08 Focus Forged Crank? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 04-10-2013, 02:24 PM   #1
08FocusSESTurbo
08FocusSESTurbo's Avatar
Fan#: 77861
What I Drive: 2008 Focus SES Turbo
Points 313, Level 6
Points: 313, Level: 6 Points: 313, Level: 6 Points: 313, Level: 6
Level Up 26% Completed
FF Reputation: 1 08FocusSESTurbo Good Standing Member
Does anyone know if the 08 Focus has a forged crankshaft?
I know FSWerks have built plenty of cars with the stock crank and havent had any problems.
I heard the earlier versions were not forged but the later cars had a forged crank not sure which years or if its true or not, just trying to clarify if it is or not if anyone knows.
08FocusSESTurbo is offline
Old 04-10-2013, 04:06 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Wow, forged cranks, but not forged pistons= na, can't be. I'll take forged pistons w/ a cast crank.
felixthecat is offline
Old 04-23-2013, 12:52 AM   #3
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
i ones heard this too a long time ago but couldnt find the post
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 04-23-2013, 07:06 AM   #4
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
This is the setup most people do.
I believe you will break many other things before the crank would go. I'm not sure if I've seen any Duratec cranks break but I could be wrong.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 04-23-2013, 08:08 AM   #5
Top Speed
Top Speed's Avatar
Fan#: 77307
What I Drive: 02 SVT, 07 ZX3, 04 Sedan, 02 ZX3
Points 7,920, Level 59
Points: 7,920, Level: 59 Points: 7,920, Level: 59 Points: 7,920, Level: 59
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 3 Top Speed Good Standing Member
The stock 08 crank is cast. But I have personally made over 650 whp on a stock cast crank
Sent from my DROID RAZR using FF Mobile
Top Speed is offline
Old 04-23-2013, 01:20 PM   #6
08FocusSESTurbo
Fan#: 77861
Points 313, Level 6
Yea I havent beenable to find the info again either, Im kinda thinking that maybe the Ford MZR's are all cast and the Mazda MZR's are were the forged were changed but IDK for sure.
Im not concerned about it breaking but from what Ive read theres about a 5lbs difference in the 2 and I feel having less rotational mass would be beneficial. That and if your going to do an engine build why not go all the way, I mean really whats another $325 or so on an engine build? That an if no one ever does it then theres no way to prove what the benefit of having 1 would be. Maybe I just prefer to try it cause its different and I don't want to have the exact same thing as everyone else.
Thanks for confirming that. Would you happen to know if all Ford MZR cranks are cast? An do you know what the weight differences would be for cast and forged for both 2.0 and 2.3 cranks? It would be nice to know even if it doesn't make much of a difference.
Old 04-23-2013, 02:38 PM   #7
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
The Cossie forged cranks are lighter then the stock cranks, & they'll really lighten your wallet too. I'd just start out w/ a ranger crank. Its not like your running formala alantic motor. I'd spent the money on rods/pistons & valve's.
Old 04-23-2013, 03:27 PM   #8
08FocusSESTurbo
Fan#: 77861
Points 313, Level 6
Your still thinking 2.3 only although cossie does make 1 for the 2.0 but yes the cossie is pricey and may not be worth the money and the 5lbs difference I mentioned is in the ranger crank and standard d23 crank so yes using the ranger crank for a d23 built would be better then spending 3k on 1 part, enless your going all out, however d20 owners have the option for a forged crank for about $325, it can be found here, at least it says it forged (IDK)
http://gp-werks.com/Duratec-20L-Forg...orgedcrank.htm
But if it is then I feel it would be more suited for a daily driven, high boost/rpm car and would still give you less rotational mass.
Old 04-23-2013, 03:35 PM   #9
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Yeah, Thats what I'd do for a 20 motor, but there's more to be had w/ using a 23 to begin w/ & add a ranger crank. Why don't they do a 23 crank, at similar price?
Old 04-23-2013, 05:46 PM   #10
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,295, Level 98
Points: 28,295, Level: 98 Points: 28,295, Level: 98 Points: 28,295, Level: 98
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
The crank from a 2009+ MX5 Miata will fit and is factory forged. Confirmed that through GP-Werks last year. It is a little heavier though.
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
