light tundra focus build - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-20-2013, 01:14 PM   #31
Tundrafoci
Fan#: 96605
What I Drive: 2003 light tundra ZTS
Points 718, Level 14
Points: 718, Level: 14 Points: 718, Level: 14 Points: 718, Level: 14
Level Up 18% Completed
FF Reputation: 5 Tundrafoci Good Standing Member
Buy-Sell-Trade Rating: (8)
make sure to get wet-dry sandpaper and keep the lights wet while you sand them.
Tundrafoci is offline
Old 10-20-2013, 01:33 PM   #32
Tundrafoci
Fan#: 96605
Originally Posted by RSVT170 View Post
Loving the modifications so far. I always thought this color of focus was so underrated and has so much potential to look bad a$$. Keep it light, keep it bright, and the car will look amazing. Avoid the temptation to black everything out like the lights and wheels and you'll have a winner IMHO.
I agree with you. I thought about doing the inserts black in the headlights but decided against it for this very reason.
Old 10-20-2013, 01:39 PM   #33
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 57,502, Level 100
Points: 57,502, Level: 100 Points: 57,502, Level: 100 Points: 57,502, Level: 100
Level Up 0% Completed
Forum Activity 18%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
Have you ever considered doing something like a "black chrome" tint for inside the headlights? I did it on mine and absolutely love the look. It still looks OEM without the chrome standing out so much. It's just a personal taste mod and makes more difference on a dark car like mine, but I like it much better than all out black and the unmodified chrome.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 10-22-2013, 10:26 PM   #34
Tundrafoci
Fan#: 96605
You have any pictures so I could see? I am also nervous about pulling apart the headlights...
Old 10-23-2013, 07:41 AM   #35
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 18%
You almost have to see them in person to get a real taste of how they look but here's a couple pictures that may give you an idea. Depending on the light, they can look like slightly dark chrome to an almost black from a distance. The part I like the best is that the black chrome blends the inside of the light together so the projectors don't stand out so awkwardly.
Old 10-23-2013, 06:49 PM   #36
Tundrafoci
Fan#: 96605
I do like that! it really fits with the car. What kind of paint did you use?
Old 10-24-2013, 08:01 AM   #37
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 18%
This: http://www.carid.com/universal-paint...Fc6j4AodpS4AWw
The quality of the paint job up close leaves much to be desired, but I think you can blame me for that more that the paint itself. The hardest part was not getting too dark; I screwed up on the first one and had to remove all the paint and start over.
If I were doing it again, I'd probably try spraying the housing with plain clear coat mixed with a little black paint for a much more even coating. That's basically all your doing with black chrome is tinting it like you can do with taillights.
Old 03-16-2014, 05:04 PM   #38
Tundrafoci
Fan#: 96605
Update!!
Finally have time for a huge update:
First off I bought some new (to me) ST wheels off a member on here and installed them when it snowed heavily (at least for the Portland area) because my other tires were nearing their end of life and i wanted to be able to safely get to work. Check out below to see pics of the wheels.
A few months back i put on SVT suspension I bought from a member on here. It was a fairly easy swap. Took a big breaker bar to loosen some bolts but nothing was stuck permanently that required cutting (I thank Portland for not using salt! not that we need it)
Pics of the car with SVT springs on
Went to get an alignment the other day and found out I had a bent strut so instead of just replacing the struts i went ahead and bought all new SVT struts and shocks from summit racing, and FRPP springs from Massive.
Now while I waited for these parts to arrive, I ran into the leaking thermostat issue and promptly replaced it with a CFM upgraded housing and the new 180* thermostat I have had laying around for about 3 months. Finally gave me an excuse to put it in. Along with that I ordered the new PCV hose and front 02 sensor cause mine was experiencing the collapse and I kept getting a CEL for a lean o2. it would go on and off every 200 miles or so. Installed the new one and haven't had a CEL for over 500 miles now. No pics of the o2 sensor but we all know what that looks like.
After the housing change it was back to the suspension. The new parts arrived and i began to assemble the struts. and then the next day installed everything. this was the second time i did my suspension in about 2000 miles. Everything was super easy to get loose. Didn't need a breaker bar at all. It wasn't loose it just wasn't rusted together. made the install go by way faster and was done within 4 hours for all four corners.
Also a while back i started looking at threads where people made a little scoop from the front of the grill to the intake tube. Now most people just cut a giant hole in there radiator cover and layed down some material to direct air into the engine bay near where the intake scoop was. I had one issue with this design. Although it directed air into the engine bay it allowed it to flow over and around the scoop as well. So here is my take on the grill scoop.
It is not the most beautiful thing, and it was my first time playing with fiberglass (its not as easy as it looks) but It directs the air INTO the intake scoop which I would hope would be a sort of ram air effect on the engine. I plan on running datalogs back to back with the stock radiator cover and with my modded one once i get the tuner to hook back up to my computer. I installed win 8 and I think that was a mistake for the tuning device. I will have to get my little linux laptop and put xp or win 7 on there to use the software again.
I'm going to update later with a post about the differences between the stock radiator cover and my modified one. (i would never cut up my stock stuff just in case i need to return it to its original glory)
Almost time to give my car that nice summer wax as well! just gotta get sunny for a few days that i don't work!
Old 03-16-2014, 05:38 PM   #39
Tundrafoci
Fan#: 96605
I also gotta say that the SVT suspension was super nice. Gave a little drop, a great improvement in handleing, and I couldn't tell tell the difference between the stock springs and svt springs comfort wise. and I'm considering getting another set of the SVT struts and shocks just so I can switch between those springs and the FRPP springs. The FRPP springs make the car handle perfectly. It feels neutral i guess. It was a trip taking the first turn. I could tell everything had changed. When I got out to a mountain roads (actually a road actually called mountain road). It was a frikin blast. I think the FRPP springs are meant for that fast curvy twisty action. It seems like it soaked up the bumps perfectly when going fast. But going slow (<40mph) over bumps with those springs does bring a sort of harshness to the ride. But these still haven't really been broken in or aligned yet. Got an appointment tomorrow.
Old 03-16-2014, 05:56 PM   #40
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,785, Level 73
Points: 12,785, Level: 73 Points: 12,785, Level: 73 Points: 12,785, Level: 73
Level Up 84% Completed
Forum Activity 99%
Lots O' Work
Lookin' good - suspension can do wonders eh?
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
