Is Premium Gas ok? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-15-2013, 06:10 PM   #21
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,906, Level 74
Points: 12,906, Level: 74 Points: 12,906, Level: 74 Points: 12,906, Level: 74
Level Up 14% Completed
Forum Activity 99%
Originally Posted by dooor View Post
Felix, Help a dummy. What is "do a bsd"? Thanks
No dummy's here, We're all here to learn. BSD= Balance shaft delete. 23's/25's have a pr of balance shafts in the bottom of motor, which is driven off the crank, to smooth out the motor. The 23/25's having a longer stroke. You have a '07 zx3, so that means you have a 20 motor, so you don't have to deal w/ that, till you install a 23. It removes rotational & static weight, which makes the motor more responsive.
felixthecat is online now
Old 04-17-2013, 02:57 PM   #22
dooor
Fan#: 51395
What I Drive: 2007 se stick
Points 922, Level 16
Points: 922, Level: 16 Points: 922, Level: 16 Points: 922, Level: 16
Level Up 22% Completed
FF Reputation: 1 dooor Good Standing Member
Thanks
dooor is offline
Old 04-17-2013, 05:54 PM   #23
metrognome
Fan#: 112081
What I Drive: 2007 Silver ZX3 SE
FF Reputation: 5 metrognome Good Standing Member
From wikipedia: http://en.wikipedia.org/wiki/Octane_rating
<Octane ratings are not indicators of the energy content of fuels. (See section 4 of this page and heating value). It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. Where the octane number is raised by blending in ethanol, energy content per volume is reduced. >
<Many high-performance engines are designed to operate with a high maximum compression, and thus demand fuels of higher octane. A common misconception is that power output or fuel efficiency can be improved by burning fuel of higher octane than that specified by the engine manufacturer. The power output of an engine depends in part on the energy density of the fuel being burnt. Fuels of different octane ratings may have similar densities, but because switching to a higher octane fuel does not add more hydrocarbon content or oxygen, the engine cannot develop more power.>
Totally amazing about gas. Draw a 1/2 inch square and with the tip of the pencil, place 15 'dots' inside the square. One of those dots is gas. The rest (approximately) are air. That's the mixture feeding a cylinder each cycle.
Run the lower octane and trust the anti-knock sensor. Unless you are running a modified engine with high compression pistons or you have an air pump (compressor).
btw, I read that Chevron gets from 'the top' at the refinery, which is a finer and cleaner blend, with less contaminants that are found in 'the dregs' that other brands get out of the same batch.
Techron will keep the injector nozzles clean.
I have no commercial connection, just years working as a mechanic on small engines that have carburetors with main jet orifices so small that a piece of hair blocks half the fuel delivery to the cylinder.
If you can buy gas with no ethanol that would be best power and mileage.
metrognome is offline
Old 04-17-2013, 06:23 PM   #24
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,182, Level 95
Points: 25,182, Level: 95 Points: 25,182, Level: 95 Points: 25,182, Level: 95
Level Up 84% Completed
Forum Activity 4%
I didn't pay attention to Tapatalk, or I would have realized that my discussion is invalid because I own a different generation Focus.
Carry on
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 05-02-2013, 09:18 PM   #25
jugglethese
jugglethese's Avatar
Fan#: 108852
What I Drive: 2007 focus gloss black SAP zx3
Points 1,619, Level 23
Points: 1,619, Level: 23 Points: 1,619, Level: 23 Points: 1,619, Level: 23
Level Up 19% Completed
FF Reputation: 1 jugglethese Good Standing Member
Just to add, i asked tom to give me a 91 octane tune. He said theres no point it wouldnt do anything for my car, untill i did more upgrades. I have a header, cai, cat back.
So i guess you need some head work and some appropriate pistons.
jugglethese is offline
Old 05-03-2013, 11:25 AM   #26
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
A logical upgrade would be a 23 motor or turbo yours.
Old 05-03-2013, 11:34 AM   #27
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
Points 4,169, Level 41
Points: 4,169, Level: 41 Points: 4,169, Level: 41 Points: 4,169, Level: 41
Level Up 10% Completed
FF Reputation: 6 RonMaiden Good Standing Member
More power with higher octane? Are we talking power like you'd see a diff in the 1/4 mile using 93 vs 87? Or is it just a tad better throttle response and smoother power delivery? MotorTrend turned a 15.8 with a SE equipped with a 5 speed and 87 octane and that's one of the quicker numbers I've seen turned with a stock MK3.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 05-03-2013, 11:57 AM   #28
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Points 1,603, Level 23
Points: 1,603, Level: 23 Points: 1,603, Level: 23 Points: 1,603, Level: 23
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 3%
FF Reputation: 3 replica81 Good Standing Member
That's odd.
Higher octane raises the detonation threshold of the motor. Meaning, there should be room to advance the timing and other ECU controlled stuff. Maybe Tom will post in here and explain this further?
SR #272
Beer and Metal.
replica81 is offline
Old 05-03-2013, 01:58 PM   #29
jugglethese
Fan#: 108852
haha if i come across one ill pick it up, ive been looking but nothing cheap enough yet ;)
Old 05-03-2013, 02:03 PM   #30
jugglethese
Fan#: 108852
Originally Posted by replica81 View Post
That's odd.
yeah i would like to know myself, because i thought it might open up a couple more pony's. but the way my friends dad explained its burns colder and prevents misfires. nothing much to gain from it, untill you get work done to the engine that requires it. but even then its not the gas thats gonna get that extra power, its the parts you just put in.
He could be compleatly wrong and so could I.
If someone knows better let us know :)
