Signal to VCT solenoid? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-15-2013, 02:13 PM   #1
SD_Rider
SD_Rider's Avatar
Fan#: 103846
What I Drive: 2002 Blue SVT
FF Reputation: 1 SD_Rider Good Standing Member
I have a cam timing advanced code.
My mechanic's troubleshooting found that the square wave signal to the VCT solenoid dies after (what seems like) the car warms up. It then goes to a constant 12V state.
If you shut the car off and restart, the signal returns but quickly goes away. He showed me and I verified what he was seeing.
The mechanic thinks that the computer is bad....any thing else to check???
For troubleshooting purposes...If I go to the local auto yard, can I just pull the computer from an SVT and will it be plug & play?
2002 Ford Focus SVT 125k
1996 Nissan Pathfinder 250k
2001 Suzuki Marauder VZ800 9.5k
SD_Rider is offline
Old 04-15-2013, 02:49 PM   #2
Insaniac
Insaniac's Avatar
Fan#: 34327
What I Drive: 2003 ZX5 SVT
FF Reputation: 5 Insaniac Good Standing Member
Was the t-belt changed and then the code appeared?
2003 ZX5 SVT #1345
CD Silver; Red Interior; Audiophile; Moonroof; HID's
Insaniac is offline
Old 04-15-2013, 03:05 PM   #3
SD_Rider
SD_Rider's Avatar
Fan#: 103846
It had a timing retarded code, then the t-belt was changed, and now has a timing advanced code.
I also have installed a new VCT solenoid.
The mechanic says he has tested everything. I visually watched as the car warmed up and the square wave dropped out.
He said the signal is from the computer and is not affected by anything else. I am thinking of having the dealer verify as well, but have never had good luck at dealers....always feel like I'm getting ripped off. :/
SD_Rider is offline
Old 04-15-2013, 07:40 PM   #4
Insaniac
Insaniac's Avatar
Fan#: 34327
Do you have any means to verify the timing alignment? My guess would be that the timing is off and not a bad sensor. Its very common when the new belt is installed and the tension is set for the VCT gear to get pulled slightly off full positive dead stop and get the advanced code.
If possible, pull everything back apart enough that you can install the crank timing pin and then check if the timing bar will fit in the ends of both cams. I'm willing to bet the cam bar will only fit into one of the cams.
To get the timing set correctly, you have to hold the VCT gear against full positive dead stop with a strap wrench via the VCT housing to keep it from rotating *AT ALL* when the tensioner is set and the inner bolt in the VCT housing is torqued down. Where this gets messed up and you get a CEL is when the tension is set, you can watch the belt pull the VCT gear off of full positive dead stop. >>This<< thread is a gold mine of useful information regarding properly timing an SVT zetec engine. Its what I referenced when doing my t-belt and Ive never gotten a CEL.
Admittedly, I can't readily verify what the signal wave should look like on a good car with no CEL but if the timing belt has been messed with at all I would put my money on the timing being incorrect. What was he using to watch the signal wave? If I can locate a similar device I might be able to verify what the wave looks like on my car that doesn't have the CEL.
2003 ZX5 SVT #1345
Insaniac is offline
Old 04-15-2013, 11:45 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
The signal from the ECU is an output. There has to be an input controlling it, namely the Cam Position Sensor.
Log the Cam and make sure it's still reading when the VCT drops out. If it's not the car will go into a failure mode and run on known good values. Which means the VCT is good.
That may point to the cam timing not being done correctly.
iminhell is online now
Old 04-16-2013, 12:23 AM   #6
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,273, Level 35
Points: 3,273, Level: 35 Points: 3,273, Level: 35 Points: 3,273, Level: 35
Level Up 49% Completed
FF Reputation: 3 paulg127 Good Standing Member
Please be specific.
The VCT actuator is at the front of the engine, the timing and accessory belt side of the engine.
The VCT sensor is at the rear of the engine on the transmission side.
The actuator should not have a signal unless the VCT is actually commanded. At idle, the VCT is NOT commanded, so there should be no or a small signal.
The VCT sensor is a hall efect sensor that produces voltage every time the position sensor wheel passes. There are 3 tabs (I believe) that pass the sensor every rotation.
If the engine speed is low the change in signal can be seen easily, but at higher engine speeds, like a quick rev in neutral, unless you have some pretty high accuracy reader (a volt meter will NOT likely ready the voltage changes, an o-scope would work) the meter will miss the voltage changes. Doing the math, at 2000 rpm /2 for half speed of the cams, and 3 tabs on the encoder you have 50Hz, which is pretty fast...
Just want to be sure you are getting the correct measurements...
paulg127 is offline
Old 04-16-2013, 12:43 AM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
There are 5 tabs; ~83Hz @ 2,000rpm.
Old 04-16-2013, 01:04 PM   #8
SD_Rider
SD_Rider's Avatar
Fan#: 103846
My mechanic swears up and down that he checked and double-checked per the TSB for the timing.
Someone (you?) referred me to the thread on FJ. I showed it to him and he says that it is set correctly.
An automotive oscilloscope.
Originally Posted by paulg127
please be specific
Connected to the VCT solenoid that is in the valve cover.
He also showed me that he checked the wire to make sure it wasn't shorting, back to the ECM.
SD_Rider is offline
Old 04-16-2013, 01:06 PM   #9
SD_Rider
SD_Rider's Avatar
Fan#: 103846
Thank you! And that's what I was curious about...what signal, if any, it was dependent upon.
How do I log the cam?
SD_Rider is offline
Old 04-16-2013, 11:35 PM   #10
paulg127
Fan#: 55998
There are several parameters that you can look at to determine what the VCT is doing and the adaptive values for the cam timing. If you log the commanded and actual VCT angle you can see if it is moving. There is an adaptive term that corrects the encoder wheel on the cam (the strategy assumes perfect cam timing) and the difference is accounted for in the strategy. The adapted value must be within +- 3 degrees of correction before you will set a code.
paulg127 is offline
