16 inch wheel problem - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-16-2013, 05:06 PM   #21
papaacer
Sonic's MK3 Crew #25
papaacer's Avatar
Fan#: 111083
What I Drive: 2012 Race Red SE
Points 7,162, Level 56
Points: 7,162, Level: 56 Points: 7,162, Level: 56 Points: 7,162, Level: 56
Level Up 6% Completed
Forum Activity 77%
Activity: 77% Activity: 77% Activity: 77%
FF Reputation: 11 papaacer Great Standing Member
Originally Posted by OPsDad View Post
You're welcome. I hope it all ends well for you!
I'm hoping the same! If it does, there will be pictures!
Originally Posted by Twenty View Post
That's because if a sedan was used there would be too much awesomeness and the internet would explode.
Originally Posted by Deftmetal View Post
I've never died because my car turned off.
papaacer is online now
Old 04-16-2013, 05:10 PM   #22
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,038, Level 66
Points: 10,038, Level: 66 Points: 10,038, Level: 66 Points: 10,038, Level: 66
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 24%
Those kind of look similar to the replicacobra r wheels for the thunderbird, which did use a 5x108 mm bolt pattern, but the center bore is probably larger, and the offsets are outside the recommended range for FWD applications. It could still theoretically work, and some people had installed them on the older Taurus models, but I'd still be cautious about falling in love with them from a description and pictures.
Those were 17x9 wheels, not sure if these were smaller, they might be the ones off of the sport package 98-99 Taurus as well, but neither of those match exactly, hrm, maybe its just polished wheels off of a Taurus or sable if its the right pattern which should be almost ok.
suss6052 is offline
Old 04-16-2013, 05:14 PM   #23
papaacer
papaacer's Avatar
Fan#: 111083
Forum Activity 77%
Very true. If they fit and I do like them, black with a red pinstripe is the first thing I'm doing before they even go on
Old 04-16-2013, 05:15 PM   #24
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2014 Fusion Titanium AWD Moonroof
FF Reputation: 2 OPsDad Good Standing Member
Someone correct me if I am wrong, but if the center bores are larger, this is a very dangerous thing, because they'll go on the hubs, but they won't provide the mechanical connection that hub-centric wheels are designed to have. So if the bores are too big, don't take them.
That's the best advice I can give, and I am about 85 percent certain that it's good advice.
SR #265 | "Quia currus certatus, inferius"
13 Focus Ti Sedan w/Handling Pkg, MFT Sony 10 NAV, Leather
13 Focus SE HB Sterling Grey, 201A, Leather
06 F350 6.0L DRW King Ranch, Sunroof, Rhino Bed Liner, 4" MBRP Turbo Back, AirRaid, Edge Chip w/Pyro
OPsDad is offline
Old 04-16-2013, 05:17 PM   #25
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
That can be an issue, the 5 bolt pattern sort of helps to keep the wheel self centered, but if the center bore is too large or too small it can be a problem. Too small is even worse as the wheels won't fit on properly at all, too large and if its not centered on the lug studs before being torqued down it can cause issues, etc.
suss6052 is offline
Old 04-16-2013, 05:18 PM   #26
papaacer
papaacer's Avatar
Fan#: 111083
Forum Activity 77%
I actually have heard that and am also taking it into consideration. Safety is obviously one of the main things but they do look like they wheels that suss6052 put up. So there is a pretty good chance :)
Old 04-16-2013, 05:35 PM   #27
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
Points 4,169, Level 41
Points: 4,169, Level: 41 Points: 4,169, Level: 41 Points: 4,169, Level: 41
Level Up 10% Completed
FF Reputation: 6 RonMaiden Good Standing Member
With all these questions and not being sure I'd pass and look for better wheels. Check out the wheels thread sticky with compatible wheels for the MK3.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 04-16-2013, 05:38 PM   #28
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 7,921, Level 59
Points: 7,921, Level: 59 Points: 7,921, Level: 59 Points: 7,921, Level: 59
Level Up 86% Completed
Forum Activity 7%
FF Reputation: 11 Joeywhat Great Standing Member
You can get rings if the center bore is too large, not a huge deal.
The Thunderbird hubs are the same size as the Focus, I have a set of Cougar wheels (same thing as the T-Bird) that work well (winter set).
Hatch Nation #29
Joeywhat is online now
Old 04-16-2013, 05:40 PM   #29
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
You realize that they make hub centric rings to make the bigger bore fit smaller wheels right... Half of the wheels on Tirerack come with them...
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 04-16-2013, 06:20 PM   #30
dodgeguy
dodgeguy's Avatar
Fan#: 85952
What I Drive: 2014 White Focus ST2
Points 578, Level 11
Points: 578, Level: 11 Points: 578, Level: 11 Points: 578, Level: 11
Level Up 56% Completed
FF Reputation: 1 dodgeguy Good Standing Member
This is all way to sketchy for me. I say pass. Find some used wheels from your make/model or something that the seller actually knows what they are selling. My $.02
K&N Air filter, uh - thats it, NO CAI, NO FSWerks, NO Exhaust, NO Coilovers, NO Tune, Nothing
dodgeguy is offline
