sent from my SGH-T989 using Xparent Skyblue FF Mobile
ClutchDeath is online now
Old 04-21-2013, 05:49 PM   #52
rent
rent's Avatar
Fan#: 12823
What I Drive: 03' SVTF
Points 669, Level 13
Points: 669, Level: 13 Points: 669, Level: 13 Points: 669, Level: 13
Level Up 38% Completed
FF Reputation: 2 rent Good Standing Member
Exclamation
Did you even bother to check the earlier posts in this thread?
I checked ALL of the parts I put on the car for part number matches, which I posted pictures of on page 3. I also measured the parts vs. stock for giggles as well before installation.
The timing idler pulley that came in the kit was Gates T42036 which is a 60mm idler pulley. The extra pulley in the kit (for Escorts) was never opened.
I wouldn't have made this thread if I put the wrong parts on the car, then it would be completely my mistake.
-James
'03 SVTF *FOR SALE*
'14 FoST Ingot Silver, bone stock...
rent is offline
Old 04-21-2013, 06:19 PM   #53
ClutchDeath
Fan#: 81304
Points 459, Level 9
Sorry it just there me off when I saw the part numbers. I always thought the "a" kits came with a bigger idler pulley. I just did my timing belt a few weeks ago with a gates kit as well. And at one point I was doing the same kind of research for a motor I did a head swap in.
Old 04-21-2013, 06:32 PM   #54
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
FF Reputation: 3 jasonbi Good Standing Member
i was changing the drive belt on my svt today, figured it would be easier to go in from the top...while i was in there i took off the upper timing cover to have a look at the condition of the belt. i noticed the t-belt tensioner alignment pointer was about a half inch lower than where it should be. it drives fine and havent had an issue in the 50,000+ km that ive put on the motor since i did t-belt swap....seems a little weird that the tensioner would have backed off that much since then, i know it was put together right and torqued correctly cause i did it myself a few years back and followed the install instructions to the letter....after reading this im freaked right the F out!! i loosened the bolt and re-set the tension...gonna check it again in a few weeks! hopefully no "boom" in my future(fingers crossed)
#3286 OF 4788
jasonbi is offline
Old 04-22-2013, 08:49 AM   #55
Insaniac
Insaniac's Avatar
Fan#: 34327
What I Drive: 2003 ZX5 SVT
FF Reputation: 5 Insaniac Good Standing Member
I didn't see mentioned anywhere, was this a Gates tensioner?
2003 ZX5 SVT #1345
CD Silver; Red Interior; Audiophile; Moonroof; HID's
Insaniac is offline
Old 04-22-2013, 10:08 AM   #56
jasonbi
jasonbi's Avatar
Fan#: 13305
yeah its a gates!!
#3286 OF 4788
jasonbi is offline
Old 04-22-2013, 10:35 AM   #57
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,295, Level 67
Points: 10,295, Level: 67 Points: 10,295, Level: 67 Points: 10,295, Level: 67
Level Up 62% Completed
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
if you read back, another member mentioned that this something with the design of the tensioner, that the mark doesn't line up anymore after a few rotations, but that it's still tensioned correctly....and that if you make it line up again, you'll over-tension it.
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 04-22-2013, 11:50 AM   #58
jasonbi
jasonbi's Avatar
Fan#: 13305
i loosened the bolt, removing all the tension and then re-tensioned it...should be alright...i hope
#3286 OF 4788
jasonbi is offline
Old 04-22-2013, 11:52 AM   #59
rent
rent's Avatar
Fan#: 12823
This ^^^
As long as you released the tensioner and then retensioned the belt with it, I don't see a problem. I would recommend observing the tensioner with the upper timing cover off to see how it reacts when you have the car running. Every car is somewhat unique in this regard even though it is within a small range of variance.
No updates on my end. I went to my local dealer just to see how available valves were in case the machine shop somehow couldn't get any... but they're easily available, given one days notice. Dealer wanted nearly $600 for a full set... and I'm not surprised.
I am curious if anyone on here has rebuilt using DNJ valves on RockAuto and the quality of the product.
-James
'03 SVTF *FOR SALE*
rent is offline
Old 04-24-2013, 08:03 PM   #60
limeyrider
limeyrider's Avatar
Fan#: 35376
What I Drive: 2004 SVT, infrared, '72 Bonny 650
Points 464, Level 9
Points: 464, Level: 9 Points: 464, Level: 9 Points: 464, Level: 9
Level Up 28% Completed
FF Reputation: 4 limeyrider Good Standing Member
No, do *not* completely release tension on an already mounted and run belt...
Raleigh NC - Home of deep fried sushi....
limeyrider is offline
