How do I remove the steering wheel? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-09-2013, 05:01 PM   #1
rayb98
Fan#: 102532
What I Drive: 2002 Blue Ford Focus
FF Reputation: 1 rayb98 Good Standing Member
I have a 2002 focus se wagon. I need to replace the clockspring. I can get it all apart down to the point of pulling the steering wheel off. But it won't budge. If I take the center bolt all the way out, I can see some gray colored material that appears to be between the shaft and the wheel. Could it be some sort of loctite? I've tried everything I can think of to get it off. Please help! Thanks.
rayb98 is offline
Old 04-09-2013, 05:02 PM   #2
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,234, Level 41
Points: 4,234, Level: 41 Points: 4,234, Level: 41 Points: 4,234, Level: 41
Level Up 43% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Do you need a puller to get the wheel off?
I now drive a Japanese Ford.
macdiesel is online now
Old 04-09-2013, 05:07 PM   #3
rayb98
Fan#: 102532
I can't find one that will work with this car.
The steering wheel has no threaded holes for a standard wheel puller to attach. I tried a 2 jaw puller but it wouldn't fit around the wheel to a point that it would grab anything solid.
rayb98 is offline
Old 04-09-2013, 05:17 PM   #4
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
You need to remove the airbag to get the wheel off, if I remember correctly it's just mounted on the steering column by a big nut behind the airbag. I don't think the steering wheel needs to come all the way off to change the clockspring.
6SPD_soul is offline
Old 04-09-2013, 05:18 PM   #5
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
I don't understand. You should have just a center bolt and it comes right off.
TerryB is offline
Old 04-09-2013, 05:25 PM   #6
rayb98
Fan#: 102532
I thought it would just pull off.
I've read on multiple posts that it would just pull off but it doesn't. The ignition switch was replaced by a locksmith before I owned the vehicle. I wonder if he put loctite on the shaft. Like I said, there appears to be something gray in color that was put on the shaft before the steering wheel was put on. For those who have had there's off. Was there gray stuff on yours?
rayb98 is offline
Old 04-09-2013, 05:28 PM   #7
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
My bad, as usual I didn't fully read your first post. Yeah, the wheel should come off freely if you have the bolt out. I changed a clockspring once and the wheel came off easily after the bolt was out and I don't remember any kind of loctite or anything else, there should be no need for it.
Old 04-09-2013, 05:30 PM   #8
TerryB
TerryB's Avatar
Fan#: 34559
Mine has a 6 sided opening as shown. It slides on with a slight taper. You certainly don't have a factory installation. The Focus wheel is the easiest one of any car to remove.
** here's a how-to, disregard the new wheel info.
http://www.focusowners.com/forum/viewtopic.php?t=18703
TerryB is offline
Old 04-09-2013, 05:33 PM   #9
rayb98
Fan#: 102532
Doesn't quite work for me
The airbag is out, the center bolt is removed, but the steering wheel will not pull off.
rayb98 is offline
Old 04-09-2013, 05:37 PM   #10
rayb98
Fan#: 102532
Exactly like the pic
Mine looks exactly like the picture in the photo. I unthreaded the bolt half way out, pulled on the wheel with all I had while somebody whacked the center bolt with a hammer. No go.
rayb98 is offline
