Weird problem - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 04-09-2013, 03:13 PM   #1
drummer829
Fan#: 71497
What I Drive: 2005 liq grey ST
FF Reputation: 1 drummer829 Good Standing Member
Weird problem
So my car has been driving awesome for the last 2 years, but today something weird happened. I sped up in 2nd gear and got to around 6k rpms and when I put it in neutral to coast, the car died. I got some groceries, got in the car and tried it again thinking maybe I did something, but the exact same thing. I tried it in 1st gear and got my rpms to around 6k and it was fine.
drummer829 is offline
Old 04-09-2013, 03:16 PM   #2
drummer829
Fan#: 71497
Also, the car turns on fine right after it happens like nothing ever happened. It just dies, then coasts and I turn it back on real quick. Accelerates normal and drives fine
Old 04-09-2013, 03:49 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,750, Level 73
Points: 12,750, Level: 73 Points: 12,750, Level: 73 Points: 12,750, Level: 73
Level Up 75% Completed
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
FF Reputation: 28 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 04-09-2013, 06:57 PM   #4
wintuk
Fan#: 58265
What I Drive: 2003 Pitch Black ZTS Centennial Edi
Points 52, Level 1
Points: 52, Level: 1 Points: 52, Level: 1 Points: 52, Level: 1
Level Up 4% Completed
FF Reputation: 1 wintuk Good Standing Member
Check the fuel pump.
wintuk is offline
Old 04-09-2013, 07:11 PM   #5
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
It sounds like the engine is being starved for either: Air, fuel, or a spark to ignite them all.
It could be a lot of potential things. The fuel pump, the fuel filter (cheaper to replace!), dirty MAF, dirty throttle body, or a myriad of other things.
The fact that you say it runs fine, but will stall out, and then start up again fine like nothing happens makes me agree with wintuk. It is probably fuel related.
You should definitely look into replacing the fuel filter. They are generally in the $20 USD range.
According to my local auto parts stores costs, it falls closer around: $10.
You can also go to auto parts stores, and borrow (100% free! No tax) a fuel pressure tester, and use the schrader valve (if you have one) on your vehicle to check.
Oblivion is offline
Old 04-10-2013, 03:38 AM   #6
amc49
Fan#: 96610
Points 3,084, Level 34
Points: 3,084, Level: 34 Points: 3,084, Level: 34 Points: 3,084, Level: 34
Level Up 23% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
FF Reputation: 25 amc49 Great Standing Member
If it's running up to 6K then not fuel. He says it dies after letting off or going to neutral. Could be IAC or TB aircrack carboned up, which are supposed to take up idle throttle when letting off, or could be nothing. I used to hotrod both bikes and cars, sometimes dying after a hard pass was the norm, nothing wrong there at all other than whatever is supposed to maintain idle speed is not working as well as it should. The main reason for damping dashpots on oldschool carbs in the later '70s and '80s was this very thing. They simply made up a device that slowed the engine speed from dropping so fast, a 6000 to 700 rpm drop has a tendency to keep dropping, inertia, you know.
amc49 is offline
Old 04-10-2013, 01:24 PM   #7
drummer829
Fan#: 71497
So would you suggest just driving it for a few days and see if it continues?
Old 04-10-2013, 07:38 PM   #8
amc49
Fan#: 96610
Forum Activity 60%
What a question. If you continue to zing the motor to 6k and let off, then expect the same result. Those things don't fix themselves.
My suggestion? Get one of these...........
'They simply made up a device that slowed the engine speed from dropping so fast'
It's called your right foot.................I've been doing it for 40+ years when the need shows. Basic physics, young jedi.
amc49 is offline
Old 04-11-2013, 12:30 PM   #9
drummer829
Fan#: 71497
I don't normally do that though, but once in a while its fun to get the car going so I was confused why it happened
Old 04-11-2013, 02:56 PM   #10
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Points 11,047, Level 69
Points: 11,047, Level: 69 Points: 11,047, Level: 69 Points: 11,047, Level: 69
Level Up 50% Completed
Forum Activity 99%
FF Reputation: 76 sailor Excellent Standing Member
Could be one thing, or a combination of many - Not a "normal" driving pattern as mentioned - and not uncommon in the particular circumstances.
As amc mentioned, the engine is slowing fast and tends to keep doing so in this circumstance. It's got ONE chance to "catch" before continuing to a stop, and the slightest "misfire" for example would be enough that it dies at that point.
Plugs/boots not quite perfect, an injector a bit dirty, IAC a little slow to respond, you could chase the issue quite expensively without solving it if all possiible suggestions were followed. That's probably a major reason for a lack of suggestions to "solve" the problem.
Drive it as is, see if it does anything similar at other times, consider "tune up" type maint. if not done recently (plugs, fuel filter) and see how it goes for now.
Luck!
sailor is online now
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
