Is Premium Gas ok? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-13-2013, 08:18 PM   #11
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
If you read the owners manual it actually says that the use of premium will make it run worse under certain conditions. Those that say they get better mpg with it are fooling themselves. High octane fuel burns SLOWER and not as easily as lower octane that is the point of it.
don627 is offline
Old 04-14-2013, 12:28 AM   #12
drummer829
Fan#: 71497
What I Drive: 2005 liq grey ST
FF Reputation: 1 drummer829 Good Standing Member
How does a simple tune then make it ok for the car to run premium?
drummer829 is offline
Old 04-14-2013, 09:26 AM   #13
DerbyCityGinger
DerbyCityGinger's Avatar
Fan#: 106672
What I Drive: 2005 Sonic Blue ZX5
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 DerbyCityGinger Good Standing Member
Unhappy
I ran 93 without a tune for two or three years. About a month ago I switched back to Regular 87, and I'm not noticing any difference.
I can only imagine what parts I could've bought with that money...
Focus 1: 2005 Sonic Blue ZX5 SE auto
Focus 2: 2007 Aqua Blue ZX5 SES auto (girlfriend's)
DerbyCityGinger is offline
Old 04-14-2013, 10:55 AM   #14
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,182, Level 95
Points: 25,182, Level: 95 Points: 25,182, Level: 95 Points: 25,182, Level: 95
Level Up 84% Completed
Forum Activity 4%
While you are correct about that being the 'point of it', you are incorrect as to thinking that it isn't beneficial. Because higher octane fuels have a more controlled burn, spark timing can be advanced in order to effectively extract more power than lower octane fuels. The sooner you can begin fuel burn in the compression stroke, the more fuel can be burnt for power.
Low octane fuels burn less predictably, so timing has to be retarded in order to prevent pre-detonation or 'pinging'. Because this burn is started later in the compression cycle, more of the fuel is still being burnt off as the piston has already begun it's downward movement on the power stroke. This is actually wasted energy. That is the price paid for using the less expensive, higher volatile fuel.
That being said, I don't think that any of the Focus line had fuel mapping strategies to take advantage of anything over 87 prior to the Mk3-but I don't know 100%. If not then the use of anything over 87 is indeed a waste because the ECU cannot effectively adjust the timing to take advantage of the higher octane. You will end up with the same result-excessive fuel being burned in the power stroke due to not being able to get it burning early enough in the compression stroke.
In regards to the higher-octane burning cleaner...the truth lies more in the fact that the more expensive fuel usually gets more additives (and this is dependent on the brand that you use). More additives can be great, but you can be just as equally hurting yourself with the higher cost fuel not being completely burnt. If there is no fuel mapping for above 87, I would recommend running only 87 and then using a fuel system cleaner (I prefer Chevron with Techron) once every 15,000 miles or longer. You will have the most 'bang-for-your-buck' (pardon the pun)
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 04-15-2013, 12:16 PM   #15
Bobby95
Fan#: 101347
What I Drive: 2002 zinc yellow zx3
Points 214, Level 4
Points: 214, Level: 4 Points: 214, Level: 4 Points: 214, Level: 4
Level Up 28% Completed
FF Reputation: 1 Bobby95 Good Standing Member
Originally Posted by drummer829 View Post
Which tune would you recommend. I've seen many people rave about toms tune.
I personally don't have a tune but I have heard the two best ones are Toms tune and fswerks randy's tune.
Bobby95 is offline
Old 04-15-2013, 12:41 PM   #16
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,932, Level 74
Points: 12,932, Level: 74 Points: 12,932, Level: 74 Points: 12,932, Level: 74
Level Up 21% Completed
Forum Activity 99%
It depends on what forum your on. Tom's on here & Fwerk's is on FJ.
felixthecat is online now
Old 04-15-2013, 12:43 PM   #17
Bobby95
Fan#: 101347
Points 214, Level 4
After countless hours on the internet that's my final thought too
Bobby95 is offline
Old 04-15-2013, 02:52 PM   #18
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
Points 8,314, Level 61
Points: 8,314, Level: 61 Points: 8,314, Level: 61 Points: 8,314, Level: 61
Level Up 55% Completed
FF Reputation: 7 indy_11 Good Standing Member
Buy-Sell-Trade Rating: (4)
I've heard tom is better with zetecs then duratecs. I'd say go with fswerks. They might charge you to get it tuned but it's not like you would be doing it everyday and they're good quality. not saying tom isn't but sometimes you gotta pay to play.
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 04-15-2013, 03:25 PM   #19
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,808, Level 100
Points: 51,808, Level: 100 Points: 51,808, Level: 100 Points: 51,808, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
Just to keep my hat in the pot , I know Duratec tuning as well as anyone does , with tuning from me you get a
Full custom tune
Free tune updates as you add more NA mods fs charges up to 350.00 more
Datalogging services where I take over your laptop and set up your datalog list and do the first datalog just like sitting in the car with you so you understand how to use everything , not offered through fs
If interested and have any questions please let me know
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-15-2013, 03:53 PM   #20
dooor
Fan#: 51395
What I Drive: 2007 se stick
Points 922, Level 16
Points: 922, Level: 16 Points: 922, Level: 16 Points: 922, Level: 16
Level Up 22% Completed
FF Reputation: 1 dooor Good Standing Member
Felix, Help a dummy. What is "do a bsd"? Thanks
dooor is offline
