control arm and rear rebuild - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2013, 06:27 PM   #11
cmb1120
Fan#: 113423
What I Drive: ZX4
FF Reputation: 1 cmb1120 Good Standing Member
Ya I will take a picture Tuesday. My jack is at my moms.
cmb1120 is offline
Old 04-12-2013, 06:51 PM   #12
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
Well, that doesn't sound as bad.
Excessive wear, at the level that can be controlled by more frequent tire rotation, isn't "urgent" at least.
Plenty of time to figure out how much is "needed" and what to do about it....
Cheers!
sailor is online now
Old 04-12-2013, 08:04 PM   #13
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,940, Level 74
Points: 12,940, Level: 74 Points: 12,940, Level: 74 Points: 12,940, Level: 74
Level Up 23% Completed
Forum Activity 99%
Just to add you could install toe-link's from massive or cfm & make rear toe adjustments super easy & make the rear of the car feel more positive.
felixthecat is offline
Old 04-16-2013, 01:08 PM   #14
cmb1120
Fan#: 113423
What I Drive: ZX4
here of pics of the rear left.
cmb1120 is offline
Old 04-16-2013, 11:24 PM   #15
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
seems like alotta rust for an '06, but then you do live in the rust belt.
the photos are kinda blurry. If you took them with a digital camera, can you replace them with ones shot in macro ("close-up") mode? Macro is sometimes designated by a flower icon. Shots of bolts & rubber would be helpful, as would a couple that are a little further away, to give us a "big picture" view of each suspension component. Even so, the best we're gonna be able to do is second-guess your mechanic.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 04-17-2013, 03:22 AM   #16
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
Well, sounds about what I would expect.
By the time the bushings in any one rear control arm are wasted, the rest are not far behind. I wouldn't do one new lower control arm and leave the other waiting to fail. It's rusty, so I would expect to have to cut at least one bolt off. Those bolts, like many of Ford's, should be replaced anyhow.
If it were mine, I would expect to replace all bushings and fasteners, including the cam bolts for setting the rear toe-in. Replacing the bushings means new control arms.
elsolo is offline
Old 04-17-2013, 11:02 AM   #17
cmb1120
Fan#: 113423
What I Drive: ZX4
these are what the bolts look like on rear lower control arms. I just sprayed them with pb oil. I cannot get them to turn at all. Any ideas that do not involve using an axle grinder or sawzall?
cmb1120 is offline
Old 04-17-2013, 01:14 PM   #18
my_beautious_ZX3
Fan#: 32386
ahhh...beautiful pics! Isn't macro mode a minor miracle?!
penetrating lube is definitely worth a shot, esp. considering your vehicle isn't very old.
Unfortunately though, those bolts tend to seize on the inside of the LCA, so a gallon of PB might not even work. But, who knows - reapply the PB and let it soak for a couple of days; then take a whack at the bolts again. Don't compromise your personal safety.
As for which power tool is best to use, I personally can't advise, because at this point I said "f--- it!" and let my mechanic do it; he later said it was one of the worst jobs he's encountered. Search the forum archives - there are posts by folks who have done this dirty deed, but I don't know how much detail they mention. You could always PM them for details.
Regardless of which method you use, note how poorly the cross member in your photo is made! Very thin sheet metal and further compromised by corrosion. So, take care not to damage it when destroying those bolts. Since the LCA is gonna be trashed anyway, focus your frustration in its direction.
Old 04-27-2013, 09:27 PM   #19
TEK30001
Fan#: 94657
What I Drive: 2006 Focus ZX5
Points 20, Level 1
Points: 20, Level: 1 Points: 20, Level: 1 Points: 20, Level: 1
Level Up 39% Completed
FF Reputation: 1 TEK30001 Good Standing Member
What is the best Rear Toe Control Arms and Adjustable Camber Arms
I am looking to get:
http://www.massivespeedsystem.com/_m...s/g-62761.aspx
And
http://www.massivespeedsystem.com/_m...s/g-62727.aspx
For the most part I get all my thing from this web page or is there a better website?
TEK30001 is offline
Old 04-28-2013, 08:21 AM   #20
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
And
Those will work. You'll find the toe-links will give the rear end more responsive.
Try CFM= centralfloridamotorsports, Steeda, Fwerks, Tirerack.
