PCV Valve - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2013, 10:24 AM   #11
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,548, Level 100
Points: 52,548, Level: 100 Points: 52,548, Level: 100 Points: 52,548, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
Originally Posted by FordManSVT View Post
I just got the cfm pcv delete kit and installed it today. Super clean part and came with new bolts. I got a new gasket from work( ford dealer). It's the same price as cfm but didnt have to pay shipping. I don't plan on running a catch can. The design lets the oil drip back I to the block and not blow out the tube. Free shipping on the PVC delete from cfm too.
I have learned over time that with boost even the c-f-m adapter can and will allow oil to be blown out , One way I have found that helps this it to run the hose to the PCV adapter up over the top raid hose , this allows for a longer steeper drain back for the oil and much much less oil comes out of the hose
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-14-2013, 12:26 PM   #12
FordManSVT
FordManSVT's Avatar
Fan#: 44253
What I Drive: 2003 ZX3 SVT Euro in Comp Orange
FF Reputation: 1 FordManSVT Good Standing Member
Very good to know Tom. I will do just that. I may run a catch can but I want to get this thing going again and finally finish tuning?
FordManSVT is offline
Old 04-15-2013, 11:51 PM   #13
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
Points 5,508, Level 47
Points: 5,508, Level: 47 Points: 5,508, Level: 47 Points: 5,508, Level: 47
Level Up 79% Completed
Forum Activity 3%
FF Reputation: 2 700whpfocus Good Standing Member
Buy-Sell-Trade Rating: (11)
Originally Posted by 1turbofocus View Post
Yes I do , You take the PCV out , cut the bottom and take out the plunger and spring and plug the hose to the intake , then replace the cut PVC with a 3/8 hose on it and run the 3/8 hose up over the top raid hose and down besides the trans to about 2 inches below the trans and tie it down
The valve cover should also not be going to anything that allows the engine air to get into the intake
do u have pics?
700whpfocus is offline
Old 04-16-2013, 12:03 AM   #14
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
from my pcv delete now I get massive oil spit out under high rpm wot, damn boost!!!
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is online now
Old 02-17-2014, 11:03 AM   #15
samili2109
Fan#: 105912
What I Drive: focus 2000 zx3
FF Reputation: 1 samili2109 Good Standing Member
do u have pics?
samili2109 is offline
Old 02-17-2014, 12:14 PM   #16
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
No I dont have any pictures of this , its easy to do just cut the very bottom off just enough to get the spring and plunger out
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 02-17-2014, 12:52 PM   #17
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
You could also just spend like $60 and get a delete from CFM.com
FF MODERATOR
RIFF CREW
Old 02-17-2014, 07:16 PM   #18
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 2%
FF Reputation: 3 paulg127 Good Standing Member
Tom (all), have you seen the 1-way valves, typically found on some boosted Ford's brake vacuum line?
I have used the 1-way valves on the PCV line before the PCV valve and have not had issues...any issues. 4k miles since installed with functioning PCV and minimal added hardware and no oil issues.
Not sure if this is known, but the 1-way valves need to be on the purge lines as well as that is a leak path for boost... not to mention a pressurized fuel tank...
paulg127 is offline
Old 02-17-2014, 07:48 PM   #19
Thomas Racing
Thomas Racing's Avatar
Fan#: 84250
What I Drive: 2003 Pitch Black SVT
Points 294, Level 5
Points: 294, Level: 5 Points: 294, Level: 5 Points: 294, Level: 5
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Thomas Racing Good Standing Member
A better solution is to run a proper catch can/oil separator set up as well as keeping the PCV The crank case and upper engine, re valve cover, shouldn't share a catch can or separator, they should be separate.
Thomas Racing is offline
Old 02-18-2014, 10:35 AM   #20
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
I have tried the one way but it doesn't totally seal off and still lets a lot past and it goes into the intake manifold
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
