instrument cluster swap. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2013, 10:56 AM   #11
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,441, Level 75
Points: 13,441, Level: 75 Points: 13,441, Level: 75 Points: 13,441, Level: 75
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 99%
Strange, swap was totally plug 'n play in my '04 (mileage stored in cluster BTW as prev. mentioned). Hope someone who did this on your "MkII" version chimes in, don't remember any comments about those being any different.
luck!
sailor is online now
Old 05-01-2013, 02:43 AM   #12
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
Points 625, Level 12
Points: 625, Level: 12 Points: 625, Level: 12 Points: 625, Level: 12
Level Up 50% Completed
FF Reputation: 3 Kodyston Good Standing Member
Originally Posted by Alptbird View Post
really when i install it it look like it is working fine. Lights up does the needle sweep like it should. even dings with the door chime. Just when i try to turn the Key No start. it is almost like the keyless entry brain is held in the cluster and I have to cycle the alarm. but this car is a "S" model and has no keyless entry. i have had the same trouble with an old Nissan and ford Tbird I just had to use the door key to cycle the lock on the driver door and it reset then every thing was cool but this car isn't equipt that way.
Hmm... that's odd. I have no clue then. lol sorry buddy. hopefully someone chimes in that might know.
Kodyston is offline
Old 03-20-2014, 09:26 AM   #13
DPDISXR4Ti
Fan#: 43470
FF Reputation: 1 DPDISXR4Ti Good Standing Member
I've read a couple of these threads about the start function being inhibited after an instrument cluster swap. I suspect that the issue is that the "new" cluster needs to be from a car with the same transmission type (i.e. manual vs. automatic). Can someone confirm?
Brad
DPDISXR4Ti is offline
Old 03-20-2014, 10:51 AM   #14
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
Doesn't make a difference, in the 2000-2007 models anyway. I got mine out of an auto in the junkyard! (I have a manual)
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 03-20-2014, 12:47 PM   #15
boardliquid01
boardliquid01's Avatar
Fan#: 114884
What I Drive: 2003 Silver Ford Focus SVT EAP
Points 573, Level 11
Points: 573, Level: 11 Points: 573, Level: 11 Points: 573, Level: 11
Level Up 46% Completed
FF Reputation: 2 boardliquid01 Good Standing Member
2000-2007 passive anti theft is present only in the PCM. 2008-2011 is present in the IC and PCM. Both the modules store the key codes and then exchange them in a check when you try to start it.
So in short, your 2008 IC is not plug and play. You'll need to have a dealer perform a programmable module installation(PMI) using your old IC to configure the new one. Or you can have someone like the dealer or key shop erase and program the keys as if you were installing new keys. This will put the key code in the new IC that matches the PCM.
boardliquid01 is offline
