Wot Box Install Instructions - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-16-2014, 10:15 PM   #11
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Originally Posted by tryingtofixthis View Post
So basically this is a computer device that interrupts power from engine via ignition?(possibly as well as fuel? On other models)
So this basically means you can avoid creating a vaccume in engine. But still reduced engine power between shifts. Thus essentially a vaccume free quick shift.
So if I got this right this device is mostly advantageous in a turbo situation because it allows better flow to the turbo buy not restricting air via throttle gate.
So if I understand this correctly this mod would be say, on a turbo car, would be faster then quick shifting, and would be comparable to powershifting. But also prevent you from Truely power shifting.
What I see here is competition, the computers action to cut power duration is controlled but the.human counterpart. This means if reacting time is.fast enough to shift before any significant loss in power occurs. And see this would be a competitions on how.fast one can move the body vs how precisely, because in power shifting you gain.power at.the.engine between shift, speed is important but more often it's prediction knowing when AND how fast you need to move .
So if I got this right, in a turbo situation, drag, either this mod and lose a little engine power but gain consistency in shifts and lose less without vaccume. Or powershift skillfully, or run a modified automatic slapstick with high tc.
Also wouldn't this create an issue down shifting aggressively?
Kill time will adjust manually, shift time is manually or you can set it in auto and the box will measure your shifting time (reaction time included). SCT is 2 step programmable only for fuel cut, wot box is an electric cut with a 2 step and wot shifting.
Originally Posted by kbrownfocus View Post
So...... Basicly this is for a slow shifter hahahaha jk I had to say it, naw what this box can do for you is basicly boost your launch & et times, but I think its a waste if your not running 500-1000whp, great write up though
Yeah it helps with times regardless of the power.
Must add that I just changed heads, running an SVT one, for the zx3 ECU to read can either grind the extra pegs in the cam and leave only one like a regular zetec or instead of tapping the cam sensor splice on ground for injector 1 and select "other fuel signal".
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 08-30-2014, 03:35 PM   #12
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
What I Drive: 2003 Turbo Svt
Points 5,207, Level 46
Points: 5,207, Level: 46 Points: 5,207, Level: 46 Points: 5,207, Level: 46
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 3%
FF Reputation: 2 FocusZx3Oh Good Standing Member
Ran into some issues with the install. Got it all wired up and started doing the checks. The first check was fine. Push the gas and the light flashes. Having trouble with the second check. with the gas pushed i push the clutch in and nothing happenes. Once I let the clutch out it will then do the flashing steps. Help!!!!!!!! lol
2003 Turbo Orange Svt
FocusZx3Oh is offline
Old 08-30-2014, 05:24 PM   #13
Mother Focus
Fan#: 73292
Select clutch inverted on the lower left side of the screen, it wiill "understand" real up or down.
PTE 6262CEA
Old 08-30-2014, 05:42 PM   #14
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
Forum Activity 3%
Ok. Thanks
Old 08-30-2014, 05:44 PM   #15
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
Forum Activity 3%
Now it won't start. Was working fine. Went inside and now it's not get power to the coil. Ugh. Anyone wanna buy this thing
Old 08-30-2014, 09:39 PM   #16
Mother Focus
Fan#: 73292
What won't start?
PTE 6262CEA
Old 08-31-2014, 08:02 AM   #17
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
Forum Activity 3%
The car wouldn't start. Had to put the coil wires back to normal so the car would start. Gonna go through all the connections again to make sure they are all good.
Old 08-31-2014, 10:48 AM   #18
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
Forum Activity 3%
Can't get any of the checks to work now and it's not getting power up to the coil.
Old 08-31-2014, 11:11 AM   #19
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
Forum Activity 3%
Well got it somewhat sorted out. Everything is working now except the two step. When you open the program under the rpms it's reading 0. Change it to other rpm source and still not getting anything.
Old 08-31-2014, 06:14 PM   #20
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
Forum Activity 3%
So I got to talking to the guys over at N2MB. They are telling me the only way it'll work is to read off the negative of an injector and that the cam sensor won't work.
