Weird problem - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2013, 12:09 AM   #11
drummer829
Fan#: 71497
What I Drive: 2005 liq grey ST
FF Reputation: 1 drummer829 Good Standing Member
Originally Posted by sailor View Post
Could be one thing, or a combination of many - Not a "normal" driving pattern as mentioned - and not uncommon in the particular circumstances.
As amc mentioned, the engine is slowing fast and tends to keep doing so in this circumstance. It's got ONE chance to "catch" before continuing to a stop, and the slightest "misfire" for example would be enough that it dies at that point.
Plugs/boots not quite perfect, an injector a bit dirty, IAC a little slow to respond, you could chase the issue quite expensively without solving it if all possiible suggestions were followed. That's probably a major reason for a lack of suggestions to "solve" the problem.
Drive it as is, see if it does anything similar at other times, consider "tune up" type maint. if not done recently (plugs, fuel filter) and see how it goes for now.
Luck!
I was going to swap out the plugs and filter soon. It has been running fine since then, so hopefully maybe my cars warning me to get a tuneup
drummer829 is offline
Old 04-12-2013, 06:23 AM   #12
firststrike51
Fan#: 110323
What I Drive: focus
FF Reputation: 1 firststrike51 Good Standing Member
Sounds like a faulty IAC valve
firststrike51 is offline
Old 04-14-2013, 12:30 AM   #13
drummer829
Fan#: 71497
Originally Posted by firststrike51 View Post
sounds like a faulty iac valve
iac?
Old 04-14-2013, 04:55 AM   #14
amc49
Fan#: 96610
Points 3,390, Level 36
Points: 3,390, Level: 36 Points: 3,390, Level: 36 Points: 3,390, Level: 36
Level Up 27% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Have a look at the TB inside, if it has any buildup around the throttle blade idle setting. Clean it with like acetone on a clean towel, you can get pretty much most of it without removing the TB, that could help and cost nothing. May even help engine starting. Dirty IAC too or 'idle air control' valve.........but they suck getting to on these.
If car doesn't do it in normal driving around town, I'd tune it out of my head.
amc49 is offline
Old 04-14-2013, 12:51 PM   #15
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
I've never owned a Ford that didn't at some point have an Idle Air Control valve fail. Actually I take that back, my mustang never did. But it failed twice on my ranger and twice on my f-150.
FoMoCus is offline
Old 04-30-2013, 10:22 PM   #16
jalissa01
Fan#: 114050
What I Drive: 200, Black, SE
FF Reputation: 1 jalissa01 Good Standing Member
I am having about the same problem. When I turn on my car it has a lot of issues switching into gear; it dies sometimes multiple times. It is normally easy to start back up but occasionally it acts like the battery is dead and does not try to turn on. Also, my rpms seem to be all over the place. Here is a video of what it does, it dies at the end. http://www.youtube.com/watch?v=ez4mmQA539w also, it is making a lot of noise which is here: http://www.youtube.com/watch?v=3b0VsTt3-S0 Any Ideas?
jalissa01 is offline
