Getting Balljoint Pin Back in - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-08-2013, 11:25 AM   #1
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,193, Level 34
Points: 3,193, Level: 34 Points: 3,193, Level: 34 Points: 3,193, Level: 34
Level Up 96% Completed
Forum Activity 14%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
Ive replaced the stock balljoints with the moog ones and am having trouble getting the new ball joint "pin" back into the knuckle, Ive even tried compressing it with a jack and still no go any help would be appreciated.
The hole is clean and lubed up and lined up it just wont go in far enough so i can get the bolt through, its like it gets stuck.
qweesy is offline
Old 04-08-2013, 05:23 PM   #2
apagios
apagios's Avatar
Fan#: 40891
What I Drive: '03 ZX5 SVT, '05 Mazdaspeed Miata
Points 873, Level 15
Points: 873, Level: 15 Points: 873, Level: 15 Points: 873, Level: 15
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 3 apagios Good Standing Member
I just did mine a few months back.
It's a tight fit if not going perfectly straight in. I find with a little pressure fromt he floor jack (not too much!) and twisting the wheel knuckle, with a little pushing to get the pin aligned correctly with the hole in the knuckle it goes in.
I was able to get one in without jack pressure by manually pushing the pin at an angle back towards the engine, so that when you raise the LCA it's more of a straight shot with the hole.
If it's too tight, try realigning, I wouldn't want to get it stuck!
apagios is offline
Old 04-09-2013, 05:02 PM   #3
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 14%
k ill try, over on FJ Steve suggested to open her legs a little ;)....... with the air hammer
qweesy is offline
Old 04-09-2013, 05:25 PM   #4
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,543, Level 22
Points: 1,543, Level: 22 Points: 1,543, Level: 22 Points: 1,543, Level: 22
Level Up 44% Completed
FF Reputation: 4 Chris_HT Good Standing Member
Talk to it gently and use some saliva...
Chris_HT is offline
Old 04-09-2013, 06:55 PM   #5
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Hammer time that bolt.
I now drive a Japanese Ford.
macdiesel is offline
Old 04-11-2013, 04:58 PM   #6
apagios
apagios's Avatar
Fan#: 40891
I actually just installed mine last night. Finally got my SVTF driving again after a clutch install.
I've always been a little leary of slamming on it with a hammer and concerned about hurting the ball joint and the bearing surface inside that the bolt rests on. Plus my new Moog ball joints have a zerk fitting on them to grease up.
I sprayed PB blaster on a paper towel and cleaned up the bolt itself and the hole in the wheel knuckle and mine slide ride in.
I did have a tough time with the strut and getting it seated into the wheel knuckle, borrowed a friends dead blow hammer, the orange plastic is nice to know you're not slamming a metal hammer on anything.
apagios is offline
Old 07-02-2013, 03:28 PM   #7
1bad03zx5
Fan#: 114690
What I Drive: 2003 pitch black ZX5
FF Reputation: 1 1bad03zx5 Good Standing Member
ball joints
I just installed some new Moog ball joints in my car. The pin/bolt is a snug fit,but went in fine with a little persuasion.
2003 focus SVT ZX5,65k miles,pitch black,red/black int,cold weather package,K&N drop in,MSD coil/wires,poly dogbone,steeda tri-ax shifter,momo shift knob,borla catback,prothane full kit,dimpled/slotted rotors,ss brake lines !FOR SALE!
1bad03zx5 is offline
Old 07-02-2013, 07:02 PM   #8
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 14%
I spread her legs a little with that air chisel and slipped it on in NO lube needed ;)
qweesy is offline
Old 07-02-2013, 09:22 PM   #9
macdiesel
macdiesel's Avatar
Fan#: 31579
Wasn't the another threads here that compared the moog and oem shoulder bolts for the ball joint and found the moog to be slightly thinner? I reused my oem bolts.
Old 07-02-2013, 11:37 PM   #10
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 14%
those bolts should not be re-used my OEM ones were stretched , and moog has its own bolt + nut anyway so you shouldnt be reusing anything
qweesy is offline
