Drive belt derailing. See video - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-13-2013, 10:51 AM   #1
galileofigaro
Fan#: 50183
What I Drive: 2001, 2.0 SPI engine SOHC
Points 1,546, Level 22
Points: 1,546, Level: 22 Points: 1,546, Level: 22 Points: 1,546, Level: 22
Level Up 46% Completed
FF Reputation: 1 galileofigaro Good Standing Member
I installed this in the past but in this case it derails as soon as I turn the ignition on.
http://www.youtube.com/watch?v=NSlX5...ature=youtu.be
Help!
Thanks
galileofigaro is offline
Old 04-13-2013, 02:56 PM   #2
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 00 infared ZTS
Points 2,383, Level 29
Points: 2,383, Level: 29 Points: 2,383, Level: 29 Points: 2,383, Level: 29
Level Up 56% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
a pulley inst aligned somewhere, did you change anything when you put it on?
Mike_Mac is offline
Old 04-13-2013, 03:43 PM   #3
galileofigaro
Fan#: 50183
what's pulley inst?
Old 04-13-2013, 03:49 PM   #4
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
He almost said "a pulley isn't aligned somewhere" and it's probably the place to start. Have you changed anything on the side of the engine recently that might have thrown belt alignment out of whack at all?
6SPD_soul is offline
Old 04-13-2013, 06:00 PM   #5
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
You're not putting belt on right or something worn to droop or out of flat plane with the belt run, simple as that. If a flat pulley that runs on backside of belt, putting it out of line there will have the bumpout run through the line trying to derail at every pulley until it straightens out.
amc49 is offline
Old 04-13-2013, 07:38 PM   #6
J0EC00L
J0EC00L's Avatar
Fan#: 86480
What I Drive: 2001 Ford Focus
Points 4,719, Level 43
Points: 4,719, Level: 43 Points: 4,719, Level: 43 Points: 4,719, Level: 43
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 1 J0EC00L Good Standing Member
Buy-Sell-Trade Rating: (6)
I went through 3 Auto Zone Duralast tensioners before I said F it and ordered a Gates from Rock auto. Have not had the belt come of since!
J0EC00L is offline
Old 04-13-2013, 10:54 PM   #7
galileofigaro
Fan#: 50183
Looking from above the only misaligned crank pulley is the compressor's. That's why the belt derails.
One of the compressor's bolt that attaches it to the engine was loose. Tightened it but same thing. Another thing, if you check the video the compressor is leaking AC fluid.
I also haven't had any collision or going over a rock (e.g) that may have caused that misalignment.
I'm planning to get an idler pulley, which is the adjacent to the compressor. If you follow the belt's direction, the idler pulley is right before the compressor. But I don't think the idler pulley is the problem because doesn't move abnormally, there's no play when turning, looks normal.
A temporary solution: I removed an entire groove along the drive belt. No more derailing. For now.
Old 04-14-2013, 05:14 AM   #8
amc49
Fan#: 96610
Forum Activity 11%
I actually did that once for a guy with a T-Bird, for some reason a mech put his stuff back together wrong and one unit was out of line. Used a razor blade to remove one groove worth and car ran happily for years after like that. It CAN work.
amc49 is offline
Old 07-03-2013, 02:05 AM   #9
galileofigaro
Fan#: 50183
The cause of misalignment was actually a faulty A/C compressor.
One day I was just arriving home when smoke came from the engine, actually from the drive belt that got stuck and caught fire. I ran home to get a fire extinguisher and put it out. Next day the mechanic told me I needed a new A/C compressor. All is Ok now, just had to pay a few hundreds, but you know A/C issues like this costs like that. Anyway, a problem that begun 2 years ago ended up well and without a car on fire.
