?? On cam and jrsc+bbk - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2013, 08:08 PM   #11
02_z_x_3
Fan#: 53977
What I Drive: 02 zx3
Points 4,316, Level 41
Points: 4,316, Level: 41 Points: 4,316, Level: 41 Points: 4,316, Level: 41
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 3%
FF Reputation: 9 02_z_x_3 Good Standing Member
Buy-Sell-Trade Rating: (13)
I'm curious, what grind did you go with? 2291017? If so I hope you bought the springs to go with them. I have this set and just spent three days in the garage assembling and disassembling the head to find out the stock valve springs were binding up and not allowing the cam to roll over any further. I swapped out the stock springs for the pac springs I bought with the cams and it rolled over like it should have.
02_z_x_3 is offline
Old 04-12-2013, 08:11 PM   #12
02svtf300
02svtf300's Avatar
Fan#: 83769
What I Drive: 2002 sonic blue SVT(moded)
FF Reputation: 2 02svtf300 Good Standing Member
I'm not shur of the ## an yes got cat springs an retainers... Valves also
Sent from my HTC6435LVW using FF Mobile
02 sonic blue svtf...< modified addiction < DD
88 bronco II (x2)... < the twins
00 yamaha banshee... <will be the end of me
02svtf300 is offline
Old 04-12-2013, 08:22 PM   #13
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
Originally Posted by 02svtf300 View Post
From my under standing the cams have a short duration and hight lift, an designed to have zero valve overlap.
FYI the jrsc and intake mani has been port an polished... Would have meth kit too
Increases in duration up to and including small amounts of overlap won't hurt. On a DOHC engine, you can mess with the overlap to help things as well. I could run tiny cams with very little duration and the boost would skyrocket simply because the air coming out of the blower would stack up on the back of the valve longer. Then the ideal gas law takes over.
P - pressure
V - volume
n - number of moles (amount of air)
R - constant to make different units of measure work
T - temperature
PV=nRT
It is a balancing act. So if pressure goes up on the left side of the equation, and volume is fixed (not a variable intake manifold) then in order for the equation to balance, something on the other side must go up as well. Constants are constant, so either the amount of air or temperature must increase. On a fixed displacement blower the volume of air doesn't go up, so temps must increase. No matter what type of engine you are running, you don't want to raise inlet temps.
This is why you want to decrease boost pressure to the point of not wasting energy or reducing blower flow on a JRSC or any other positive displacement system.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 04-12-2013, 08:32 PM   #14
02svtf300
02svtf300's Avatar
Fan#: 83769
I really can't make much of this but...
Ford ST170, VVT
I4cyl 2.0L 16v DOHC (DTx/DTx)
intake exhaust
camshaft data:
lash ramp : 0.25mm 0.25mm
duration @ 0.1mm : 277 262
duration @ 1.0mm : 243 224
valve lift : 12.00mm 10.80mm
cam lift : 12.00mm 10.80mm
lobe angle : 110 120
timing @ 1.0mm : 11 / 52 52 / 8
valve lift @ TDC : 2.65mm 0.55mm
Old 04-12-2013, 08:35 PM   #15
02_z_x_3
Fan#: 53977
Forum Activity 3%
are you keeping vct or deleting it? I deleted mine.
02_z_x_3 is offline
Old 04-12-2013, 08:38 PM   #16
02svtf300
02svtf300's Avatar
Fan#: 83769
Deleted!
Old 04-12-2013, 08:47 PM   #17
02_z_x_3
Fan#: 53977
Forum Activity 3%
i thought it was too much of a pain.
02_z_x_3 is offline
Old 04-12-2013, 08:51 PM   #18
02svtf300
02svtf300's Avatar
Fan#: 83769
Just makes tuning easier from wat I've been told
Old 04-12-2013, 09:37 PM   #19
teamDFL
teamDFL's Avatar
Fan#: 92060
More reasons to run the same flow at less boost:
Those are charts from Eaton via Magnusson.
teamDFL is offline
Old 04-12-2013, 09:56 PM   #20
02svtf300
02svtf300's Avatar
Fan#: 83769
So it would take a lot of time but if I got the timing right with the cams an SC it could have good results.
But sounds expensive time on a dino!
Would 300hp be unreasonable?
