TSB 13-4-5 Intermittent Transmission Clutch Shudder - DPS6 Automatic Transmission - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 04-11-2013, 12:30 PM   #1
Hypnotoad
Fan#: 85864
What I Drive: 2012 Sterling Grey Focus SEL
FF Reputation: 3 Hypnotoad Good Standing Member
This TSB contains no new causes or solutions to the transmission shudder issue but it provides techs with a way to measure if the shudder is beyond a normal range for clutch engagement.
I won’t reprint the TSB here because of copyright, and it contains an embedded picture, but here is the TSB in a nutshell:
The issue is: Some 2011-2013 Fiesta and 2012-2013 Focus vehicles equipped with a DPS6 automatic transmission may exhibit an intermittent transmission clutch shudder on light acceleration from a stop.
Here is a synopsis of the service procedure:
Reprogram the PCM/TCM with the latest calibration files.
Initiate adaptive learning for the transmission range sensor, shift drum, and clutch.
Perform an adaptive drive cycle on vehicle.
If shudder condition is eliminated then release vehicle, otherwise:
With an IDS data logger connected, drive vehicle while monitoring APP (Accelerator Pedal Position). Keep APP between 18-30% and record a shudder event.
Use the playback feature of the IDS to graph the ISS (trans. Input Shaft Speed) and locate the shudder event on the graph. The shudder looks like a bulge of ringing waves on an otherwise straight ramp of increasing RPM (like a pig in a python or a small earthquake on a seismograph).
Measure the high and low peaks of the waves in the bulge to determine the maximum difference in RPM during the shudder.
If the maximum RPM difference during the shudder is less than 250 RPM then “no further action required. Clutch engagement shudder is operating within expected limits and a clutch replacement will not improve operation”, otherwise “replace the clutch, inner input shaft
and outer input shaft case seal.”
Hypnotoad is offline
Old 04-11-2013, 12:33 PM   #2
cappa
cappa's Avatar
Fan#: 85229
What I Drive: 2000 VW Golf / 2012 Ford Focus Ti
FF Reputation: 1 cappa Good Standing Member
why would there be a copyright issue for a TSB, when TSB should be and is public knowledge?
cappa is offline
Old 04-11-2013, 12:41 PM   #3
PratoN
PratoN's Avatar
Fan#: 88058
FF Reputation: 10 PratoN Great Standing Member
A TSB should be public knowledge, but they're not.
EDIT: I stand corrected?
http://www.autoguide.com/auto-news/2...he-public.html
Also, if they reset the car before they test the shudder, I could see there being some issues as a lot of people don't get the shudder until after a few hundred miles from the reset. I might consider buying one of those OBD bluetooth things.
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at v3.6 91k miles and counting...
PratoN is online now
Old 04-11-2013, 05:49 PM   #4
Strix
Fan#: 85696
What I Drive: Not a Ford
FF Reputation: 0 Strix Poor Behavior Needs Improvement
My car works much better for a brief time after being reset (Except for the vibration that Hines Park Ford installed. That does not go away with software changes.) I agree that this is a concern. If they reset before testing all the time, they may never encounter certain problems.
My main complaint (gutlessness and poor drivability that makes me hate the car) doesn't occur until the ECM/TCM notice the clutch slipping and start remapping the throttle and shift points to avoid overheating the slipping clutch.
I don't have much in the way of shudder, tbh... but I do have a lot of "OMG YOU STUPID CAR WHY CAN'T YOU KEEP UP WITH THAT '87 CAVALIER IN FRONT OF US!!!"
It's like the engine output settings available to my right foot go: 1%, 2%, 3%, 80%, 90%, 100%.
There's very little available in the way of moderate acceleration. It's all or nothing. You're either gaining on the car in front of you, or falling behind. Matching their speed between 10 and 50 MPH is extremely difficult.
This is not the sort of thing that is easily noticed on a short test drive... but makes for a miserable driving experience as time goes on.
Strix is offline
Old 04-11-2013, 06:56 PM   #5
BlazeFocus
BlazeFocus's Avatar
Fan#: 104991
What I Drive: _
FF Reputation: 2 BlazeFocus Good Standing Member
CAFE standards are a b&%ch and then you die.
I imagine that it is becoming harder and harder for engineers to meet
fuel efficiency requirements whilst maintaining some semblance
of an enjoyable driving experience and going to a transmission
setup that ditches the torque converter (DCT) appears to have it's drawbacks..
Freedom of speech is a protected right in this U S of A. Discredit overly sensitive mother hens, ignorance and butt-hurt; Recognize and reward real substance..
BlazeFocus is offline
Old 04-11-2013, 08:00 PM   #6
Tubeway Army
Fan#: 111167
What I Drive: 2013 Focus Titanium DCT Dilemma
FF Reputation: 1 Tubeway Army Good Standing Member
That explains mine too, the only way it can even come close is by dropping it into sport mode or using seletshift. In stop and go traffic, D mode is painful, lethergic, grinds, shudders and etc, the Powershit transmisssion has a mind of it's own.
Tubeway Army is offline
Old 04-12-2013, 08:46 AM   #7
PratoN
PratoN's Avatar
Fan#: 88058
My car has a tendency to not downshift which pretty much matches what you're saying. I'll go to merge on the highway and I'll give it like 80% throttle and I won't move faster than a snail's pace. Then I mash the pedal to the floor and it downshifts 2 gears to like 6k RPM. Why is it so hard for it to just downshift one gear at 80% throttle? It may be because I ease onto the accelerator instead of going from 0 to 80% in one motion.
Old 04-12-2013, 09:12 AM   #8
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
FF Reputation: 4 slybarman Good Standing Member
I am sure you have noticed that the shift points totally change based on how hard you push down on the accellerator. It kinda makes sense in that if you drive with a light foot the car figures you are not in a hurry and gives shifts for best fuel economy. If you mash the pedal, it figures you want to get somewhere now and shifts to keep you in the power band - at the expense of fuel economy.
slybarman is online now
Old 05-11-2013, 10:15 PM   #9
2013FocusTitanium
Fan#: 114498
What I Drive: 2013 Titanium White Platinum
FF Reputation: 2 2013FocusTitanium Good Standing Member
First off, here is a direct link to the TSB: http://www.fordservicecontent.com/pu...sb13-04-05.pdf
I bought a '13 Focus Titanium Hatch 2 weeks ago (didn't know anything about this issue) and my wife had a shudder crisis this week at about 700 miles. Dealer seemed to be expecting us to bring the car in. Handled it graciously with a loaner and executed this TSB. 24 hours later, got our car back. I'm sensing the key is to bring it straight in to the dealer at the first sign of shudder so the trans. doesn't damage the clutch. Seems to be running smoothly now and we might even be getting better mileage - we'll see how it goes and if the problem comes back I'll repost.
2013FocusTitanium is offline
Old 05-12-2013, 11:06 AM   #10
Hypnotoad
Fan#: 85864
The transmission isnít damaging the clutch, itís a leaking shaft seal that is causing trans fluid to contaminate the clutch pads. Programming will not fix it, although going through an adaptive learning cycle may make the problem diminish for a while, as others have found.
As for going to the dealer at the fist sign of shudder, your dealer is a rare exception, as most dealers, mine included, give you the bumís rush unless the shudder is so bad the car is shaking to pieces, or fluid is practically pouring out the bottom of the bell housing.
