?? On cam and jrsc+bbk - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 04-12-2013, 01:43 PM   #1
02svtf300
02svtf300's Avatar
Fan#: 83769
What I Drive: 2002 sonic blue SVT(moded)
FF Reputation: 2 02svtf300 Good Standing Member
I've done ordered cat cam turbo grind for a turbo setup
My question is what can I expect to get with a fully built motor turbo cams and jrsc+bbk
Also with supertech 85.5 over bore low c/r.
Am I going to have to get my head decked an run thinner HG going from a turbo build to a SC set up
Sent from my HTC6435LVW using FF Mobile
02 sonic blue svtf...< modified addiction < DD
88 bronco II (x2)... < the twins
00 yamaha banshee... <will be the end of me
02svtf300 is offline
Old 04-12-2013, 01:53 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
In my opinion you would want to run lower compression with SC as well , the problem is the SC out for the Focus dont move a lot of air
Bigger cams will lower the amount of boost the small jrsc SC will be able to make , go turbo and save your self a lit of time and frustration
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-12-2013, 02:08 PM   #3
02svtf300
02svtf300's Avatar
Fan#: 83769
... The motor not built yet, parts have already just been ordered.
So stay with turbo build plans...
Or if I did go with SC using the svt cams would be better
One more question... Can I break the new in about 1k, motor built for a turbo without a turbo. just run my svt header an exhaust.
Old 04-12-2013, 02:21 PM   #4
1turbofocus
FF Affiliate
Fan#: 1123
I wouldnt do cams with any boost , Yes you can run a Boosted built engine NA if you choose to , I would make sure the tune is safe
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-12-2013, 02:29 PM   #5
02svtf300
02svtf300's Avatar
Fan#: 83769
Only reason I'm wanting to break it in NA is because. I'm still missing some pieces of the puzzle for the turbo kit.
An I have a NA tune from you already... Will probably going though you for turbo tune too
Old 04-12-2013, 02:39 PM   #6
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
But don't forget, this is a good thing.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 04-12-2013, 03:40 PM   #7
02svtf300
02svtf300's Avatar
Fan#: 83769
^^ elaborate?
Old 04-12-2013, 05:11 PM   #8
1turbofocus
FF Affiliate
Fan#: 1123
How is that a good thing , If he is making say 10psi and say 220hp and adds cams and makes 8psi and 220 hp where did he gain the gains for the cost of the cam
Curious about your thinking ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-12-2013, 06:54 PM   #9
teamDFL
teamDFL's Avatar
Fan#: 92060
Short answer - PV=nRT
Long answer - Because it won't work that way. It is a positive displacement blower so it moves the same amount of air each revolution. So unlike a compressor, boost is nothing more than a measure of restriction after the blower. Boost causes higher drive losses and, more importantly, more heat. As you well know, that is the last thing a JRSC needs. For a roots blower, unless you go too far with the overlap and are therefore wasting energy, you want the highest power at the lowest boost level. This is why cams for roots blowers aren't the same as they are for compressors. If you add cams and lower the boost level, you will gain power from the loss in heat build, at the very least.
teamDFL is offline
Old 04-12-2013, 07:07 PM   #10
02svtf300
02svtf300's Avatar
Fan#: 83769
From my under standing the cams have a short duration and hight lift, an designed to have zero valve overlap.
FYI the jrsc and intake mani has been port an polished... Would have meth kit too
