i cant afford this!!!!!! - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2013, 03:51 PM   #61
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Originally Posted by gary the wolf View Post
try menthol-hydrate in the gas tank
Is that the "minty fresh" version of methyl hydrate aka methanol? lol
To the OP, a lot of intermittent problems are electrical in nature and your description is close to my experience with a faulty ignition coil connector. i.e. engine bogs, feels as if it's fuel starvation but in reality it's a lack of proper spark, car bucks, no CEL until circuit fails completely, occurs randomly but usually after car is warm (perhaps heated wire expansion is just enough to break a circuit by a few thou).
Anyway, check the integrity of the coil pack electrical connector. Any corrosion, cracks, split wire casing or green crud is a sign of a problem. Pull on the three wires at the coil. The center is 12V power; the two outer ones are "signalling/switching" wires for each pair of cylinders.
Free to look. It's not on your list of things you've checked (although your singing may have been off key enough to make the problem worse...)
BC_ZX3 is offline
Old 04-20-2013, 06:59 PM   #62
gary the wolf
Fan#: 101265
What I Drive: 2003 white stationwagon
FF Reputation: 1 gary the wolf Good Standing Member
l mentioned those coil wires before,,happened to me,,wire came apart,,red l think
gary the wolf is offline
Old 04-29-2013, 12:57 PM   #63
spivonious
Fan#: 86969
What I Drive: 2003 Twilight Blue ZX3, 2.0L
FF Reputation: 1 spivonious Good Standing Member
Sounds like a bad coil pack to me. I had the same issues. I really thought it was something with fuel delivery, but a new coil pack fixed it. Although, I had the CEL come on with a cylinder misfire code.
spivonious is offline
Old 04-29-2013, 01:00 PM   #64
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,291, Level 46
Points: 5,291, Level: 46 Points: 5,291, Level: 46 Points: 5,291, Level: 46
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Check for hairline cracks on the coil
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 04-29-2013, 03:27 PM   #65
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
Smurfsmack......lol....try unplugging the vacuum hose on top the egr valve and just plug the hose with something.... its possible that the egr valve is opening when it shouldn't.....could cause the problem. Here's the deal. At this point, you know there is a problem AND when it'll happen.....so you have to think outside the box. You have either a air, fuel, or spark issue.....its up to you to find out exactly which area is the problem child. I would start by checking some KEY ground wires that relate to the big 2 or the 3"...( air-fuel-spark). Fuel pump relay.....wiring harness to fuel pump.....coil wiring harness...connector in general.....broken or corroded wiring.....egr valve....vacuum leaks......etc. You have to check and inspect everything...
Sent from my SPH-D710 using FF Mobile
SR#269 'I know where the 'zetec' kicks in....'
FocusRus is online now
Old 04-29-2013, 11:47 PM   #66
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
Could be almost any electronic part on car since seems to be heat related.
If you are running fuel with ethanol in it, well, your water source there.
I'd be looking for some way to check fuel pressure at the time the problem occurs. At my house, that would mean tapping physically into the fuel rail, which I have plans of doing on both mine someday. Electrical deduction of fuel pressure is stupid as the sensor can lie.
Had a Tempo once that acted just like this car, ran fine 99% and then out of the blue the crap running and no power. Fuel pump worn out, but that one I could check.
amc49 is offline
Old 05-02-2013, 12:09 PM   #67
smurfsack
Fan#: 110575
What I Drive: 2003, beige,se 2.0 split port
FF Reputation: 1 smurfsack Good Standing Member
thank you i will this weekend
smurfsack is offline
Old 05-02-2013, 12:11 PM   #68
smurfsack
Fan#: 110575
happened again this morning....in trafiic....seems to only happen when im in traffic or in the heat of the day on a long road trip,(after i get off the freeway)
i may just need to set this car on fire and collect insurance haha
Old 05-02-2013, 12:22 PM   #69
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
how old are your 02 sensors? I had this issue with a bad sensor.. the idle would just die off when i came to a stop.
SVT header kit, 2.25 MBRP cat-back & flex, r/t high flow cat. aem cai, frpp kit
For Sale: Rear bumper(stock). SVT side skirts FS as well. Buy em!!!!
nov173 is offline
Old 05-29-2013, 11:17 PM   #70
smurfsack
Fan#: 110575
ok update time........ my fans are not turning on...wtf? i sat there and watched them until the car got hot and died, they never switched on. this could be why after long drives it dies while sitting still in idle. and why it dies when im sitting in traffic. what do you guys think
