sputter when its hot out - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-10-2013, 11:48 AM   #1
jkliphouse
Fan#: 103513
What I Drive: 2000 lx
FF Reputation: 1 jkliphouse Good Standing Member
things i have done to car:
*reman head/1 piston and rod/all new gaskets/head bolts 2,000 miles since
*egr valve and tube
*plugs wires/coil pack
*timing belt and tensionor
*pcv valve
i travel one way to work about 40 miles...on a day its 85 out at about 30 miles car sputters to the point you have to pull over..if you restart car it will go a few more miles before you have to pull over again...i had the same problem with the other head also so when i put on reman head i checked all hose's which appeared to be good! car runs good in the winter...just when it gets warm out i cant figure this out doesnt make no dam since...iam tried of putting money in this dam car i should have just did engine swap instead of reman head any ideas?
jkliphouse is offline
Old 04-10-2013, 12:36 PM   #2
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 945, Level 16
Points: 945, Level: 16 Points: 945, Level: 16 Points: 945, Level: 16
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 3%
FF Reputation: 3 CotyM Good Standing Member
Do you have a CEL (Check Engine Light) ? It sounds like it could be a faulty sensor having trouble with heat...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
Old 04-10-2013, 12:44 PM   #3
jkliphouse
Fan#: 103513
i wish i had cel on...also i have changed fuel filter already
Old 04-10-2013, 01:11 PM   #4
CotyM
CotyM's Avatar
Fan#: 85558
Forum Activity 3%
Any steam/water or dark smoke coming out of the exhaust? More than normal anyway, it's quite common for motors to make a little water from the humidity in the air. Are you slowly losing coolant or oil?
The heat could be causing the head gasket to leak if it wasn't sealed properly... My only other guess would be the plugs, fuel pump or filter and the distributer... but you already replaced those...
Hatch Nation #32
CotyM is offline
Old 04-11-2013, 02:28 PM   #5
jkliphouse
Fan#: 103513
no steam/water and iam not losing any fluilds...havent done fuel pump or IAC or MAFS i just dont understand why it only does it when its hot!
Old 04-11-2013, 05:56 PM   #6
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,030, Level 74
Points: 13,030, Level: 74 Points: 13,030, Level: 74 Points: 13,030, Level: 74
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 04-11-2013, 06:39 PM   #7
gary the wolf
Fan#: 101265
What I Drive: 2003 white stationwagon
FF Reputation: 1 gary the wolf Good Standing Member
check coil connecter,,,under insulation, wire or wires may be partly broke through and when it heats up breaks contact,,check where it plugs into coil,,,bad area right there
gary the wolf is offline
Old 04-12-2013, 08:40 AM   #8
jkliphouse
Fan#: 103513
under insulation? did check coil connection appears to be good...its weird when it sputtters to the point it shuts off or if i shut it off and restart it i can step on the gas fairly hard and car will take out with no problems for a few miles and do it again...it almost like whatever it is gets reset or something i think maybe fuel pump?
Old 04-12-2013, 10:12 AM   #9
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
What I Drive: 2003 Liquid Grey ZX3
Points 2,453, Level 30
Points: 2,453, Level: 30 Points: 2,453, Level: 30 Points: 2,453, Level: 30
Level Up 2% Completed
FF Reputation: 1 03FocusZX3 Good Standing Member
I would have to say that your fuel pump is dieing. Seems to me that the fuel pump doesnt like the heat, just my 2cents
When I die, I want to go peacefully like my grandfather did, in his sleep, not screaming, like the passengers in his car.
03FocusZX3 is offline
Old 04-12-2013, 10:50 AM   #10
jkliphouse
Fan#: 103513
under insulation? did check coil connection appears to be good...its weird when it sputtters to the point it shuts off or if i shut it off and restart it i can step on the gas fairly hard and car will take out with no problems for a few miles and do it again...it almost like whatever it is gets reset or something i think maybe fuel pump? correct me if iam wrong wouldnt a mafs or iac valve throw a cel?
