Tuning Solution (Injected Engineering) - Page 137 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-18-2013, 04:01 PM   #1361
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,360, Level 42
Points: 4,360, Level: 42 Points: 4,360, Level: 42 Points: 4,360, Level: 42
Level Up 5% Completed
Forum Activity 4%
FF Reputation: 9 darkangelism Good Standing Member
Originally Posted by dbsimms63 View Post
But horsepower is the product of torque and RPM, so if you limit torque you'll limit the horsepower as well.
That's right, but peak HP tends to not be peak rpm, on other cars there is torque management that limits power above a certain rpm so that during the shift power is lower, so on ours say they raise redline and then at 7k rpm torque is limited to 175 so that during the shift torque is not so high that it damages the DCT then once the shift is done torque limit is removed. VW has a torque limit on the DSG that capped torque and tuners were disabling to get more power and tuning the shifts so it wouldn't grind. It was capped at 258 ft lbs, but tuners were getting to 368 safely. Injected might now if there is a cap from ford on the DCT for torque or if the DCT tuning would make going higher would be safe.
darkangelism is online now
Old 06-18-2013, 08:03 PM   #1362
timeatkuu
Fan#: 112507
What I Drive: '12 BlCndy Ti Hatch DCT w/ Hand Pkg
Points 110, Level 2
Points: 110, Level: 2 Points: 110, Level: 2 Points: 110, Level: 2
Level Up 20% Completed
FF Reputation: 1 timeatkuu Good Standing Member
Anyone else having trouble with the checkout process?
timeatkuu is offline
Old 06-18-2013, 08:54 PM   #1363
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,858, Level 25
Points: 1,858, Level: 25 Points: 1,858, Level: 25 Points: 1,858, Level: 25
Level Up 58% Completed
FF Reputation: 16 ShoOff Great Standing Member
what does the 180 degr. t stat do for us exactly?
ShoOff is offline
Old 06-18-2013, 09:44 PM   #1364
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 3 Juicedz Good Standing Member
Effectively lowers the operating temperature of the cooling system to 180 degrees. I hope they're planning to also add this into the tune so that the fans are programmed to turn on sooner. This would be highly valuable to you living in a hotter climate state such as Texas. Heat kills power.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 06-18-2013, 09:48 PM   #1365
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 551, Level 11
Points: 551, Level: 11 Points: 551, Level: 11 Points: 551, Level: 11
Level Up 2% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
I believe Aron already mentioned that the tune is provisioned to run the 180* tstat. It won't harm anything if you don't have it though.
Sent from my HTC Droid DNA
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 06-18-2013, 09:48 PM   #1366
carnage.exe
carnage.exe's Avatar
Fan#: 112726
What I Drive: '13 Perf. Blue Focus, '13 Dart GT
Points 1,553, Level 22
Points: 1,553, Level: 22 Points: 1,553, Level: 22 Points: 1,553, Level: 22
Level Up 53% Completed
Forum Activity 6%
FF Reputation: 1 carnage.exe Good Standing Member
No joke! I do feel like there has been a slight decrease in power since the heat and humidity started
carnage.exe is online now
Old 06-18-2013, 10:07 PM   #1367
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,149, Level 96
Points: 26,149, Level: 96 Points: 26,149, Level: 96 Points: 26,149, Level: 96
Level Up 80% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
^This. A 180 degree thermostat does nothing for you without changing the operating parameters of the fan. It will open sooner than a 195, but engine temps will rise to normal without earlier fan intervention. Injected's tune does cover that.
The most beneficial aspect of the lower operating temps will be seen by those that live in hot climates. Higher temperatures will cause detonation/ping due to higher cylinder temps, and when the ECU senses it it will pull timing. Less timing equals less than optimal power, but with a lower temperature thermostat and earlier fan intervention it won't occur as early. This allows for more advanced timing resulting in more power, more complete combustion, and better engine efficiency. Outside of that, lower temperatures overall will assist in making additional power.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 06-18-2013, 11:06 PM   #1368
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 4%
I plan on datalogging my temps without it and then see if I need it.
Old 06-18-2013, 11:32 PM   #1369
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 61%
I don't blame you and always advocate testing/research before purchase. Intake temps aren't going to be what you want to look for, you're going to want to be watching your water temps and timing.
September '13 ROTM
2014 FiST-
Old 06-19-2013, 12:39 AM   #1370
ShoOff
ShoOff's Avatar
Fan#: 109590
I really just want to hit the 200hp point. But then again I don't really know where I'm at now lol
Steeda CAI, Steeda STS, Magnaflo Cat Back Exhaust, Injected Tuner, Cobb Rear Motor Mount, TTR Upper Motor Mount, Injected 180 T Stat
ShoOff is offline
